查看: 1656|回復: 7
STC15F2K60S2單片機加TMTM1637驅動數(shù)碼管 檢測應答錯誤
ID:961122 發(fā)表于 2023-2-19 11:00 | 顯示全部樓層 |閱讀模式
程序如下:問題:當我用多個_nop_()做延時,LED2燈就會亮(我用LED檢測應答,如果單片機沒收到應簽就亮起),數(shù)碼管顯示正常。如果延時用for語句,for內就一個_nop_(),LED2燈就不會亮,數(shù)碼管也正常。不知為什么,請高人指點。
I2C_DRIVE.C
I2C_DRIVE.C
#define _I2C_DRIVE_C
#include "reg51.h"
#include "I2C_drive.h"
#include "INTRINS.H"
sbit SCL          =                   P2^0 ;                //???????IIC???????
sbit SDA          =                   P2^1 ;                //???????IIC????????
void I2C_delay(void)                                        //延時4us 在11059200時鐘下一個nop為1us
uint8 i;
//不用for語句用_nop();LED2會亮起,說明檢測應答有誤
//_nop_();
//_nop_();
//_nop_();
//_nop_();
for(i=0;i<1;i++){
    _nop_();
void I2C_Init(void)//IIC初始化
//  P2M1 |= 0x03;      //P1.5、P1.6定義為輸出
//  P2M0 |= 0x03;
//*名稱:i2c_send_noack()                                                              *
//*功能:無應答I2C總線                                                              *
//*參數(shù):無        *
//*返回:1 有NOACK信號 0 無NOACK信號                                                 *
void send_noack(void){
    SDA=1;  //SDA = 1; NO ACK
    I2C_delay();
    SCL=1;  //SCL = 1;
    I2C_delay();
    SCL=0;  //SCL = 0;  //START
// iic 應答  for slaver
void send_ack(void) {
    SDA=0; //OUT 0 ACK
    I2C_delay();
    SCL=1;
    I2C_delay();
    SCL=0;
*停止iic
void I2C_stop(void){
    SDA=0;
    SCL=0;  //SCL = 0;
    I2C_delay();
    SCL=1;  //SCL = 1;  STOP
    I2C_delay();
    SDA=1;  //SDA = 1;
    I2C_delay();
* 啟動iic
//  static void start(void) {
void I2C_start(void){
    SDA=1;  //SDA = 1;
    SCL=1;  //SCL = 1;
    I2C_delay();
    SDA=0;  //SDA = 0;
    I2C_delay();
* iic寫一個字節(jié)
void I2C_write(uint8 datIn) {
    uint8 mask;
    for(mask = 0x01; mask != 0;mask <<= 1){ // 先寫高低為:(mask = 0x80; mask != 0;mask >>= 1) TM1637先寫低位
        if((mask & datIn) == 0)
            SDA = 0;
            SDA = 1;
        I2C_delay();
        SCL = 1;
        I2C_delay();
        SCL = 0;
uint8 check_ack(void) {
    uint8 ack_flag;
    SDA = 1;
    I2C_delay();
    SCL = 1;    //read ask begin
    I2C_delay();
    ack_flag=SDA;
    I2C_delay();
    SCL = 0;    //read ask end
    return (~ack_flag); //應答值取反以符合通常的邏輯:0=不存在或忙或寫入失敗,1=存在且空閑或寫入成功
* iic讀一個字節(jié)
uint8 I2C_read(void) {
    uint8 mask,dat;
    SDA =1 ;
    for(mask = 0x80; mask != 0;mask >>= 1){
        I2C_delay();
        SCL = 1;
        if(SDA == 0)
            dat &= ~mask;
            dat |= mask;
        I2C_delay();
        SCL = 0;
    return dat;
// End Of File
MAIN.C
#include "REG51.H"
sbit LED0   = P1^0;
sbit LED1   = P1^1;
sbit LED2   = P1^2;
sbit LED3   = P1^3;
void main(){
  uint8 i;
  I2C_start();
  I2C_write(0x40);
  if(~check_ack()) LED0=0;
  I2C_stop();
  I2C_start();
  I2C_write(0xC0);
  if(~check_ack()) LED1=0;
  for(i=0;i<4;i++){
    I2C_write(0xff);
    if(~check_ack()) LED2=0;
  I2C_stop();
  I2C_start();
  I2C_write(0x8f);
   if(~check_ack()) LED3=0;
  I2C_stop();
  while (1);
ID:213173 發(fā)表于 2023-2-19 13:48 | 顯示全部樓層
STC15F2K60S2是1T單片機,一個_nop_()延時時間在12MHz晶振12T單片機是1us,換了運行環(huán)境就大相徑庭了。
ID:961122 發(fā)表于 2023-2-19 14:02 | 顯示全部樓層
都是在同一個芯片上運行的
ID:1063483 發(fā)表于 2023-2-19 20:36 | 顯示全部樓層
uint8 i;
//_nop_();
//_nop_();
//_nop_();
//_nop_();
for(i=0;i<3;i++){
    _nop_();
把for(i=0;i<1;i++)中的   i<1,改為  i<3,  循環(huán)4次,應該可以. 并不是一個_nop_()不行,而是單片機就算響應了,數(shù)碼管來不及響應就過了,試試看吧
ID:161164 發(fā)表于 2023-2-19 21:04 | 顯示全部樓層
以下仿真用12Mhz開始時間:75.25us
運行For之后:78.75us, 耗時:3.5us
運行nop之后:79.92us, 耗時:1.17us
用nop延時的時間太短
不足以讓1637返回Ack(拉低電平)
但1637收到命令和數(shù)據(jù)
所以也可以正常顯示
ID:961122 發(fā)表于 2023-2-20 13:43 | 顯示全部樓層
lkc8210 發(fā)表于 2023-2-19 21:04
感謝各位,受教了。不但知道了結果,也了解了分析問題的方法。嚴謹性值得佩服!
ID:961122 發(fā)表于 2023-2-21 21:16 | 顯示全部樓層
用USBee測了4個nop的延時,高電平延時只有2us不到,不知為什么?
ID:961122 發(fā)表于 2023-2-21 21:19 | 顯示全部樓層
用usbee測了一下,SCL高電平中延時了2us不到,同一個延時為什么低電平有6us。真不知為什么?
aa
aa
Powered by 單片機教程網
