查看: 2132|回復(fù): 0
光照傳感器實驗含arduino代碼,Proteus仿真原理圖
ID:1051174 發(fā)表于 2022-11-9 13:27 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
光照器原理:
1.兩個通道,通道0是可檢測可見光和紅外光
2.通道1可檢測紅外光
3.輸入電壓在2.7v-5.5v之間
4.出腳SMBus串行數(shù)據(jù)I/O總線,SMBCLK:SMBus串行時鐘輸入總線
/*  TCS3200 Colour Sensor!
    Sensor Pin S0 -> Arduino Pin D5    Sensor Pin S1 -> Arduino Pin D4
    Sensor Pin S2 -> Arduino Pin D6    Sensor Pin S3 -> Arduino Pin D7
    Sensor Pin OUT -> Arduino Pin D8
  Date:20221104
  Author:Lee get from net!
#define S0_PIN 5
#define S1_PIN 4
#define S2_PIN 7
#define S3_PIN 6
#define CAI_PIN  8
void setup()
  // Set the S0, S1, S2, S3 Pins as Output
  pinMode(S0_PIN, OUTPUT);
  pinMode(S1_PIN, OUTPUT);
  pinMode(S2_PIN, OUTPUT);
  pinMode(S3_PIN, OUTPUT);
  //Set OUT_PIN as Input
  pinMode(CAI_PIN, INPUT);
  // Set Pulse Width scaling to 20%
  digitalWrite(S0_PIN, HIGH);
  digitalWrite(S1_PIN, LOW);
  // Enabl UART for Debugging
  Serial.begin(9600);
void loop()
  int r, g, b;
  r = process_red_value();
  delay(200);
  g = process_green_value();
  delay(200);
  b = process_blue_value();
  delay(200);
  Serial.print("r = ");
  Serial.print(r);
  Serial.print(" ");
  Serial.print("g = ");
  Serial.print(g);
  Serial.print(" ");
  Serial.print("b = ");
  Serial.print(b);
  Serial.print(" ");
  Serial.println();
  if (r < 42)
    Serial.println("Colour Pink");
  else if (g < 63)
    Serial.println("Colour Green");
  else if (r < 64)
    Serial.println("Colour Red");
int process_red_value()
  digitalWrite(S2_PIN, LOW);
  digitalWrite(S3_PIN, LOW);
  int pulse_length = pulseIn(CAI_PIN, LOW);
  return pulse_length;
int process_green_value()
  digitalWrite(S2_PIN, HIGH);
  digitalWrite(S3_PIN, HIGH);
int process_blue_value()
admin + 50 共享資料的黑幣獎勵!
