查看: 1401|回復(fù): 2
有大佬解釋一下嗎?jisuanqi.c(145): error C141: syntax error near 'while' jisu...
ID:1058309 發(fā)表于 2022-12-19 20:16 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
#include<intrins.h>
sbit e=P2^3;
sbit rs=P2^4;
sbit rw=P2^0;
sbit busy=P0^7;
char i,j,temp,num,num_1;
long a,b,c;
float a_c,b_c;
uchar flag,fuhao;
uchar code table[]={7,8,9,0,4,5,6,0,1,2,3,0,0,0,0,0};
uchar code table1[]={7,8,9,0x2f-0x30,4,5,6,0x2a-0x30,1,2,3,0x2d-0x30,0x01-0x30,0,0x3d-0x30,0x2b-0x30};
void delay(uchar z)
        uchar y;
        for(z;z>0;z--)
                for(y=0;y<110;y++);
void check()
        do{
                P0=0xFF;
                rs=0;
                rw=1;
        e=0;
        delay(1);
        e=1;
}while(busy==1);
void write_com(uchar com)
        P0=com;
        rs=0;
        rw=0;
        e=0;
        check();
        e=1;
void write_date(uchar date)
        P0=date;
        rs=1;
        rw=0;
        e=0;
        check();
        e=1;
void init()
        num=-1;
        e=1;
        write_com(0X01);
        delay(1);
        write_com(0x38);
        delay(1);
        write_com(0x0c);
        delay(1);
        write_com(0x06);
        delay(1);
        write_com(0x80);
        delay(1);
        write_com(0x01);
        delay(1);
        num_1=0;
        i=0;
        j=0;
        a=0;
        b=0;
        c=0;
        flag=0;
        fuhao=0;
while(P3!=0xf7);
switch(num)
case 12:{write_com(0x01);a=0;b=0;flag=0;fuhao=0;}//????"??"
break;
case 13:
if(flag==0)
a=a*10;
write_date(0x30);
P1=0;
else if(flag==1)//???????
b=b*10;
write_date(0x30);
break;
case 14:{j=1;
if(fuhao==1){write_com(0x80+0x4f);//?????,???????????????
write_com(0x04); //?????????,???????,??????
c=a+b;
while(c!=0)
write_date(0x30+c%10);
c=c/10;
write_date(0x3d); //??"="
else if(fuhao==2){write_com(0x80+0x4f);//???????????????
write_com(0x04); //?????????,???????,??????(?????????,????????)
if(a-b>0)
c=a-b;
c=b-a;
while(c!=0)
c=c/10;
if(a-b<0)
write_date(0x2d);
else if(fuhao==3){write_com(0x80+0x4f);
write_com(0x04);
c=a*b;
while(c!=0)
c=c/10;
write_date(0x3d);
else if(fuhao==4){write_com(0x80+0x4f);
write_com(0x04);
i=0;
c=(long)(((float)a/b)*1000);
while(c!=0)
c=c/10;
i++;
if(i==3)
write_date(0x2e);
if(a/b<=0)
write_date(0x30);
write_date(0x3d);
break;
case 15:{write_date(0x30+table1[num]);flag=1;fuhao=1;}
break;
main()
        init();
                 keyscan();
ID:45879 發(fā)表于 2022-12-20 09:34 | 顯示全部樓層
你這“while(P3!=0xf7);”包含在哪個子函數(shù)里面???
ID:161164 發(fā)表于 2022-12-20 09:49 | 顯示全部樓層
代碼缺失了一部分
從那抄來的?
