給你一個(gè)漸亮漸暗開關(guān)燈的示例,相關(guān)變量和端口根據(jù)實(shí)際需要自行調(diào)整。
- #include <reg51.H>
- sbit OUT=P1^0;
- sbit key=P3^4;
- unsigned char num;
- unsigned char count;
- bit sign;
- void delay_10ms()//延時(shí)函數(shù)
- int i,j;
- for(i=0;i<10;i++)
- for(j=0;j<120;j++);
- void Timer0Init() //200微秒@12.000MHz
- TMOD= 0x02; //設(shè)置定時(shí)器模式
- TL0 = 0x38; //設(shè)置定時(shí)初始值
- TH0 = 0x38; //設(shè)置定時(shí)重載值
- TF0 = 0; //清除TF0標(biāo)志
- TR0 = 1; //定時(shí)器0開始計(jì)時(shí)
- EA = 1;
- ET0 = 1;
- void main(void)
- Timer0Init();
- while(1)
- if(!key)
- delay_10ms();
- if(!key)
- sign=~sign;
- while(!key);
- void Timer0Interrupt(void) interrupt 1
- count++;
- if(count>=100)
- count=0;
- if(sign)
- if(num<100)num++;
- else
- if(num>0)num--;
- if(num>count)OUT=0;//暗
- else OUT=1;//亮
復(fù)制代碼 |
