上面的是實(shí)驗(yàn)箱的第一個(gè)代碼,后面是根據(jù)第一個(gè)改出來(lái)的,然后現(xiàn)在的要求是先亮第一段代碼的LED燈,然后點(diǎn)擊4412實(shí)驗(yàn)箱上的音量+和音量-可以中斷切換到第二個(gè)代碼的亮燈;蛘呖梢越o出一個(gè)延時(shí)函數(shù),延時(shí)2秒左右的時(shí)間切換到第二段代碼也可以。
- #include "exynos_4412.h"
- * @brief mydelay_ms program body
- * @param[in] int (ms)
- * @return None
- void mydelay_ms(int ms)
- int i, j;
- while(ms--)
- for (i = 0; i < 5; i++)
- for (j = 0; j < 514; j++);
- /*-------------------------MAIN FUNCTION------------------------------*/
- * @brief Main program body
- * @param[in] None
- * @return int
- int main(void)
- *Config
- *D1 -> GPX2_4 D2 -> GPX3_0
- *D3 -> GPX2_7 D4 -> GPX1_0
- GPX2.CON = (GPX2.CON & ~(0xf<<16 | 0xf<<28)) | (0x1<<16 | 0x1<<28) ;//GPX2_4:output, D1
- //GPX2_7:output, D3
- GPX3.CON = (GPX3.CON & ~(0xf<<0)) | 0x1<<0; //GPX3_0:output, D2
- GPX1.CON = (GPX1.CON & ~(0xf<<0)) | 0x1<<0; //GPX1_0:output, D4
- * Turn off all LED
- GPX2.DAT &= ~(0x1 << 4);
- GPX2.DAT &= ~(0x1 << 7);
- GPX3.DAT &= ~(0x1 << 0);
- GPX1.DAT &= ~(0x1 << 0);
- while(1)
- //Turn on D1
- GPX2.DAT |= 0x1 << 4;
- mydelay_ms(500);
- //Turn on D3
- GPX2.DAT |= 0x1 << 7;
- //Turn off D1
- mydelay_ms(500);
- //Turn on D2
- GPX3.DAT |= 0x1 << 0;
- //Turn off D3
- mydelay_ms(500);
- //Turn on D4
- GPX1.DAT |= 0x1 << 0;
- //Turn off D2
- mydelay_ms(500);
- //Turn off D4
- return 0;
* @return None
int i, j;
while(ms--)
* @param[in] None
* @return int
int main(void)
*Config
//GPX2_7:output, D3
// GPX1.CON = (GPX1.CON & ~(0xf<<0)) | 0x1<<0; //GPX1_0:output, D4
* Turn off all LED
//Turn on D1
mydelay_ms(500);
//Turn on D2
//Turn off D1
mydelay_ms(500);
//Turn on D3
// GPX2.DAT |= 0x1 << 7;
//Turn off D2
mydelay_ms(500);
//Turn on D4
// GPX1.DAT |= 0x1 << 0;
//Turn off D3
//GPX2.DAT &= ~(0x1 << 7);
//mydelay_ms(500);
//Turn off D4
//GPX1.DAT &= ~(0x1 << 0);
return 0;
