查看: 1509|回復(fù): 0
基于STM32的(IIC OLED 顯示)+矩陣按鍵串口打印程序
ID:316613 發(fā)表于 2023-2-16 15:23 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include "stm32f10x.h"
#include "oled.h"
#include "sys.h"
#include "lnterface.h"
#include "bmp.h"
#include "24cxx.h"
#include "led.h"
#include "key.h"
#include "usmart.h"
#include "key4_4.h"
#include "usart.h"
unsigned int year=2019,month=8,day=8;//年月日
unsigned int nzs=12,nzf=22;//鬧鐘時(shí) 鬧鐘分
//unsigned int time=5,branch=8;
//unsigned int second=5,second2=5;//時(shí)分秒
unsigned int shi=11,fen=21,miao=50;//時(shí)分秒
unsigned int num=0;
unsigned int S;
u8 key=0;
unsigned int Choice=2;
int Bluetooth_Sign=1,WIFI_Sign=33,Flashlight_Sign=1,Electricity_Sign=4;
int Status_Bar_Sgin=0,Content_Column_Sgin=0;
int Key_Selectio=0;
int conu=0;
int Page_Sgin=0;
int count=0;
int Return_Sgin=0;
int Sgin=1;
int text_Buffer[]={00000000};
#define size sizeof(text_Buffer)    //讀取要寫入芯片中的字節(jié)數(shù)。
void FMQ(void)
    fmq=1;//叫
    delay_ms(50);
    fmq=0;//停
    delay_ms(50);
void Timer2_Init_Config(void)
    NVIC_InitTypeDef  NVIC_InitStructure;
    TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);        //使能Timer2時(shí)鐘
    TIM_TimeBaseStructure.TIM_Period = 9999;                        //設(shè)置在下一個(gè)更新事件裝入活動(dòng)的自動(dòng)重裝載寄存器周期的值(計(jì)數(shù)到10為1ms)  9 1MS計(jì)數(shù)   99 10ms基計(jì)數(shù)
    TIM_TimeBaseStructure.TIM_Prescaler = 7199;                    //設(shè)置用來(lái)作為TIMx時(shí)鐘頻率除數(shù)的預(yù)分頻值(10KHz的計(jì)數(shù)頻率)
    TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;        //設(shè)置時(shí)鐘分割:TDTS = TIM_CKD_DIV1
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;    //TIM向上計(jì)數(shù)模式
    TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);                //根據(jù)TIM_TimeBaseInitStruct中指定的參數(shù)初始化TIMx的時(shí)間基數(shù)單位
    NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;                //設(shè)置中斷向量號(hào)
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;    //設(shè)置搶先優(yōu)先級(jí)0
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;            //設(shè)置響應(yīng)優(yōu)先級(jí)0
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                //使能NVIC
    NVIC_Init(&NVIC_InitStructure);
    TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE );                 //使能TIM2指定的中斷
    TIM_Cmd(TIM2, ENABLE);
void TIM2_IRQHandler(void)                                                   //定時(shí)器2中斷服務(wù)函數(shù)1S一次
    if(TIM_GetITStatus(TIM2, TIM_IT_Update) == SET)
        TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
        miao++;
        if(miao==60)
            miao=0;
            fen++;
            if(fen==60)
                fen=0;
                shi++;
                if(shi==24)
                    shi=0;
        if(shi==nzs&&fen==nzf)
            FMQ();
int main(void)
     unsigned int datatemp[size];
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);    //設(shè)置NVIC中斷分組2:2位搶占優(yōu)先級(jí),2位響應(yīng)優(yōu)先級(jí)
     delay_init();
     uart_init(115200);
     IIC_Init();
     OLED_Init();
     LED_Init();
     KEY_Init();
     Timer2_Init_Config();
     Key_Init();
Key_Test();
    //AT24CXX_WriteLenByte(0,miao,size);
    //S=AT24CXX_ReadLenByte(0,size);
    //printf("%d",S);
    WhenTheDisplay2();
    //lnterface();  //菜單顯示
    //WhenTheDisplay();
        OLED_P16x32Ch(1*16,2,1);        //屏幕中間顯示12:28
        OLED_P16x32Ch(2*16,2,2);
        OLED_P16x32Ch(3*16,2,10);
        OLED_P16x32Ch(4*16,2,2);
        OLED_P16x32Ch(5*16,2,8);
        //OLED_P32x32Ch(1*32,2,0);    //您
        //OLED_P32x32Ch(2*32,2,1);    //好
        //OLED_P128x48Ch(0,2,0);//嗨占滿屏幕
    /*    Status_Bar();                      // 頂層圖標(biāo)顯示
        OLED_P8x16Str(1*16,2,"Tomorrow");//第一行
        OLED_P8x16Str(1*16,4,"123");     //第二行
        OLED_P8x16Str(1*16,6,"123");      //第三行
    OLED_P16x16Ch(0*16,Choice,44);            //選擇箭頭
    OLED_P16x16Ch(1*16,2,65);                 //藍(lán)
    OLED_P16x16Ch(2*16,2,66);                 //牙
    OLED_P8x16Str(1*16,4,"WIFI");             //WIFI
    OLED_P16x16Ch(1*16,6,67);                   //溫
    OLED_P16x16Ch(2*16,6,68);                   //度
    OLED_ShowNum(6*16,6,Choice/2,1,12);    //右下角頁(yè)數(shù)
    OLED_P6x8Str(6.5*16,7,"/");
    OLED_P6x8Str(7*16,7,"10");
