查看: 1228|回復(fù): 0
GD32單片機(jī)配置兩個(gè)定時(shí)器中斷時(shí)只有一個(gè)定時(shí)器會(huì)工作,該怎么修改程序呢?
ID:1040297 發(fā)表于 2023-1-25 21:53 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
timer.c
#include "timer.h"
#include "gd32f10x.h"
#include "usart0.h"
#include "systick.h"
#include "led.h"
extern unsigned int seconds;
void timer5_init(void)
          timer_parameter_struct timer_initpara;
    rcu_periph_clock_enable(RCU_TIMER5);
    timer_deinit(TIMER5);
    timer_struct_para_init(&timer_initpara);
    timer_initpara.prescaler         = 11999;             // 主頻率120M
    timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
    timer_initpara.counterdirection  = TIMER_COUNTER_UP;
    timer_initpara.period            = 9;
    timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
    timer_init(TIMER5, &timer_initpara);
    timer_interrupt_flag_clear(TIMER5, TIMER_INT_FLAG_UP);
    timer_interrupt_enable(TIMER5, TIMER_INT_UP);
          timer_auto_reload_shadow_enable(TIMER5);
    timer_enable(TIMER5);
    nvic_irq_enable(TIMER5_IRQn, 2, 3);   // 配置中斷優(yōu)先級
void TIMER5_IRQHandler(void)
        if(timer_interrupt_flag_get(TIMER5, TIMER_INT_FLAG_UP))
                if(seconds==100)
                        seconds=0;
                        led1=!led1;
                seconds++;
void timer6_init(void)
    rcu_periph_clock_enable(RCU_TIMER6);
    timer_deinit(TIMER6);
    timer_init(TIMER6, &timer_initpara);
    timer_interrupt_flag_clear(TIMER6, TIMER_INT_FLAG_UP);
    timer_interrupt_enable(TIMER6, TIMER_INT_UP);
    timer_enable(TIMER6);
    nvic_irq_enable(TIMER6_IRQn, 0, 1);
void TIMER6_IRQHandler(void)
        if(timer_interrupt_flag_get(TIMER6, TIMER_INT_FLAG_UP))
                if(seconds==100)
                        seconds=0;
                        led2=!led2;
                seconds++;
timer.h
#ifndef _TIMER_H
#define _TIMER_H
void timer5_init(void);
void TIMER5_IRQHandler(void);
void timer6_init(void);
void TIMER6_IRQHandler(void);
#endif
主函數(shù)
int main(void)
        rcu_ahb_clock_config(RCU_AHB_CKSYS_DIV1);//AHB主頻是1分頻
        systick_config();//系統(tǒng)主頻108MHZ,采用外部晶振,由兩個(gè)宏決定(__SYSTEM_CLOCK_108M_PLL_HXTAL與HXTAL_VALUE)
        LED_Init();
  USART0_init(9600U);  //串口0    初始化函數(shù)
        timer5_init();
        timer6_init();
        nvic_priority_group_set(NVIC_PRIGROUP_PRE2_SUB2);
