#include <REGX52.H>
sbit key1 = P2^4;
sbit key2 = P2^5;
sbit key3 = P2^6;
sbit key4 = P2^7;
unsigned char sz[]={0x10,0x00,0x78,0x02,0x12,0x19,0x30,0x24,0x79,0x40};//數(shù)碼管值
void Timer0Init(void) //1毫秒@12.000MHz
TMOD &= 0xF0; //設(shè)置定時器模式
TMOD |= 0x01; //設(shè)置定時器模式
TL0 = 0x30; //設(shè)置定時初值
TH0 = 0xf8; //設(shè)置定時初值
TF0 = 0; //清除TF0標志
TR0 = 1; //定時器0開始計時
EA=1; //定時器總開關(guān)
ET0=1; //定時器0開關(guān)
bit keydq = 1;//按鍵當(dāng)前值
bit bc = 1;//保存前一次的值
unsigned char i; //數(shù)值變化
P2=0xfe;//矩陣按鍵選擇P2.0低電平
Timer0Init();
if(key2==0)
P0=0X55;
if(keydq != bc) //當(dāng)前值與前一次不一樣
if(bc == 0)
i++;
if(i >= 9)
i=0;
P1=sz[i];
bc=keydq;
void time0() interrupt 1
unsigned char keybuf=0xff;
P2=0XFE;
keybuf=(keybuf<<1) | key2;
if(keybuf==0x00)
keydq=0;
else if(keybuf==0xff)
keydq=1;
程序如上在main中將keydq換成key1則按鍵正常使用,求大佬幫看看哪里寫的有問題
