- #include "remote.h"
- #include "delay.h"
- #include "usart.h"
- //紅外遙控初始化
- //設(shè)置IO以及定時(shí)器4的輸入捕獲
- void Remote_Init(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- NVIC_InitTypeDef NVIC_InitStructure;
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- TIM_ICInitTypeDef TIM_ICInitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE); //使能PORTB時(shí)鐘
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4,ENABLE); //TIM4 時(shí)鐘使能
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PB9 輸入
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //上拉輸入
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- GPIO_SetBits(GPIOB,GPIO_Pin_9); //初始化GPIOB.9
- TIM_TimeBaseStructure.TIM_Period = 10000; //設(shè)定計(jì)數(shù)器自動重裝值 最大10ms溢出
- TIM_TimeBaseStructure.TIM_Prescaler =(72-1); //預(yù)分頻器,1M的計(jì)數(shù)頻率,1us加1.
- TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //設(shè)置時(shí)鐘分割:TDTS = Tck_tim
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上計(jì)數(shù)模式
- TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure); //根據(jù)指定的參數(shù)初始化TIMx
- TIM_ICInitStructure.TIM_Channel = TIM_Channel_4; // 選擇輸入端 IC4映射到TI4上
- TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; //上升沿捕獲
- TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
- TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; //配置輸入分頻,不分頻
- TIM_ICInitStructure.TIM_ICFilter = 0x03;//IC4F=0011 配置輸入濾波器 8個(gè)定時(shí)器時(shí)鐘周期濾波
- TIM_ICInit(TIM4, &TIM_ICInitStructure);//初始化定時(shí)器輸入捕獲通道
- TIM_Cmd(TIM4,ENABLE ); //使能定時(shí)器4
- NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn; //TIM3中斷
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; //先占優(yōu)先級0級
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //從優(yōu)先級3級
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
- NVIC_Init(&NVIC_InitStructure); //根據(jù)NVIC_InitStruct中指定的參數(shù)初始化外設(shè)NVIC寄存器
- TIM_ITConfig( TIM4,TIM_IT_Update|TIM_IT_CC4,ENABLE);//允許更新中斷 ,允許CC4IE捕獲中斷
- //遙控器接收狀態(tài)
- //[7]:收到了引導(dǎo)碼標(biāo)志
- //[6]:得到了一個(gè)按鍵的所有信息
- //[5]:保留
- //[4]:標(biāo)記上升沿是否已經(jīng)被捕獲
- //[3:0]:溢出計(jì)時(shí)器
- u8 RmtSta=0;
- u16 Dval; //下降沿時(shí)計(jì)數(shù)器的值
- u32 RmtRec=0; //紅外接收到的數(shù)據(jù)
- u8 RmtCnt=0; //按鍵按下的次數(shù)
- //定時(shí)器4中斷服務(wù)程序
- void TIM4_IRQHandler(void)
- if(TIM_GetITStatus(TIM4,TIM_IT_Update)!=RESET)
- if(RmtSta&0x80) //上次有數(shù)據(jù)被接收到了
- RmtSta&=~0X10; //取消上升沿已經(jīng)被捕獲標(biāo)記
- if((RmtSta&0X0F)==0X00)RmtSta|=1<<6; //標(biāo)記已經(jīng)完成一次按鍵的鍵值信息采集
- if((RmtSta&0X0F)<14)RmtSta++;
- else
- RmtSta&=~(1<<7); //清空引導(dǎo)標(biāo)識
- RmtSta&=0XF0; //清空計(jì)數(shù)器
- if(TIM_GetITStatus(TIM4,TIM_IT_CC4)!=RESET)
- if(RDATA)//上升沿捕獲
- TIM_OC4PolarityConfig(TIM4,TIM_ICPolarity_Falling); //CC4P=1 設(shè)置為下降沿捕獲
- TIM_SetCounter(TIM4,0); //清空定時(shí)器值
- RmtSta|=0X10; //標(biāo)記上升沿已經(jīng)被捕獲
- }else //下降沿捕獲
- Dval=TIM_GetCapture4(TIM4); //讀取CCR4也可以清CC4IF標(biāo)志位
- TIM_OC4PolarityConfig(TIM4,TIM_ICPolarity_Rising); //CC4P=0 設(shè)置為上升沿捕獲
- if(RmtSta&0X10) //完成一次高電平捕獲
- if(RmtSta&0X80)//接收到了引導(dǎo)碼
- if(Dval>300&&Dval<800) //560為標(biāo)準(zhǔn)值,560us
- RmtRec<<=1; //左移一位.
- RmtRec|=0; //接收到0
- }else if(Dval>1400&&Dval<1800) //1680為標(biāo)準(zhǔn)值,1680us
- RmtRec|=1; //接收到1
- }else if(Dval>2200&&Dval<2600) //得到按鍵鍵值增加的信息 2500為標(biāo)準(zhǔn)值2.5ms
- RmtCnt++; //按鍵次數(shù)增加1次
- RmtSta&=0XF0; //清空計(jì)時(shí)器
- }else if(Dval>4200&&Dval<4700) //4500為標(biāo)準(zhǔn)值4.5ms
- RmtSta|=1<<7; //標(biāo)記成功接收到了引導(dǎo)碼
- RmtCnt=0; //清除按鍵次數(shù)計(jì)數(shù)器
- RmtSta&=~(1<<4);
- TIM_ClearITPendingBit(TIM4,TIM_IT_Update|TIM_IT_CC4);
- //處理紅外鍵盤
- //返回值:
- // 0,沒有任何按鍵按下
- //其他,按下的按鍵鍵值.
- u8 Remote_Scan(void)
- u8 sta=0;
- u8 t1,t2;
- if(RmtSta&(1<<6))//得到一個(gè)按鍵的所有信息了
- t1=RmtRec>>24; //得到地址碼
- t2=(RmtRec>>16)&0xff; //得到地址反碼
- if((t1==(u8)~t2)&&t1==REMOTE_ID)//檢驗(yàn)遙控識別碼(ID)及地址
- t1=RmtRec>>8;
- t2=RmtRec;
- if(t1==(u8)~t2)sta=t1;//鍵值正確
- if((sta==0)||((RmtSta&0X80)==0))//按鍵數(shù)據(jù)錯誤/遙控已經(jīng)沒有按下了
- RmtSta&=~(1<<6);//清除接收到有效按鍵標(biāo)識
- return sta;
- #include "led.h"
- #include "key.h"
- #include "sys.h"
- #include "lcd.h"
- int main(void)
- u8 key;
- u8 t=0;
- u8 *str=0;
- delay_init(); //延時(shí)函數(shù)初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置中斷優(yōu)先級分組為組2:2位搶占優(yōu)先級,2位響應(yīng)優(yōu)先級
- uart_init(115200); //串口初始化為115200
- LED_Init(); //LED端口初始化
- LCD_Init();
- KEY_Init();
- Remote_Init(); //紅外接收初始化
- POINT_COLOR=RED; //設(shè)置字體為紅色
- LCD_ShowString(30,50,200,16,16,"WarShip STM32");
- LCD_ShowString(30,70,200,16,16,"REMOTE TEST");
- LCD_ShowString(30,90,200,16,16,"ATOM@ALIENTEK");
- LCD_ShowString(30,110,200,16,16,"2015/1/15");
- LCD_ShowString(30,130,200,16,16,"KEYVAL:");
- LCD_ShowString(30,150,200,16,16,"KEYCNT:");
- LCD_ShowString(30,170,200,16,16,"SYMBOL:");
- while(1)
- key=Remote_Scan();
- if(key)
- LCD_ShowNum(86,130,key,3,16); //顯示鍵值
- LCD_ShowNum(86,150,RmtCnt,3,16); //顯示按鍵次數(shù)
- switch(key)
- case 0:str="ERROR";break;
- case 162:str="POWER";break;
- case 98:str="UP";break;
- case 2:str="PLAY";break;
- case 226:str="ALIENTEK";break;
- case 194:str="RIGHT";break;
- case 34:str="LEFT";break;
- case 224:str="VOL-";break;
- case 168:str="DOWN";break;
- case 144:str="VOL+";break;
- case 104:str="1";break;
- case 152:str="2";break;
- case 176:str="3";break;
- case 48:str="4";break;
- case 24:str="5";break;
- case 122:str="6";break;
- case 16:str="7";break;
- case 56:str="8";break;
- case 90:str="9";break;
- case 66:str="0";break;
- case 82:str="DELETE";break;
- LCD_Fill(86,170,116+8*8,170+16,WHITE); //清楚之前的顯示
- LCD_ShowString(86,170,200,16,16,str); //顯示SYMBOL
- }else delay_ms(10);
- t++;
- if(t==20)
- t=0;
- LED0=!LED0;
Keil代碼下載(只有代碼不含其他任何資料,非原創(chuàng)):
紅外遙控實(shí)驗(yàn).7z
(225.98 KB, 下載次數(shù): 47)
2023-1-4 15:27 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
