查看: 2720|回復(fù): 0
C高級(jí)指針接口回調(diào)函數(shù)
ID:56426 發(fā)表于 2013-10-29 16:23 | 顯示全部樓層 |閱讀模式
// C的精華在指針 指針的精華在函數(shù)指針
int  insert_linklist_mount(FILE *p ,Ocean_Element **wordtemp, char**s,uint32_t mount);
回調(diào)函數(shù)實(shí)現(xiàn)接口設(shè)計(jì)
32行 回調(diào)函數(shù)  主要功能 向鏈表插入從文件p 中讀出的兩行數(shù)據(jù)  第二參數(shù)傳入傳出參數(shù) 初始化結(jié)構(gòu)并傳出   第三參數(shù)char **s   堆上的空間用來(lái)接收文件內(nèi)容  mount 用來(lái)指定想鏈表中插入Ocean_Element 結(jié)構(gòu)(記錄)的個(gè)數(shù)
//dzm_project
  2 #ifndef _HABITS
  3 #define _HABITS
  4 #include <malloc.h>
  5 #include <stdio.h>
  6 #include <string.h>
  7 #include "simplified.h"
  8 #define  READ_LEN  150
  9 #define  CHIN_LEN  150
10 #define  WORK_LEN  150
11  typedef struct _OCEAN
12         {
13             char   *word;
14             char   *chin[CHIN_LEN];
15             uint32_t    count ;
16             struct _OCEAN* maintain;
17             struct _OCEAN* next;
18             struct _OCEAN* prev;
19         }Ocean_Element;
20
21  typedef void(*Tpfocus) (FILE *p, Ocean_Element** temp, char **s);
22
23  extern Ocean_Element *head;
24
25  int receive_vw_count(uint32_t *count);
26  void preserve_chin_array(Ocean_Element **node, char* tempword, char **arp);
27  void creat_virtual(Ocean_Element **list);
28 int read_file_line(FILE* p, Ocean_Element **wordtemp, char** s);
29 void judge_changeline(char ** para);
30 int  judge_char(char **par, char val);
31 int  egodic_list(void);
32 int  insert_linklist_mount(FILE *p ,Ocean_Element **wordtemp, char**s,uint32_t mo    unt);
33 char* cpy_str(char **dest, char **src);
34 char* judge_delete_ch(char**para, char ch) ;
35 char* user_search(char **s);
36 int   search_word(Ocean_Element *temp, const char * str);
37
38  void main_task(FILE *p, Ocean_Element **wordtemp, char**s);
