從網(wǎng)上下載公歷轉(zhuǎn)農(nóng)歷模塊并應(yīng)用于公歷轉(zhuǎn)換農(nóng)歷,覺得轉(zhuǎn)換速度極快的,很實用。公歷轉(zhuǎn)農(nóng)歷模塊的源碼作者的確是高手!但最近發(fā)現(xiàn)一個小錯誤,就是在今年(2013年)的6月中旬公歷轉(zhuǎn)換成農(nóng)歷時好像要差一天,如今天是6月18日,農(nóng)歷是五月十一,可是用此模塊轉(zhuǎn)換出來的農(nóng)歷卻是五月初十,差了一天。
源碼中作者有具體說明十六進制的農(nóng)歷常量的編寫方法,本人根據(jù)說明,確定原因是2013的農(nóng)歷四月份被作者設(shè)置成大月,而實際是小月,于是動手將2013年的四月設(shè)置成小月,即農(nóng)歷常量中的B5500D2改成A5500D2,問題終于得到解決。下面是正確的源碼:
Option Explicit
'公歷轉(zhuǎn)農(nóng)歷模塊
'原創(chuàng):互聯(lián)網(wǎng)
'修正:阿勇 2005/1/12
'再修正:揭陽新新科技 2013/6/18
'// 農(nóng)歷數(shù)據(jù)定義 //
'先以 H2B 函數(shù)還原成長度為 18 的字符串,其定義如下:
'前12個字節(jié)代表1-12月:1為大月,0為小月;壓縮成十六進制(1-3位)
'第13位為閏月的情況,1為大月30天,0為小月29天;(4位)
'第14位為閏月的月份,如果不是閏月為0,否則給出月份(5位)
'最后4位為當(dāng)年農(nóng)歷新年的公歷日期,如0131代表1月31日;當(dāng)作數(shù)值轉(zhuǎn)十六進制(6-7位)
'農(nóng)歷常量(1899~2100,共202年)
Private Const ylData = "AB500D2,4BD0883," _
& "4AE00DB,A5700D0,54D0581,D2600D8,D9500CC,655115D,56A00D5,9AD00CA,55D027A,4AE00D2," _
& "A5B0682,A4D00DA,D2500CE,D25157E,B5500D6,56A00CC,ADA027B,95B00D3,49717C9,49B00DC," _
& "A4B00D0,B4B0580,6A500D8,6D400CD,AB5115C,2B600D5,95700CA,52F027B,49700D2,6560682," _
& "D4A00D9,EA500CE,6A9157E,5AD00D6,2B600CC,86E137C,92E00D3,C8D1783,C9500DB,D4A00D0," _
& "D8A167F,B5500D7,56A00CD,A5B115D,25D00D5,92D00CA,D2B027A,A9500D2,B550781,6CA00D9," _
& "B5500CE,535157F,4DA00D6,A5B00CB,457037C,52B00D4,A9A0883,E9500DA,6AA00D0,AEA0680," _
& "AB500D7,4B600CD,AAE047D,A5700D5,52600CA,F260379,D9500D1,5B50782,56A00D9,96D00CE," _
& "4DD057F,4AD00D7,A4D00CB,D4D047B,D2500D3,D550883,B5400DA,B6A00CF,95A1680,95B00D8," _
& "49B00CD,A97047D,A4B00D5,B270ACA,6A500DC,6D400D1,AF40681,AB600D9,93700CE,4AF057F," _
& "49700D7,64B00CC,74A037B,EA500D2,6B50883,5AC00DB,AB600CF,96D0580,92E00D8,C9600CD," _
& "D95047C,D4A00D4,DA500C9,755027A,56A00D1,ABB0781,25D00DA,92D00CF,CAB057E,A9500D6," _
& "B4A00CB,BAA047B,A5500D2,55D0983,4BA00DB,A5B00D0,5171680,52B00D8,A9300CD,795047D," _
& "6AA00D4,AD500C9,5B5027A,4B600D2,96E0681,A4E00D9,D2600CE,EA6057E,D5300D5,5AA00CB," _
& "76A037B,96D00D3,4AB0B83,4AD00DB,A4D00D0,D0B1680,D2500D7,D5200CC,DD4057C,B5A00D4," _
& "56D00C9,55B027A,49B00D2,A570782,A4B00D9,AA500CE,B25157E,6D200D6,ADA00CA,4B6137B," _
& "93700D3,49F08C9,49700DB,64B00D0,68A1680,EA500D7,6AA00CC,A6C115C,AAE00D4,92E00CA," _
& "D2E0379,C9600D1,D550781,D4A00D9,DA400CD,5D5057E,56A00D6,A6C00CB,55D047B,52D00D3," _
& "A9B0883,A9500DB,B4A00CF,B6A067F,AD500D7,55A00CD,ABA047C,A5A00D4,52B00CA,B27037A," _
& "69300D1,7330781,6AA00D9,AD500CE,4B5157E,4B600D6,A5700CB,54E047C,D1600D2,E960882," _
& "D5200DA,DAA00CF,6AA167F,56D00D7,4AE00CD,A9D047D,A2D00D4,D1500C9,F250279,D5200D1"
Private Const ylMd0 = "初一初二初三初四初五初六初七初八初九初十十一十二十三十四十五" _
& "十六十七十八十九二十廿一廿二廿三廿四廿五廿六廿七廿八廿九三十 "
Private Const ylMn0 = "正二三四五六七八九十冬臘"
Private Const ylTianGan0 = "甲乙丙丁戊已庚辛壬癸"
Private Const ylDiZhi0 = "子丑寅卯辰巳午未申酉戌亥"
Private Const ylShu0 = "鼠;⑼谬埳唏R羊猴雞狗豬"
'公歷日期轉(zhuǎn)農(nóng)歷
Function GetYLDate(ByVal strDate As String) As String
On Error GoTo aErr
If Not IsDate(strDate) Then Exit Function
Dim setDate As Date, tYear As Integer, tMonth As Integer, tDay As Integer
setDate = CDate(strDate)
tYear = Year(setDate): tMonth = Month(setDate): tDay = Day(setDate)
'如果不是有效有日期,退出
If tYear > 2100 Or tYear < 1900 Then Exit Function
Dim daList() As String * 18, conDate As Date, thisMonths As String
Dim AddYear As Integer, AddMonth As Integer, AddDay As Integer, getDay As Integer
Dim YLyear As String, YLShuXing As String
Dim dd0 As String, mm0 As String, ganzhi(0 To 59) As String * 2
Dim RunYue As Boolean, RunYue1 As Integer, mDays As Integer, i As Integer
'加載2年內(nèi)的農(nóng)歷數(shù)據(jù)
ReDim daList(tYear - 1 To tYear)
daList(tYear - 1) = H2B(Mid(ylData, (tYear - 1900) * 8 + 1, 7))
daList(tYear) = H2B(Mid(ylData, (tYear - 1900 + 1) * 8 + 1, 7))
AddYear = tYear
initYL:
AddMonth = CInt(Mid(daList(AddYear), 15, 2))
AddDay = CInt(Mid(daList(AddYear), 17, 2))
conDate = DateSerial(AddYear, AddMonth, AddDay) '農(nóng)歷新年日期
getDay = DateDiff("d", conDate, setDate) + 1 '相差天數(shù)
If getDay < 1 Then AddYear = AddYear - 1: GoTo initYL
thisMonths = Left(daList(AddYear), 14)
RunYue1 = Val("&H" & Right(thisMonths, 1)) '閏月月份
If RunYue1 > 0 Then '有閏月
thisMonths = Left(thisMonths, RunYue1) & Mid(thisMonths, 13, 1) & Mid(thisMonths, RunYue1 + 1)
End If
thisMonths = Left(thisMonths, 13)
For i = 1 To 13 '計算天數(shù)
mDays = 29 + CInt(Mid(thisMonths, i, 1))
If getDay > mDays Then
getDay = getDay - mDays
Else
If RunYue1 > 0 Then
If i = RunYue1 + 1 Then RunYue = True
If i > RunYue1 Then i = i - 1
End If
AddMonth = i
AddDay = getDay
Exit For
End If
Next
dd0 = Mid(ylMd0, (AddDay - 1) * 2 + 1, 2)
mm0 = Mid(ylMn0, AddMonth, 1) + "月"
For i = 0 To 59
ganzhi(i) = Mid(ylTianGan0, (i Mod 10) + 1, 1) + Mid(ylDiZhi0, (i Mod 12) + 1, 1)
Next i
YLyear = ganzhi((AddYear - 4) Mod 60)
YLShuXing = Mid(ylShu0, ((AddYear - 4) Mod 12) + 1, 1)
If RunYue Then mm0 = "閏" & mm0
GetYLDate = "農(nóng)歷" & YLyear & "(" & YLShuXing & ")年" & mm0 & dd0
aErr:
End Function
'農(nóng)歷轉(zhuǎn)公歷日期
'secondMonth 為真,則天示當(dāng) tMonth 是閏月時,取第二個月
Function GetDate(ByVal tYear As Integer, tMonth As Integer, tDay As Integer, Optional secondMonth As Boolean = False) As String
On Error GoTo aErr
If tYear > 2100 Or tYear < 1899 Or tMonth > 12 Or tMonth < 1 Or tDay > 30 Or tDay < 1 Then Exit Function
Dim thisMonths As String, ylNewYear As Date, toMonth As Integer
Dim mDays As Integer, RunYue1 As Integer, i As Integer
thisMonths = H2B(Mid(ylData, (tYear - 1899) * 8 + 1, 7))
If tDay > 29 + CInt(Mid(thisMonths, tMonth, 1)) Then Exit Function
ylNewYear = DateSerial(tYear, CInt(Mid(thisMonths, 15, 2)), CInt(Mid(thisMonths, 17, 2))) '農(nóng)歷新年日期
thisMonths = Left(thisMonths, 14)
toMonth = tMonth - 1
If tMonth > RunYue1 Or (secondMonth And tMonth = RunYue1) Then toMonth = tMonth
End If
mDays = 0
For i = 1 To toMonth
mDays = mDays + 29 + CInt(Mid(thisMonths, i, 1))
Next
mDays = mDays + tDay
GetDate = ylNewYear + mDays - 1
aErr:
End Function
'將壓縮的陰歷字符還原
Private Function H2B(ByVal strHex As String) As String
Dim i As Integer, i1 As Integer, tmpV As String
Const hStr = "0123456789ABCDEF"
Const bStr = "0000000100100011010001010110011110001001101010111100110111101111"
tmpV = UCase(Left(strHex, 3))
'十六進制轉(zhuǎn)二進制
For i = 1 To Len(tmpV)
i1 = InStr(hStr, Mid(tmpV, i, 1))
H2B = H2B & Mid(bStr, (i1 - 1) * 4 + 1, 4)
Next
H2B = H2B & Mid(strHex, 4, 2)
'十六進制轉(zhuǎn)十進制
H2B = H2B & "0" & CStr(Val("&H" & Right(strHex, 2)))
End Function
在此再次感謝原作者的艱辛勞動和無私奉獻 !
