查看: 1684|回復(fù): 3
單片機數(shù)碼管顯示電路問題 加上三極管顯示就不正常
ID:693230 發(fā)表于 2022-12-31 14:46 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
為什么加上三極管顯示就不正常,一個一個顯示,但去掉三極管就顯示正常了
單片機源程序如下:
  1. #include<reg51.h>
  2. #define uin unsigned int
  4. unsigned char code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
  5. unsigned char code tablet[]={0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10,0x08,0x03,0x46,0x21,0x06,0x0e};
  6. unsigned char code show[]={0x70,0xB0,0xD0,0xE0};//三極管換成0x10,0x20,0x40,0x80
  7. unsigned int count=0;
  8. unsigned char group[10]={0};
  9. sbit P3_2=P3^2;
  10. sbit P3_4=P3^4;
  11. sbit P3_5=P3^5;
  12. sbit P3_6=P3^6;
  13. sbit P3_7=P3^7;
  14. uin math,i,j,k,g,special;
  15. uchar p=0,o=0,b=0,m=0,t=0,h=0,q=1;
  16. void delay(unsigned int time)
  17. {
  18.        unsigned int j=0;
  19.                    for(;time>0;time--)
  20.               for(j=0;j<100;j++);
  21. }
  22. key1() interrupt 2{
  23.         if(m==0){
  24.           math=count;
  25.     group[p]=math;
  26.     p++;
  27.           o++;
  28.     if(p>=10) m=1;
  29.                 }}
  30. software() interrupt 1{
  31.
  32.           t++;
  33.                 if(t==2)
  34.                 {count++;t=0;}
  35.     TH0=0x3c;
  36.     TL0=0xb0;
  37.                 }
  38. void clr()
  39. { uchar c;
  40.    for(c=0;c<10;c++)
  41.    group[c]=0;}
  42.
  43. void main(){
  44.
  45.     TMOD=0x01;
  46.     TH0=0x3c;
  47.     TL0=0xb0; P3_2=1;
  48. IT0=1;EX0=1;EA=1;
  49. IT1=1;EX1=1;
  50. TR0=0; ET0=1;
  51. while(1)
  52.          { P3_2=1;
  53.
  54.                           if(b==0){
  55.          for(i=0;i<4;i++)
  56.                   { if(i==0)
  57.                                 {P2=show[i];
  58.                                  P0=table[p];
  59.                                 }
  60.                                 else if(i==1)
  61.                                 {P2=show[i];
  62.                                  P0=table[count/100];
  63.
  64.                                 }
  65.                else if(i==2)
  66.         {P2=show[i];
  67.          P0=tablet[count/10];
  68.
  69.                                 }
  70.                                 else  if(i==3)
  71.                                 {P2=show[i];
  72.                                  P0=table[count%10];
  73.                                 }
  74.                          delay(20);}}
  75.
  76.                  if(P3_7==0)
  77.      {delay(10);
  78.                          if(P3_7==0)
  79.        {TR0=1;b=0;m=0;
  80.                                 }
  81.
  82.   if(P3_4==0)
  83.      {delay(10);
  84.                          if(P3_4==0)
  85.        {TR0=0;
  86.                                 }
  87.
  88.                  if(P3_5==0)
  89.                   {delay(10);
  90.                          if(P3_5==0)
  91.                           { p=0;
  92.                                  b=1;
  93.                                  TR0=0;
  94.                                  count=0;
  95.                                 if(b==1){
  96.                                  for(k=0;k<o;k++)
  97.                                  { special=group[p];
  98.                                         for(g=0;g<20;g++)
  99.           {
  100.                                         for(i=0;i<4;i++)
  101.                                         { if(i==0)
  102.                                 {P2=show[i];
  103.                                  P0=table[q];
  104.                                 delay(10);
  105.                                 }
  106.                else if(i==1)
  107.         {P2=show[i];
  108.          P0=table[special/100];
  109.         delay(10);
  110.                                 }
  111.                                 else if(i==2)
  112.                                 {P2=show[i];
  113.                                  P0=tablet[special/10%10];
  114.          delay(10);}
  115.                                 else if(i==3)
  116.                                 {P2=show[i];
  117.                                  P0=table[special%10];
  118.          delay(10);}
  119.
  120.                                 }}
  121.                           p++;
  122.                                 q++;
  123.                                 if(p==o)
  124.                                         {b=0;count=0;p=0;i=0;k=0;special=0;o=0;q=1;clr();P3_2=0;delay(10);}
  125.                           }
  126.                          }}
  127.      }
  128.           if(P3_6==0)
  129.      {delay(10);
  130.                          if(P3_6==0)
  131.        { P3_2=0;
  132.                                  delay(15);
  133.
  134.                                  TR0=0;
  135.                                 count=0;b=0;p=0;i=0;m=0;special=0;q=1;clr();
  136.
  137.                                 }
  138.                                 }
  139.                                 }
  140.                         }
  141.                 }
  142.         }
原理圖.7z (33.08 KB, 下載次數(shù): 8)
ID:88256 發(fā)表于 2022-12-31 17:55 | 只看該作者
三極管起反相作用的
ID:94031 發(fā)表于 2022-12-31 19:47 | 只看該作者
加三極管會使信號倒相。
ID:332444 發(fā)表于 2022-12-31 20:00 | 只看該作者
不討論程序問題,就單三極管控制來說幾個10K的電阻是多余的,從圖上色點看似乎是共陽數(shù)碼管,而控制似乎是低電平的,哪就是要用一個非門轉(zhuǎn)換,可以用PNP也可以用NPN,也可以非門電路。
