查看: 1532|回復(fù): 0
單片機(jī)+Max7219兩片連級(jí)第一片正常,第二片交替顯示第一第二片數(shù)據(jù)程序
ID:1053761 發(fā)表于 2022-11-24 16:39 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#define uint  unsigned int
//定義Max7219端口
sbit Max7219_pinCLK = P0^2;
sbit Max7219_pinCS  = P0^1;
sbit Max7219_pinDIN = P0^0;
void Delay_xms(uint x)
uint i,j;
for(i=0;i<x;i++)
  for(j=0;j<112;j++);
//功能:向MAX7219(U3)寫(xiě)入字節(jié)
//入口參數(shù):DATA
//出口參數(shù):無(wú)
//說(shuō)明:
void Write_Max7219_byte(uchar DATA)
            uchar i;
                Max7219_pinCS=0;
            for(i=8;i>=1;i--)
            Max7219_pinCLK=0;
            Max7219_pinDIN=DATA&0x80;
            DATA=DATA<<1;
            Max7219_pinCLK=1;
//功能:向MAX7219寫(xiě)入數(shù)據(jù)
//入口參數(shù):address、dat
//出口參數(shù):無(wú)
//說(shuō)明:
void Write_Max7219(uchar address,uchar dat)
     Max7219_pinCS=0;
         Write_Max7219_byte(address);           //寫(xiě)入地址,即數(shù)碼管編號(hào)
     Write_Max7219_byte(dat);               //寫(xiě)入數(shù)據(jù),即數(shù)碼管顯示數(shù)字
         Max7219_pinCS=1;
//功能:向第二片MAX7219寫(xiě)入數(shù)據(jù)
//出口參數(shù):無(wú)
//說(shuō)明:
void Write_Max7219_2(uchar address,uchar dat)
     Max7219_pinCS=0;
     Max7219_pinCLK=1;
     Write_Max7219_byte(0X00);              //對(duì)第一片執(zhí)行空操作
         Max7219_pinCS=1;
//MAX7219初始化
void Init_MAX7219(void)
Write_Max7219(0x09, 0xff);       //譯碼方式:BCD碼
Write_Max7219_2(0x09, 0xff);       //譯碼方式:BCD碼
Write_Max7219(0x0a, 0x02);       //亮度
Write_Max7219_2(0x0a, 0x02);       //亮度
Write_Max7219(0x0b, 0x07);       //掃描界限;8個(gè)數(shù)碼管顯示
Write_Max7219_2(0x0b, 0x07);       //掃描界限;8個(gè)數(shù)碼管顯示
Write_Max7219(0x0c, 0x01);       //掉電模式:0,普通模式:1
Write_Max7219_2(0x0c, 0x01);       //掉電模式:0,普通模式:1
Write_Max7219(0x0f, 0x00);       //顯示測(cè)試:1;測(cè)試結(jié)束,正常顯示:0
Write_Max7219_2(0x0f, 0x00);       //顯示測(cè)試:1;測(cè)試結(jié)束,正常顯示:0
void main(void)
Delay_xms(50);
Init_MAX7219();
Write_Max7219(1,1);
Write_Max7219(2,2);
Write_Max7219(3,3);
Write_Max7219(4,4);
Write_Max7219(5,5);
Write_Max7219(6,6);
Write_Max7219(7,7);
Write_Max7219(8,8);
Write_Max7219_2(1,8);
Write_Max7219_2(2,7);
Write_Max7219_2(3,6);
Write_Max7219_2(4,5);
Write_Max7219_2(5,4);
Write_Max7219_2(6,3);
Write_Max7219_2(7,2);
Write_Max7219_2(8,1);
