查看: 1545|回復(fù): 6
請問LCD12232液晶屏如何實現(xiàn)反白顯示
ID:471636 發(fā)表于 2023-4-16 11:45 | 顯示全部樓層 |閱讀模式
看說明書  反白是擴展指令集  于是  發(fā)送0x34  指令   發(fā)送0X04 反白指令,結(jié)果顯示字符都沒了。
我用的是DM12232液晶屏。
ID:220661 發(fā)表于 2023-4-16 13:37 | 顯示全部樓層
你說的是反顯吧?
ID:1072104 發(fā)表于 2023-4-16 20:30 | 顯示全部樓層
#include "stm32f10x.h"
#include "delay.h"
#define LCD_DATA        GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7
#define LCD_DATA_PORT   GPIOA
#define LCD_CMD         GPIO_Pin_8
#define LCD_CMD_PORT    GPIOB
#define LCD_RST         GPIO_Pin_9
#define LCD_RST_PORT    GPIOB
#define LCD_CS          GPIO_Pin_12
#define LCD_CS_PORT     GPIOB
void lcd_cmd(uint8_t cmd)
    LCD_CMD_PORT->BRR = LCD_CMD;  // 寫命令選擇
    LCD_CS_PORT->BRR = LCD_CS;    // 片選使能
    LCD_DATA_PORT->ODR = cmd;     // 寫入命令
    Delay_us(10);                 // 延時10us
    LCD_CS_PORT->BSRR = LCD_CS;   // 片選禁止
void lcd_data(uint8_t data)
    LCD_CMD_PORT->BSRR = LCD_CMD; // 寫數(shù)據(jù)選擇
    LCD_DATA_PORT->ODR = data;    // 寫入數(shù)據(jù)
void lcd_init(void)
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB, ENABLE);
    // 配置LCD數(shù)據(jù)口為推挽輸出
    GPIO_InitStructure.GPIO_Pin = LCD_DATA;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_Init(LCD_DATA_PORT, &GPIO_InitStructure);
    // 配置LCD命令口、復(fù)位口、片選口為推挽輸出
    GPIO_InitStructure.GPIO_Pin = LCD_CMD | LCD_RST | LCD_CS;
    GPIO_Init(LCD_CMD_PORT, &GPIO_InitStructure);
    GPIO_Init(LCD_RST_PORT, &GPIO_InitStructure);
    GPIO_Init(LCD_CS_PORT, &GPIO_InitStructure);
    // 復(fù)位液晶屏
    LCD_RST_PORT->BRR = LCD_RST;
    Delay_ms(10);
    LCD_RST_PORT->BSRR = LCD_RST;
    Delay_ms(10);
    // 擴展指令集設(shè)置
    lcd_cmd(0x34);  // 打開擴展指令集
    lcd_cmd(0x04);  // 打開反白顯示
    // 顯示控制參數(shù)設(shè)置
    lcd_cmd(0x30);  // 關(guān)閉擴展指令集
    lcd_cmd(0x0c);  // 顯示開,無游標,不閃爍
    lcd_cmd(0x01);  // 清屏
void lcd_putchar(uint8_t ch)
    lcd_data(ch);
void lcd_puts(const char* str)
    while (*str) {
        lcd_data(*str++);
void lcd_putnum(uint32_t num)
    uint8_t buf[10];
    uint8_t len = 0;
    do {
        buf[len++] = '0' + num % 10;
        num /= 10;
    } while (num > 0);
    for (int i = len - 1; i >= 0; i--) {
        lcd_data(buf[i]);
int main(void)
    lcd_init();     // 初始化液晶屏
    lcd_puts("Hello, world!");   // 顯示字符
    while(1);
這是一份基礎(chǔ)代碼示例,你根據(jù)自己實際的需求進行適應(yīng)和調(diào)整。
ID:471636 發(fā)表于 2023-4-16 22:51 | 顯示全部樓層
是的  反顯
ID:1034262 發(fā)表于 2023-4-17 10:30 | 顯示全部樓層
如果是用的自激的字庫,則將點陣取反即可。
ID:584814 發(fā)表于 2023-4-17 11:03 | 顯示全部樓層
反顯,要不用物理方式直接買成品;
要不用將現(xiàn)在打點的地方空、空的地方打點。
ID:471636 發(fā)表于 2023-4-17 20:28 | 顯示全部樓層
反白是不是只支持繪圖模式,不支持字符模式?
