查看: 1410|回復(fù): 2
單片機(jī)矩陣和獨(dú)立按鍵的結(jié)合但不知道哪里出錯(cuò)還是實(shí)現(xiàn)不了退格清零,麻煩各位幫忙...
#include <regx52.h>
#include <intrins.h>
sbit beep=P2^3;
sbit DU = P2^6;
sbit WE = P2^7;
sbit key_s2 = P3^0;
uchar num;
uchar KeyValue = 20;
uchar temp;
uchar  code tabel[]= {
//0                1         2     3     4     5     6     7     8
0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F,
//9     A     B           C         D           E         F                H         L
0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71, 0x76, 0x38,
//n           u          -          ??
0x37, 0x3E, 0x40, 0x00 };
void delay(uint z)
        uint x,y;
        for(x = z; x > 0; x--)
                for(y = 114; y > 0 ; y--);
void KeyScan()
        P3 = 0XF0;
        if(P3 != 0XF0)
                delay(10);
                if(P3 != 0XF0)
                        switch(P3)
                                case 0xe0:        KeyValue = 0;        break;
                                case 0xd0:        KeyValue = 1;        break;
                                case 0xb0:        KeyValue = 2;        break;
                                case 0x70:        KeyValue = 3;        break;
                        P3 = 0X0F;
                        switch(P3)
                                case 0x0e:        KeyValue = KeyValue;        break;
                                case 0x0d:        KeyValue = KeyValue + 4;        break;
                                case 0x0b:        KeyValue = KeyValue + 8;        break;
                                case 0x07:        KeyValue = KeyValue + 12;        break;
                        while(P3 != 0X0F);
        P3 = 0XFF;
        if(P3 != 0XFF)
                delay(10);
                if(P3 != 0XFF)
                        switch(P3)
                                case 0xfe:        KeyValue = 16;        break;
                                case 0xfd:        KeyValue = 17;        break;
                                case 0xfb:        KeyValue = 18;        break;
                                case 0xf7:        KeyValue = 19;        break;
                        while(P3 != 0XFF);
void Template()
        if(KeyValue==0)
                num=0;
        else if(KeyValue==1)
                num=1;
        else if(KeyValue==2)
                num=2;
        else if(KeyValue==3)
                num=3;
        else if(KeyValue==4)
                num=4;
        else if(KeyValue==5)
                num=5;
        else if(KeyValue==6)
                num=6;
        else if(KeyValue==7)
                num=7;
        else if(KeyValue==8)
                num=8;
        else if(KeyValue==9)
                num=9;
        else if(KeyValue==10)
                num=10;
        else if(KeyValue==11)
                num=11;
        else if(KeyValue==12)
                num=12;
        else if(KeyValue==13)
                num=13;
        else if(KeyValue==14)
                num=14;
        else if(KeyValue==15)
                num=15;
        if(KeyValue==16)
                if(num!=9)  num++;
                if(4<KeyValue&&KeyValue<9)
                        temp=_crol_(temp,1);
                        P1=temp;
                        beep=~beep;
                        delay(500);
        else if(KeyValue=17)
                num=num-1;
                if(num==0);num=0;
        else if(KeyValue=18)
                num=num+1;
                if(num>9)num=9;
        else if(KeyValue=19)
                num=0;
  KeyValue=49;
        temp=0xf0;
        P1=temp;
        WE = 1;
        P0 = 0XFE;
        WE = 0;
        DU = 1;
                KeyScan();
                Template();
                P0 = tabel[num];
ID:161164 發(fā)表于 2022-11-13 17:34 | 只看該作者
ID:123289 發(fā)表于 2022-11-14 15:25 | 只看該作者
矩陣的各個(gè)鍵都是等價(jià)的,關(guān)鍵是按下后你程序如何執(zhí)行!
退格:清除上次鍵操作的結(jié)果,將光標(biāo)(指針)停留在上次的鍵位上。
這就要求你記住每次操作的鍵位置。
清零:將當(dāng)前位置上的東東清0 。
也要求你對(duì)每次操作的鍵位置有記錄,還要求你對(duì)清0有定義。
