stm32c8t6
iic 4腳OLED
HX711按代碼接線
- #include "stm32f10x.h"
- #include "delay.h"
- #include "HX711.h"
- #include "oled.h"
- #include "bmp.h"
- int main(void)
- unsigned char m=0,gtemp=0,i,zm,mt[10]={0,0,0,0,0,0,0,0,0,0};
- s32 k=0;
- Init_HX711pin();
- delay_init();
- OLED_Init();
- OLED_ColorTurn(0);//0正常顯示,1 反色顯示
- OLED_DisplayTurn(0);//0正常顯示 1 屏幕翻轉(zhuǎn)顯示
- Get_Maopi(); //稱空板重量
- delay_ms(1000);
- delay_ms(1000);
- Get_Maopi(); //重新獲取空板重量
- while(1)
- Get_Weight();
- if(gtemp > Weight_Shiwu)
- { zm = zm + gtemp;}
- delay_ms(500);
- if(Weight_Shiwu!=0)
- { gtemp=Weight_Shiwu;}
- if(Weight_Shiwu==0 && gtemp!=Weight_Shiwu)
- m++;
- gtemp=Weight_Shiwu;
- OLED_Refresh();
- OLED_ShowChinese(0,10,0,16,1);//茄
- OLED_ShowChinese(18,10,1,16,1);//子
- OLED_ShowChinese(36,10,2,16,1);//數(shù)
- OLED_ShowChinese(54,10,3,16,1);//量
- OLED_ShowChar(70,10,':',16,1);//:
- OLED_ShowNum(79,10,m,3,16,1);
- OLED_ShowPicture(109,10,16,16,BMP1,1);
- OLED_ShowChinese(0,28,0,16,1);//茄
- OLED_ShowChinese(18,28,1,16,1);//子
- OLED_ShowChinese(36,28,4,16,1);//重
- OLED_ShowChinese(54,28,3,16,1);//量
- OLED_ShowChar(70,28,':',16,1);//:
- OLED_ShowNum(79,28,Weight_Shiwu,4,16,1);
- OLED_ShowString(114,28,"g",16,1);
- OLED_ShowChinese(0,46,0,16,1);//茄
- OLED_ShowChinese(18,46,1,16,1);//子
- OLED_ShowChinese(36,46,4,16,1);//重
- OLED_ShowChinese(54,46,3,16,1);//量
- OLED_ShowChar(70,46,':',16,1);//:
- OLED_ShowNum(79,46,zm,4,16,1);
- OLED_ShowString(114,46,"g",16,1);
復制代碼- #include "HX711.h"
- u32 HX711_Buffer;
- u32 Weight_Maopi;
- s32 Weight_Shiwu;
- u8 Flag_Error = 0;
- //校準參數(shù)
- //因為不同的傳感器特性曲線不是很一致,因此,每一個傳感器需要矯正這里這個參數(shù)才能使測量值很準確。
- //當發(fā)現(xiàn)測試出來的重量偏大時,增加該數(shù)值。
- //如果測試出來的重量偏小時,減小改數(shù)值。
- //該值可以為小數(shù)
- #define GapValue 106.5
- void Init_HX711pin(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); //使能PF端口時鐘
- //HX711_SCK
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; // 端口配置
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽輸出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度為50MHz
- GPIO_Init(GPIOB, &GPIO_InitStructure); //根據(jù)設定參數(shù)初始化GPIOB
- //HX711_DOUT
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;//輸入上拉
- GPIO_SetBits(GPIOB,GPIO_Pin_0); //初始化設置為0
- //讀取HX711
- u32 HX711_Read(void) //增益128
- unsigned long count;
- unsigned char i;
- HX711_DOUT=1;
- delay_us(1);
- HX711_SCK=0;
- count=0;
- while(HX711_DOUT);
- for(i=0;i<24;i++)
- HX711_SCK=1;
- count=count<<1;
- delay_us(1);
- HX711_SCK=0;
- if(HX711_DOUT)
- count++;
- delay_us(1);
- HX711_SCK=1;
- count=count^0x800000;//第25個脈沖下降沿來時,轉(zhuǎn)換數(shù)據(jù)
- delay_us(1);
- HX711_SCK=0;
- return(count);
- //獲取毛皮重量
- void Get_Maopi(void)
- Weight_Maopi = HX711_Read();
- //稱重
- void Get_Weight(void)
- HX711_Buffer = HX711_Read();
- if(HX711_Buffer > Weight_Maopi)
- Weight_Shiwu = HX711_Buffer;
- Weight_Shiwu = Weight_Shiwu - Weight_Maopi; //獲取實物的AD采樣數(shù)值。
- Weight_Shiwu = (s32)((float)Weight_Shiwu/GapValue); //計算實物的實際重量
- //因為不同的傳感器特性曲線不一樣,因此,每一個傳感器需要矯正這里的GapValue這個除數(shù)。
復制代碼
Keil代碼下載:
稱+oled Keil代碼.7z
(207.22 KB, 下載次數(shù): 145)
2022-10-26 20:10 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
