查看: 2188|回復(fù): 0
STM32單片機(jī)超聲波測(cè)距程序 原理圖PCB文件
ID:396474 發(fā)表于 2022-11-18 15:36 | 顯示全部樓層 |閱讀模式
STM32超聲波測(cè)距protel99se畫的原理圖和PCB圖如下:(51hei附件中可下載工程文件)
#include "delay.h"
#include "sys.h"
#include "usart.h"
#include "timer.h"
#include "HCSR04.h"
#include "led.h"
#include "beep.h"
#include "key.h"
#include "lcd1602.h"
#include "stmflash.h"  //包含頭文件
unsigned long S=0; //定義超聲數(shù)據(jù)
#define FLASH_SAVE_ADDR  0X0800FF00                //設(shè)置FLASH 保存地址(必須為偶數(shù),且其值要大于本代碼所占用FLASH的大小+0X08000000)
extern unsigned long Clock_time;
unsigned char Send_flag=0;
extern u8  TIM3CH1_CAPTURE_STA;                //輸入捕獲狀態(tài)
extern u16        TIM3CH1_CAPTURE_VAL;        //輸入捕獲值
u16 fls[4];
u8 k=0;
u32 TL=50;
u8 beep1;
u8 t=0;
void key() //按鍵函數(shù)
        k=KEY_Scan(1); //按鍵掃描的值給K
        if(k == KEY0_PRES) //如果K等于  KEY0_PRES,就說明是按下加按鍵
                TL++;     //數(shù)據(jù)加一,如果大于400,則減一,保持最大400
                if(TL>400)
                        TL--;
                fls[0]=TL;
                STMFLASH_Write(FLASH_SAVE_ADDR,(u16*)fls,1); //存儲(chǔ)
        if(k == KEY1_PRES)//同上,不過是減
                TL--;
                if(TL<5)
                        TL++;
                fls[0]=TL;
void ceju()
        Trig=1;
        delay_us(20);
        Trig=0;              //啟動(dòng)信號(hào)
        S=0;                     //清零距離數(shù)據(jù)
        Clock_time=0;
        TIM_Cmd(TIM3, DISABLE);  //關(guān)定時(shí)器,清零計(jì)時(shí)變量
        while(!GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_5)); //等待檢測(cè)到高電平
        Clock_time=0;
        TIM_Cmd(TIM3, ENABLE);  //開定時(shí)器
        while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_5)==1&&Clock_time<47058);  //只要是高,一直算時(shí)間,如果時(shí)間計(jì)數(shù)超過 47058,所說有問題,直接跳過,47058不一定精確,是一個(gè)大概值,
        S=((Clock_time*2)*340/10000)/2;   //時(shí)間變量是2us加一,乘以速度,因?yàn)闀r(shí)間是us,換成秒是除以1000000,保留兩位小數(shù),所以除以 10000,然后除以二得到單方面距離
        Clock_time=0;            //清零數(shù)據(jù)
        printf("Distance:%d cm\r\n",S);//打印總的高點(diǎn)平時(shí)間
void show()
        LCD1602_Show_Str(0,0,"Distance:");    //顯示
        if(S>=100&&S<=400) LCD1602_Write_Dat(S/100%10+0x30); //這里是測(cè)速數(shù)據(jù)
        else LCD1602_Show_Str(9,0," ");
        if(S>=10) LCD1602_Write_Dat(S/10%10+0x30);
        else LCD1602_Show_Str(10,0," ");
        LCD1602_Write_Dat(S%10+0x30);
        LCD1602_Show_Str(12,0,"cm      ");
        LCD1602_Show_Str(0,1,"alarm  :"); //這里開始顯示報(bào)警數(shù)據(jù),下面這三段,其實(shí)就是判斷閾值數(shù)據(jù)是百位數(shù)還是十位數(shù)還是個(gè)位數(shù),如果是個(gè)位數(shù),顯示個(gè)位數(shù)據(jù),百位十位顯示空
        if(TL>=100&&TL<=400)
                LCD1602_Write_Dat(TL/100%10+0x30);
                LCD1602_Write_Dat(TL/10%10+0x30);
                LCD1602_Write_Dat(TL%10+0x30);
                LCD1602_Show_Str(12,1,"cm      ");
   if(TL>=10&&TL<100)
                LCD1602_Show_Str(9,1," ");
        if(TL>0&&TL<10)
                LCD1602_Show_Str(10,1," ");
void problem()  //報(bào)警函數(shù)
        if(S<TL)     //小于閾值,蜂鳴器開始響,對(duì)應(yīng)指示燈亮,否則蜂鳴器不響
                beep1=1;
                LED1=1;
                beep1=0;
                LED1=0;
                LED0=1;
int main(void)
        u16 datatemp[1];
        BEEP_Init();
        KEY_Init();
        delay_init();                     //延時(shí)函數(shù)初始化
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);         //設(shè)置NVIC中斷分組2:2位搶占優(yōu)先級(jí),2位響應(yīng)優(yōu)先級(jí)
        uart_init(115200);         //串口初始化為115200
        LED_Init();                             //LED端口初始化
        UltrasonicWave_Configuration();  //初始化超聲IO
        TIM3_Cap_Init(1,72-1);        //以1Mhz的頻率計(jì)數(shù),第一個(gè)選項(xiàng),最小只能是1
        LCD1602_Init();
        STMFLASH_Read(FLASH_SAVE_ADDR,(u16*)datatemp,1);
        TL=datatemp[0];
        if(TL<5||TL>400)
        TL=50;
        ceju();
        printf("Distance"); //串口打印一下,調(diào)試用
                if(beep1==1) //如果蜂鳴器標(biāo)志等于1,則開始滴滴叫,指示燈也是閃爍
                        BEEP=!BEEP;
                        LED0=!LED0;
                                BEEP=0;
                show();   //調(diào)用顯示函數(shù)
                key();    //調(diào)用按鍵函數(shù)
                problem();//調(diào)用報(bào)警處理函數(shù)
                t++;      //變量自加,加到5的時(shí)候,對(duì)5取余會(huì)等于0,則啟動(dòng)一次測(cè)距函數(shù)
                if(t%5==0)
                        t=0;
                        ceju();
下載: STM32 超聲波測(cè)距程序和protel99格式的PCB原理圖.7z (343.72 KB, 下載次數(shù): 41)
