設(shè)計(jì)了四套驅(qū)動(dòng)方案:1、154+595驅(qū)動(dòng) 2、154+P口驅(qū)動(dòng) 3、595驅(qū)動(dòng) 4、單片機(jī)P口驅(qū)動(dòng)
程序?yàn)槲淖肿笠骑@示
供初學(xué)者參考
51hei錄屏20230128052222 00_00_00-00_00_30.gif (872.76 KB, 下載次數(shù): 32)
2023-1-28 05:24 上傳
2023-1-28 05:19 上傳
2023-1-28 05:19 上傳
2023-1-28 05:19 上傳
2023-1-28 05:19 上傳
單片機(jī)16×16點(diǎn)陣(154+595驅(qū)動(dòng))源程序如下:
- #include <intrins.h> //函數(shù),應(yīng)用于程序設(shè)計(jì)
- #include <reg52.h> //單片機(jī)頭文件
- /**********接口說(shuō)明**********/
- sbit SER=P3^0; //DS 第14腳 串行數(shù)據(jù)輸入
- sbit SRCLK=P3^1; //SH_CP 第11腳 數(shù)據(jù)輸入時(shí)鐘線
- sbit LATCH=P3^2; //ST_CP 第12腳 輸出存儲(chǔ)器鎖存時(shí)鐘線
- sbit OE=P3^3; //OE 第13腳 輸出有效,低電平有效
- /**********全局變量**********/
- unsigned int word=1; //數(shù)據(jù)位指針
- unsigned char column=0; //列數(shù),最大數(shù)16
- unsigned char time=5; //走字速度,可修改
- unsigned char code segout[8]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80}; //列掃描數(shù)組
- unsigned char code tab[]=
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//空白位置
- /*以下文字開(kāi)始*/
- 0x00,0x01,0x00,0x02,0x03,0xEC,0x02,0x20,0x02,0x20,0x02,0x28,0xFE,0x26,0x12,0x20,0x12,0x28,0x12,0x26,0x12,0x20,0x13,0xE0,0x10,0x08,0x10,0x07,0x00,0x00,0x00,0x00,//點(diǎn),1
- 0x00,0x00,0x7F,0xFF,0x40,0x10,0x44,0x08,0x5B,0x10,0x60,0xE0,0x10,0x10,0x13,0x10,0x1D,0x10,0xF1,0x10,0x17,0xFF,0x11,0x10,0x11,0x10,0x11,0x10,0x10,0x10,0x00,0x00,0x00,0x00,//陣,2
- 0x08,0x20,0x06,0x20,0x40,0x7E,0x31,0x80,0x00,0x01,0x7F,0xE2,0x40,0x0C,0x4F,0xF0,0x40,0x08,0x7F,0xE4,0x00,0x00,0x1F,0xE2,0x00,0x01,0xFF,0xFE,0x00,0x00,0x00,0x00,//測(cè),3
- 0x02,0x00,0x02,0x00,0x42,0x00,0x33,0xFC,0x00,0x08,0x09,0x14,0x09,0x06,0x09,0xFC,0x09,0x08,0x09,0x08,0xFF,0x80,0x08,0x70,0x88,0x0C,0x68,0x02,0x08,0x0F,0x00,0x00,0x00,0x00,//試,4
- 0x24,0x10,0x24,0x60,0x25,0x80,0x7F,0xFF,0xC4,0x80,0x44,0x60,0x00,0x02,0x7C,0x92,0x44,0x92,0x44,0x92,0x44,0xFE,0x44,0x92,0x44,0x92,0x7C,0x92,0x00,0x82,0x00,0x00,0x00,0x00,//程,5
- 0x00,0x02,0x00,0x0C,0x3F,0xF0,0x20,0x00,0x20,0x80,0x20,0x80,0x28,0x80,0xA8,0x82,0x6A,0x81,0x29,0xFE,0x2A,0x80,0x2C,0x80,0x28,0x80,0x20,0xA0,0x20,0xC0,0x00,0x00,0x00,0x00,//序,6
- /*以上文字結(jié)束*/
- 0xBB,//結(jié)束碼
- void Delay(unsigned char ms)
- unsigned char x,y;
- for(x=ms;x>0;x--)
- for(y=124;y>0;y--);
- void SendByte(unsigned char dat)
- unsigned char i;
- for(i=0;i<8;i++)
- if(dat&0x01==1)
- SER=1;
- else
- SER=0;
- dat>>=1;
- SRCLK=0;
- _nop_();
- _nop_(); //空指令
- SRCLK=1;
- void Out595(void) //給出上升沿
- LATCH=0; //輸出存儲(chǔ)器鎖存時(shí)鐘線置0
- _nop_();
- _nop_(); //空指令
- LATCH=1; //輸出存儲(chǔ)器鎖存時(shí)鐘線至1,給上升沿
- void Send_Rank(unsigned int dat)
- SendByte(tab[2*dat-1]); //09~16行數(shù)據(jù)選擇
- SendByte(tab[2*dat-2]); //01~08行數(shù)據(jù)選擇
- void main()
- while(1) //無(wú)限循環(huán)
- unsigned char temp=0;
- for(temp=time;temp>0;temp--) //循環(huán)掃描,可修改走字速度
- for(column=0;column<16;column++) //循環(huán)掃描16列
- P2=column; //列掃描程序
- Send_Rank(word); //行數(shù)據(jù)顯示程序
- Out595(); //給出上升沿
- OE=0; //74HC595輸出有效
- Delay(2);
- OE=1; //消隱
- word++; //數(shù)據(jù)位指針加1,準(zhǔn)備顯示下一行數(shù)據(jù)
- if(tab[2*word-2]==0xBB) //判斷下一個(gè)顯示數(shù)據(jù)是否為結(jié)束碼,若是往下執(zhí)行
- word=1; //行數(shù)據(jù)重新賦值
- else
- word-=16; //行數(shù)據(jù)返回前16行
- word++; //行數(shù)據(jù)加1,達(dá)到顯示數(shù)據(jù)左移目的
2023-1-28 12:33 上傳
Keil代碼與Proteus8.15版本的仿真下載(注意:不能兼容其他版本 只能用8.15打開(kāi)):
點(diǎn)陣.7z
(338.8 KB, 下載次數(shù): 53)
2023-1-28 12:43 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
