查看: 3407|回復(fù): 12
求助:網(wǎng)上找來的單片機(jī)程序,想添加控制繼電器功能
ID:816562 發(fā)表于 2023-2-12 19:47 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
    網(wǎng)上找來的程序,基于51單片機(jī)的倒計時裝置,定時時間到后蜂鳴器鳴叫,倒計時結(jié)束,想添加一個控制繼電器功能,就是計時開始繼電器吸合,計時結(jié)束繼電器釋放,不知道怎么加,請各位大佬幫幫忙,在此謝過了!
    以下是源碼:
//        Copyright (C) 2020 Jobcrazy
//        All rights reserved
#include <reg52.h>
//Button registers
sbit Step1m = P3^6;  //按鍵3,+1分鐘
sbit Step10m = P3^5;  //按鍵2,+10分鐘
sbit Step1h = P3^4;  //按鍵1,+1小時
sbit StepStart = P3^7;  //按鍵4,開始計時
//Beep register
sbit Beep = P1^6;  //蜂鳴器
//Relay
sbit Relay = P1^7;  //繼電器
//Time Led Dot register
sbit TIME_DOT = P1^5;  //數(shù)碼管":"
//Time Led Segment register
sbit ShuMa_Duan_0 = P1^0;  //數(shù)碼管1
sbit ShuMa_Duan_1 = P1^1;  //數(shù)碼管2
sbit ShuMa_Duan_2 = P1^2;  //數(shù)碼管3
sbit ShuMa_Duan_3 = P1^3;  //數(shù)碼管4
//Initial settings
#define DEFAULT_HOUR 00
#define DEFAULT_MINUTE 00
#define DEFAULT_SECOND 00
volatile int Hour = DEFAULT_HOUR;
volatile int Minute = DEFAULT_MINUTE;
volatile int Second = DEFAULT_SECOND;
//Led Number Definitions
code unsigned char ShuMa_Data[10] = {0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92,0x82,0xF8,0x80,0x90};
//Led Number Indexes
volatile int Shi_Left = 0;
volatile int Ge_Left = 0;
volatile int Shi_Right = 0;
volatile int Ge_Right = 0;
//Delay 1 minisecond
void Delay_1ms( int i )
    for( ; i > 0; --i )
        int j = 0;
        for( ; j < 110; ++j )
//Timer Settings
void Init_Timer()
    TMOD = 0x11; //Using timer 0 and timer 1
    TH0  = 0xB8;
    TL0  = 0x00;  //Timer0 = 20ms
    TH1  = 0xB8;
    TL1  = 0x00;  //Timer1 = 20ms
    TR0  = 0x01;  //Enable Timer 0
    TR1  = 0x00;
//Enable Timer
void Init_Interrupt()
    ET0 = 1;
    ET1 = 1;
    EA = 1;
//Show Number on the Timer Led
void  ShuMa(unsigned char ShuMa_Wei, unsigned char ShuMa_Index)
    P2 = ShuMa_Data[ShuMa_Index];
    if( ShuMa_Wei == 0 )
        ShuMa_Duan_0 = 0;
        ShuMa_Duan_1 = 1;
        ShuMa_Duan_2 = 1;
        ShuMa_Duan_3 = 1;
    else if( ShuMa_Wei == 1 )
        ShuMa_Duan_0 = 1;
        ShuMa_Duan_1 = 0;
        ShuMa_Duan_2 = 1;
        ShuMa_Duan_3 = 1;
    else if( ShuMa_Wei == 2 )
        ShuMa_Duan_0 = 1;
        ShuMa_Duan_1 = 1;
        ShuMa_Duan_2 = 0;
        ShuMa_Duan_3 = 1;
    else if( ShuMa_Wei == 3 )
        ShuMa_Duan_0 = 1;
        ShuMa_Duan_1 = 1;
        ShuMa_Duan_2 = 1;
        ShuMa_Duan_3 = 0;
    //We must delay 1ms here, or else the Led will not show a correct number
    Delay_1ms(1);
//Convert the time to a displayable format
void CalcSecond()
    if( 0 < Hour )
        Shi_Left = Hour / 10;
        Ge_Left = Hour % 10;
        Shi_Right = Minute / 10;
        Ge_Right =  Minute % 10;
        Shi_Left = Minute / 10;
        Ge_Left = Minute % 10;
        Shi_Right = Second / 10;
        Ge_Right = Second % 10;
//Counter Timer
void Interrupt_Timer_0() interrupt 1
    static int Counter = 0;
    TH0 = 0xB8;
    TL0 = 0x00;
    ++Counter;
    if( 49 < Counter )
        //Ths scope will run 1 time per second
        Counter = 0;
        TIME_DOT = ~TIME_DOT;
        Second--;
        //Let's see how long time is left
        if( Second < 0 )
            Second = 59;
            Minute -= 1;
        if( Minute < 0 )
            if( 0 < Hour )
                Hour--;
                Minute = Second = 59;
                Hour = Minute = Second = 0;
                TR0 = 0; //Disable counter timer
                TR1 = 1; //Enable Beep Timer
        CalcSecond();
//Beep timer
void Interrupt_Timer_1() interrupt 3
    static int n = 0, Counter = 0;
    TH1 = 0xB8;
    TL1 = 0x00;
    ++Counter;
    if( Counter < 10 )
        Beep = 0;
    else if( Counter < 30 )
        Beep = 1;
    else if( Counter > 49 )
        Counter = 0;
        n++;
        if( n >= 5 )
            n = 0;
            //Disable two timers
            TR0 = 0;
            TR1 = 0;
//Covert time to be recognizable
void formatTime()
    if( Minute >= 60 )
        Minute = 0;
        Hour = Hour + 1;
    if( Hour >= 99 )
        Hour = 0;
        Minute = 0;
        Second = 0;
    CalcSecond();
    //To avoid long press
    int Pressed = 0;
    //Light Timer Dot
    TIME_DOT = 0;
    //Turn Off Beep
    Beep = 1;
    //Make P3 output high-level signal
    P3 = 0xFF;
    CalcSecond();
    //Infinite loop
        formatTime();
        //Show time the led screen
        ShuMa( 0, Shi_Left );
        ShuMa( 1, Ge_Left );
        ShuMa( 2, Shi_Right );
        ShuMa( 3, Ge_Right );
        if( 0 == TR0 && 0 == TR1 ) //If timer is not running
            if( 0 == Step1m && 0 == Pressed )
                //If Step1m button is pressed down
                Pressed = 1;
                Minute = Minute + 1;
            else if( 0 == Step10m && 0 == Pressed )
                //If Step10m button is pressed down
                Pressed = 1;
                Minute = Minute + 10;
            else if( 0 == Step1h && 0 == Pressed )
                //If Step1h button is pressed down
                Pressed = 1;
                Hour = Hour + 1;
            else if( 0 == StepStart && 0 == Pressed )
                //If StepStart button is pressed down
                Pressed = 1;
                if ( 0 != Hour || 0 != Minute || 0 != Second )
                    Init_Timer();
                    Init_Interrupt();
                if( 1 == Step1m && 1 == Step10m && 1 == Step1h && 1 == StepStart )
                    //If no button is pressed down
                    Pressed = 0;
Timer-master.zip
46.24 KB, 下載次數(shù): 6
ID:996773 發(fā)表于 2023-2-13 09:14 | 只看該作者
搞匯編的我真心看不懂這c語言,天書一樣,倒計時是很簡單的程序,用c寫怎么這么長?對于匯編來說,只要在蜂鳴器不工作的時候加一條clr p0.1或者0.2任意端口拉低就可以用這個口驅(qū)動繼電器了
ID:161164 發(fā)表于 2023-2-13 09:30 | 只看該作者
  1. //...
  2. sbit Relay = Px^y;
  3. void main()
  4. {
  5. //...
  6. while(1)
  7. {
  8. //...
  9. Relay = !TR0;
  10. }
  11. }
ID:816562 發(fā)表于 2023-2-13 19:16 來自觸屏版 | 只看該作者
lkc8210 發(fā)表于 2023-2-13 09:30
萬分感謝,我通過您的代碼問題已經(jīng)解決!
ID:492633 發(fā)表于 2023-2-13 21:17 來自觸屏版 | 只看該作者
蜂鳴器是0啟動1關(guān)閉,那你可以用npn型三極管直接驅(qū)動繼電器,當(dāng)蜂鳴器不響時繼電器導(dǎo)通,蜂鳴器響時繼電器關(guān)閉
ID:579397 發(fā)表于 2023-2-13 23:05 | 只看該作者
                    Init_Timer();
                    Init_Interrupt();
Relay=~Relay;
Relay=~Relay;
                    Pressed = 0;
ID:579397 發(fā)表于 2023-2-13 23:08 | 只看該作者
我也做了一個,用18650電池的
kingzr00 發(fā)表于 2023-2-13 19:16
數(shù)碼管沒有消隱
ID:816562 發(fā)表于 2023-2-14 00:54 來自觸屏版 | 只看該作者
3wjkdhus 發(fā)表于 2023-2-13 21:17
蜂鳴器是0啟動1關(guān)閉,那你可以用npn型三極管直接驅(qū)動繼電器,當(dāng)蜂鳴器不響時繼電器導(dǎo)通,蜂鳴器響時繼電器 ...
感謝你提供的解決思路,蜂鳴器是計時結(jié)束時響5聲,如果用蜂鳴器的引腳驅(qū)動繼電器,當(dāng)計時結(jié)束時就會重復(fù)開關(guān)5次,有可能對電氣造成傷害,不過現(xiàn)在問題已經(jīng)解決了!
ID:816562 發(fā)表于 2023-2-14 00:55 來自觸屏版 | 只看該作者
hi等你 發(fā)表于 2023-2-13 09:14
搞匯編的我真心看不懂這c語言,天書一樣,倒計時是很簡單的程序,用c寫怎么這么長?對于匯編來說,只要在蜂 ...
感謝,問題已經(jīng)解決了!
ID:816562 發(fā)表于 2023-2-16 23:40 來自觸屏版 | 只看該作者
已經(jīng)組裝好了,達(dá)到預(yù)期效果!
ID:816562 發(fā)表于 2023-2-16 23:42 來自觸屏版 | 只看該作者
完成效果
ID:816562 發(fā)表于 2023-2-18 15:49 來自觸屏版 | 只看該作者
405616736 發(fā)表于 2023-2-13 23:05
                    Init_Timer() ...
謝謝!
