查看: 1193|回復(fù): 3
想尋求一個(gè)通過(guò)光敏電阻控制led亮暗程度的代碼
ID:1068108 發(fā)表于 2023-4-14 18:08 來(lái)自觸屏版 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
謝謝大家
基于stc15
ID:1068301 發(fā)表于 2023-4-14 19:38 | 只看該作者
#include "ADC1.h"
//光敏
void ADC1_Init(void)
        //使能PC口時(shí)鐘
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
        //配置IO口 模擬輸入
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);
        GPIO_InitTypeDef GPIO_InitStruct;
        GPIO_InitStruct.GPIO_Mode=GPIO_Mode_AN;
        //GPIO_InitStruct.GPIO_OType=
        GPIO_InitStruct.GPIO_Pin=GPIO_Pin_0;
        //GPIO_InitStruct.GPIO_PuPd=
        GPIO_InitStruct.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_Init(GPIOC, &GPIO_InitStruct);
        //配置ADC--12精度 右對(duì)齊 單次不掃描 通道數(shù)1
        RCC_APB2PeriphClockLPModeCmd(RCC_APB2Periph_ADC1, ENABLE);
        ADC_InitTypeDef ADC_InitStruct={0};
        ADC_Init(ADC1, &ADC_InitStruct);
        ADC_InitStruct.ADC_ContinuousConvMode=DISABLE;    //連續(xù)單次模式
        ADC_InitStruct.ADC_DataAlign=ADC_DataAlign_Right;        //數(shù)據(jù)對(duì)齊(左or右)
//        ADC_InitStruct.ADC_ExternalTrigConv=                                    //外部觸發(fā)方式
//        ADC_InitStruct.ADC_ExternalTrigConvEdge=                    //外部觸發(fā)極性配置
        ADC_InitStruct.ADC_NbrOfConversion =1;                                                //AD轉(zhuǎn)換通道數(shù)
        ADC_InitStruct.ADC_Resolution      =ADC_Resolution_12b;//分辨率
        ADC_InitStruct.ADC_ScanConvMode    = DISABLE;      //掃描模式
        //配置--獨(dú)立模式 采樣頻率 兩次采樣間隔時(shí)間 是否使能DMA
        ADC_CommonInitTypeDef ADC_CommonInitStruct;
        ADC_CommonInitStruct.ADC_DMAAccessMode=ADC_DMAAccessMode_Disabled;
        ADC_CommonInitStruct.ADC_Mode=ADC_Mode_Independent;        //獨(dú)立模式,單個(gè)ADC使用
        ADC_CommonInitStruct.ADC_Prescaler=ADC_Prescaler_Div4;          //采樣頻率(84/4<36)
        ADC_CommonInitStruct.ADC_TwoSamplingDelay=ADC_TwoSamplingDelay_20Cycles;//兩次采樣延時(shí)
        ADC_CommonInit(&ADC_CommonInitStruct);
        ADC_Cmd(ADC1, ENABLE);
//        ADC_SoftwareStartConv(ADC1);//軟件觸發(fā)使能
        //設(shè)定ADC規(guī)則組通道,轉(zhuǎn)化順序和采樣時(shí)間
//        ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_480Cycles);
u16 ADC1_Read_Value(void)
        while(ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC)==0);//等待規(guī)則組轉(zhuǎn)換完成
        ADC_ClearFlag(ADC1, ADC_FLAG_EOC);  //清規(guī)則組轉(zhuǎn)換完成標(biāo)記位
        return ADC_GetConversionValue(ADC1);//返回讀取到的ADC值
//pwm燈光控制
#include "pwm.h"
void TIM3_PWM_Init(int psc,int val)  //psc預(yù)分頻系數(shù) val重裝載值
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);//使能TIM3時(shí)鐘
         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC,ENABLE);
         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE);
//        GPIO_InitTypeDef Fan3;//風(fēng)扇 PC8
        GPIO_InitTypeDef Led3;//LED3 PB0
        TIM_OCInitTypeDef PWM={0};
//          Fan3.GPIO_Pin=GPIO_Pin_8;
//          Fan3.GPIO_Mode=GPIO_Mode_AF;
//          Fan3.GPIO_Speed=GPIO_Speed_2MHz ;
//          Fan3.GPIO_OType=GPIO_OType_PP;
//          Fan3.GPIO_PuPd=GPIO_PuPd_UP;
//          GPIO_Init(GPIOC,&Fan3);
//          GPIO_PinAFConfig(GPIOC,GPIO_PinSource8,GPIO_AF_TIM3);
          Led3.GPIO_Pin=GPIO_Pin_0;
          Led3.GPIO_Mode=GPIO_Mode_AF;
          Led3.GPIO_Speed=GPIO_Speed_2MHz ;
          Led3.GPIO_OType=GPIO_OType_PP;
          Led3.GPIO_PuPd=GPIO_PuPd_UP;
          GPIO_Init(GPIOB,&Led3);
          GPIO_PinAFConfig(GPIOB,GPIO_PinSource0,GPIO_AF_TIM3);
          PWM.TIM_Pulse=0;//先寫0,默認(rèn)為0%低電平
          PWM.TIM_OCMode=TIM_OCMode_PWM1;//PWM1模式
          PWM.TIM_OCPolarity=TIM_OCPolarity_Low;//低電平有效
          PWM.TIM_OutputState=TIM_OutputState_Enable;//使能輸出控制
          TIM_OC3Init(TIM3,&PWM);
        TIM_TimeBaseInitTypeDef T3;//基本定時(shí)器初始化結(jié)構(gòu)體
        T3.TIM_ClockDivision=TIM_CKD_DIV1;//時(shí)鐘分頻
        T3.TIM_CounterMode=TIM_CounterMode_Up;//向下計(jì)數(shù)模式
        T3.TIM_Period=val;//重裝載值(計(jì)時(shí),systick是記次數(shù))
        T3.TIM_Prescaler=psc-1;//預(yù)分頻
        T3.TIM_RepetitionCounter=0;//tim1 和tim8有
        TIM_TimeBaseInit(TIM3,&T3);//基本定時(shí)器初始化
   TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE);//定時(shí)器中斷配置使能
        TIM_Cmd(TIM3,ENABLE);//使能TIM3
ID:1068108 發(fā)表于 2023-4-15 16:08 來(lái)自觸屏版 | 只看該作者
afasga 發(fā)表于 2023-4-14 19:38
#include "ADC1.h"
//光敏
謝謝,但是請(qǐng)問(wèn)有51的程序嗎
