使用stc89c52控制,LCD1602顯示溫度,顯示設定報警值,功能簡單,報警裝置為BB響,代碼較為粗糙,大佬可自行修改,小白可參考學習,第一個按鍵為安全按鍵,按住不放再按另外兩個按鍵可以調(diào)節(jié)溫度報警值,溫度顯示值可能有誤差,誤差大的話智能程序內(nèi)調(diào)整了
2022-11-8 17:13 上傳
2022-11-8 10:44 上傳
單片機源程序如下:
- // 1602液晶顯示
- //單片機 AT89S52 或 STC89C52RC
- //功能 晶振 11.0592M 波特率 9600
- #include <reg51.h>
- #include <intrins.h>
- typedef unsigned char U8; /* defined for unsigned 8-bits integer variable 無符號8位整型變量 */
- typedef signed char S8; /* defined for signed 8-bits integer variable 有符號8位整型變量 */
- typedef unsigned int U16; /* defined for unsigned 16-bits integer variable 無符號16位整型變量 */
- typedef signed int S16; /* defined for signed 16-bits integer variable 有符號16位整型變量 */
- typedef unsigned long U32; /* defined for unsigned 32-bits integer variable 無符號32位整型變量 */
- typedef signed long S32; /* defined for signed 32-bits integer variable 有符號32位整型變量 */
- typedef float F32; /* single precision floating point variable (32bits) 單精度浮點數(shù)(32位長度) */
- typedef double F64; /* double precision floating point variable (64bits) 雙精度浮點數(shù)(64位長度) */
- #define uchar unsigned char
- #define uint unsigned int
- #define Data_0_time 4
- #define LCD1602_DB P0
- sbit LCD1602_RS = P2^0; //1602液晶引腳定義
- sbit LCD1602_RW = P2^1;
- sbit LCD1602_E = P2^2;
- sbit xz = P2^5; //按鍵
- sbit jia = P2^6;
- sbit jian = P2^7;
- sbit buzz = P3^7; //蜂鳴器
- sbit SO = P1^5; //P3.6口與SO相連
- sbit SCK = P1^6; //P3.4口與SCK相連
- sbit CS = P1^7; //P3.5口與CS相連
- //const unsigned char DevID = 1; //本機設備ID
- unsigned char buffer; //串口接收緩沖區(qū)
- unsigned char rcv_buffer[20];
- //unsigned char send_buffer[20];
- //unsigned char flag_ok = 0; //接收完畢的標識
- unsigned int MAX6675_Temp;
- unsigned char Flag_connect;
- //unsigned char CRCH,CRCL;
- //unsigned char wd[2]; //wd[]:BCD碼的溫度
- //unsigned char flag_dis; //顯示刷新的標識
- /* 等待液晶準備好 */
- void LcdWaitReady()
- unsigned char sta;
- LCD1602_DB = 0xFF;
- LCD1602_RS = 0;
- LCD1602_RW = 1;
- do {
- LCD1602_E = 1;
- sta = LCD1602_DB; //讀取狀態(tài)字
- LCD1602_E = 0;
- } while (sta & 0x80); //bit7等于1表示液晶正忙,重復檢測直到其等于0為止
- /* 向LCD1602液晶寫入一字節(jié)命令,cmd-待寫入命令值 */
- void LcdWriteCmd(unsigned char cmd)
- LcdWaitReady();
- LCD1602_RS = 0;
- LCD1602_RW = 0;
- LCD1602_DB = cmd;
- LCD1602_E = 1;
- LCD1602_E = 0;
- /* 向LCD1602液晶寫入一字節(jié)數(shù)據(jù),dat-待寫入數(shù)據(jù)值 */
- void LcdWriteDat(unsigned char dat)
- LcdWaitReady();
- LCD1602_RS = 1;
- LCD1602_RW = 0;
- LCD1602_DB = dat;
- LCD1602_E = 1;
- LCD1602_E = 0;
- /* 設置顯示RAM起始地址,亦即光標位置,(x,y)-對應屏幕上的字符坐標 */
- void LcdSetCursor(unsigned char x, unsigned char y)
- unsigned char addr;
- if (y == 0) //由輸入的屏幕坐標計算顯示RAM的地址
- addr = 0x00 + x; //第一行字符地址從0x00起始
- else
- addr = 0x40 + x; //第二行字符地址從0x40起始
- LcdWriteCmd(addr | 0x80); //設置RAM地址
- /* 在液晶上顯示字符串,(x,y)-對應屏幕上的起始坐標,str-字符串指針 */
- void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str)
- LcdSetCursor(x, y); //設置起始地址
- while (*str != '\0') //連續(xù)寫入字符串數(shù)據(jù),直到檢測到結(jié)束符
- LcdWriteDat(*str++);
- /* 打開光標的閃爍效果 */
- void LcdOpenCursor()
- LcdWriteCmd(0x0F);
- /* 關閉光標顯示 */
- void LcdCloseCursor()
- LcdWriteCmd(0x0C);
- /* 初始化1602液晶 */
- void InitLcd1602()
- LcdWriteCmd(0x38); //16*2顯示,5*7點陣,8位數(shù)據(jù)接口
- LcdWriteCmd(0x0C); //顯示器開,光標關閉
- LcdWriteCmd(0x06); //文字不動,地址自動+1
- LcdWriteCmd(0x01); //清屏
- void Delay(U16 j)
- { U8 i;
- for(;j>0;j--)
- for(i=0;i<27;i++);
- unsigned int MAX6675_ReadReg(void)
- unsigned char i;
- unsigned int dat;
- i = 0;
- dat = 0;
- CS = 0;
- SCK = 0;
- for(i=0; i<16; i++) //get D15-D0 from 6675
- SCK = 1;
- dat = dat<<1;
- if( SO==1 )
- dat = dat|0x01;
- SCK = 0;
- CS = 1;
- return dat;
- * 功 能:延時,若干毫秒
- * 參 數(shù):毫秒數(shù)
- * 返回值:無
- void DelayMs(unsigned int i) //一個延時函數(shù),這個函數(shù)在11.0592M晶振下的延時時間大概為1ms
- unsigned int j,k;
- for(j=i; j>0; j--)
- for(k=114; k>0; k--);
- unsigned char shezhi = 145; //數(shù)值設置默認值145
- U8 shezhi_zu[3]; //默認值設置
- unsigned int temph;
- U8 temp_zu[4];
- U8 bba_zu[2];
- U8 kb[1] ;
- void Display(unsigned int temp)
- kb[0] = 0x0a;
- bba_zu[0] = 0xdf;
- bba_zu[1] = 0x43;
- temph = temp-2; //誤差
- temp_zu[0] = temph/100+'0'; //溫度運算
- temp_zu[1] = (temph/10)%10+'0';
- temp_zu[2] = temph%10+'0';
- shezhi_zu[0] = shezhi/100+'0'; //數(shù)值設置1
- shezhi_zu[1] = (shezhi/10)%10+'0';
- shezhi_zu[2] = shezhi%10+'0';
- if(Flag_connect==0) //Flag_connect為0 表示熱電偶已連接,這時顯示溫度
- LcdShowStr(0,0,"T:");
- LcdShowStr(3,0,temp_zu);
- //LcdShowStr(0,0,".");
- LcdShowStr(6,0,bba_zu);//單位
- LcdShowStr(0,3,"C:");
- LcdShowStr(3,3,shezhi_zu);
- else //Flag_connect為1表示 熱電偶未連接,這時顯示FFFF
- LcdShowStr(9,0,"ERROR");
- buzz = 0;
- Delay(1000);
- buzz = 1;
- Delay(1000);
- /*****************定時器0中斷服務*******************/
- void Int0()
- TMOD=0x01; //設置定時器0為工作方式1
- TH0=(65536-45872)/256;
- TL0=(65536-45872)%256; //裝初值
- EA=1;//開總中斷
- ET0=1;//開啟定時器0中斷
- TR0=1;//啟動定時器0
- unsigned char num;
- void T0time() interrupt 1
- TL0=(65536-45872)%256; //重裝初值,保證每次進入中斷函數(shù)都是50ms
- num++;
- if(num >= 15 ){
- if (temph >= shezhi){
- buzz =~ buzz;
- num = 0;
- //main()功能描述: AT89C51 11.0592MHz
- void main()
- unsigned char cnt = 11;
- unsigned int t;
- buzz = 1;
- Int0(); //定時器0開啟函數(shù)
- Delay(100); //延時100US(12M晶振)
- InitLcd1602(); /* 初始化1602液晶 */
- while(1)
- t=MAX6675_ReadReg();
- Flag_connect=t&0x04; //讀出數(shù)據(jù)的D2位是熱電偶掉線標志位,該位為1表示掉線,該位為0表示連接
- Flag_connect=Flag_connect>>2; //MAX6675是否在線
- t = t<<1; //讀出來的數(shù)據(jù)的D3~D14是溫度值
- t = t>>4;
- MAX6675_Temp = t/4; //測得的溫度單位是0.25,所以要乘以0.25(即除以4)才能得到以度為單位的溫度值
- /*-------------按鍵檢測---------------------*/
- if(xz == 0 )
- Delay(50);
- if(xz == 0)
- if(jia == 0)
- Delay(100);
- if(jia == 0)
- shezhi = shezhi+1;
- }if(jian == 0){
- Delay(100);
- if(jian == 0)
- shezhi = shezhi-1;
- // if (temph >= shezhi){
- // buzz = 0;
- // Delay(1000);
- // buzz = 1;
- // Delay(1000);
- for(t=0; t<200; t++) //顯示溫度
- Display(MAX6675_Temp);
復制代碼
2022-11-8 17:22 上傳
顯示有一定的誤差 大家自行在程序里面校正一下
Keil代碼與Proteus仿真下載:
仿真程序.7z
(91.06 KB, 下載次數(shù): 52)
2022-11-8 17:18 上傳
點擊文件名下載附件
仿真+程序
