放一下之前寫的程序,單片機IO直接驅(qū)動4位數(shù)碼管,同時具備顯示ds18b20溫度功能,可作為溫度電子溫度計。
單片機源程序如下:
- #include "sys.h"
- #include "temp.h"
- #define FOSC 24000000L //時鐘頻率
- #define tm0_delay 1 //tm0_delay*ms
- //STC老單片機使用
- //#define T1MS (int)(65536-(int)((float)1000*(float)tm0_delay/((float)1/((float)FOSC/(float)1000000/(float)12)))) //12T模式 定時器定時時間自動計算
- //STC1T單片機使用
- #define T1MS (int)(65536-(int)((float)1000*(float)tm0_delay/((float)1/((float)FOSC/(float)1000000/(float)1)))) //1T模式 定時器定時時間自動計算
- //根據(jù)自己硬件的實際硬件連接來設(shè)定
- sbit led_a = P1^3; //數(shù)碼管段引腳 11
- sbit led_b = P1^7; //數(shù)碼管段引腳 7
- sbit led_c = P3^6; //數(shù)碼管段引腳 4
- sbit led_d = P1^0; //數(shù)碼管段引腳 2
- sbit led_e = P1^1; //數(shù)碼管段引腳 1
- sbit led_f = P1^4; //數(shù)碼管段引腳 10
- sbit led_g = P3^5; //數(shù)碼管段引腳 5
- sbit led_dp = P3^7; //數(shù)碼管段引腳 3
- sbit led_w1 = P1^2; //數(shù)碼管位引腳 12
- sbit led_w2 = P1^5; //數(shù)碼管位引腳 9
- sbit led_w3 = P1^6; //數(shù)碼管位引腳 8
- sbit led_w4 = P3^2; //數(shù)碼管位引腳 6
- u8 code led_duan[16]={
- 0X3F,0X06,0x5B,0X4F,0X66,0X6D,0X7D,0X07,0X7F,0X6F,0X77,0X7C,0X39,0X5E,0X79,0X71 //共陰段碼
- //0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8, 0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e //共陽段碼
- u8 code led_wei[8]={
- 0xfe,0xfd,0xfb,0xf7,0xef,0xdF,0xbF,0x7F//共陰位碼
- //0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80//共陽位碼
- };//位碼
- u8 bdata daun_gpio; //段碼 位尋址
- sbit duan_bit7=daun_gpio^7;
- sbit duan_bit6=daun_gpio^6;
- sbit duan_bit5=daun_gpio^5;
- sbit duan_bit4=daun_gpio^4;
- sbit duan_bit3=daun_gpio^3;
- sbit duan_bit2=daun_gpio^2;
- sbit duan_bit1=daun_gpio^1;
- sbit duan_bit0=daun_gpio^0;
- u8 bdata wei_gpio; //位碼 位尋址
- sbit wei_bit3=wei_gpio^3;
- sbit wei_bit2=wei_gpio^2;
- sbit wei_bit1=wei_gpio^1;
- sbit wei_bit0=wei_gpio^0;
- u16 time_clk=0;
- void duan_gpio_out(u8 dat,u8 dat1); //解碼段位
- void disp_num_dat(int dat); //顯示最大數(shù)字0-9999
- void InitTimer0();//定時器0初始化
- u8 disp_num[4]; //數(shù)碼管顯示緩存
- void duan_gpio_out(u8 dat,u8 dat1) //解碼段位,位碼
- daun_gpio=dat;
- wei_gpio=dat1;
- led_a =duan_bit0;
- led_b =duan_bit1;
- led_c =duan_bit2;
- led_d =duan_bit3;
- led_e =duan_bit4;
- led_f =duan_bit5;
- led_g =duan_bit6;
- led_dp=duan_bit7;
- led_w1=wei_bit0;
- led_w2=wei_bit1;
- led_w3=wei_bit2;
- led_w4=wei_bit3;
- void int_start(void) //外部中斷,定時器中斷初始化
- //TMOD = 0x01;
- TMOD=0X00;
- TL0 = T1MS;
- TH0 = T1MS>>8;
- EA = 1;
- ET0 = 1;
- TR0 = 1;
- void disp_num_dat(int dat)//顯示解碼 0-9999
- // disp_num[0]=0x00;
- disp_num[1]=led_duan[(dat%1000)/100];
- disp_num[2]=led_duan[(dat%100)/10];
- disp_num[3]=led_duan[(dat%10)/1];
- void temp_disp(int temp)//溫度顯示
- float tp;
- if(temp< 0) //當(dāng)溫度值為負數(shù)
- disp_num[0]=0x40; //負溫度符號
- //因為讀取的溫度是實際溫度的補碼,所以減1,再取反求出原碼
- temp=temp-1;
- temp=~temp;
- tp=temp;
- temp=tp*0.0625*100+0.5;
- //留兩個小數(shù)點就*100,+0.5是四舍五入,因為C語言浮點數(shù)轉(zhuǎn)換為整型的時候把小數(shù)點
- //后面的數(shù)自動去掉,不管是否大于0.5,而+0.5之后大于0.5的就是進1了,小于0.5的就
- //算由?.5,還是在小數(shù)點后面。
- else
- disp_num[0]=0x76;
- tp=temp;//因為數(shù)據(jù)處理有小數(shù)點所以將溫度賦給一個浮點型變量
- //如果溫度是正的那么,那么正數(shù)的原碼就是補碼它本身
- //算加上0.5,還是在小數(shù)點后面。
- temp=temp/100;
- if(temp<10)
- //disp_num[0]=0x00;
- disp_num[1]=0x00;
- disp_num[2]=0x00;
- disp_num[3]=led_duan[(temp%10)/1];
- if(temp>9)
- if(temp<100)
- disp_num[1]=0x00;
- disp_num[2]=led_duan[(temp%100)/10];
- if(temp>99)
- disp_num[1]=led_duan[(temp%1000)/100];
- void main()
- char mode_dat=0;
- AUXR = AUXR|0x80; // T0, 1T Mode
- int_start();//初始化中斷和定時器
- P1M1 = 0<<0|0<<1|0<<2|0<<3|0<<4|0<<5|0<<6|0<<7;//配置端口模式
- P1M0 = 1<<0|1<<1|1<<2|1<<3|1<<4|1<<5|1<<6|1<<7;//配置端口模式
- P3M1 = 0<<0|0<<1|0<<2|0<<3|0<<4|0<<5|0<<6|0<<7;//配置端口模式
- P3M0 = 0<<0|0<<1|1<<2|1<<3|0<<4|1<<5|1<<6|1<<7;//配置端口模式
- P5M0=0X00;
- P5M1=0X00;
- Ds18b20Init();
- while(1)
- if(time_clk==1000)//溫度調(diào)取周期
- temp_disp(Ds18b20ReadTemp());//讀取解析時間
- time_clk=0;
- void time0(void) interrupt 1//
- static u8 i;
- TL0 = T1MS;
- TH0 = T1MS>>8;
- time_clk++;
- i++;
- i=i&0x03;
- duan_gpio_out(0x00,0xff);//消影
- duan_gpio_out(disp_num[i],led_wei[i]); //刷新LED
Keil代碼下載(附件內(nèi)只有代碼 無原理圖等其他資料,如介意請勿下載):
代碼.7z
(30.37 KB, 下載次數(shù): 30)
2022-12-10 22:24 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
