麻煩大家?guī)臀覚z查一下C程序,運(yùn)行結(jié)果是這樣的
Build target 'Target 1'
Text3.c(3): warning C318: can't open file 'sfr.h'
Text3.c(4): warning C318: can't open file 'os.h'
TEXT3.C(7): error C129: missing ';' before 'P36_o_74f161_clr_n'
Target not created
// 8051單片機(jī)初始源程序
#include <sfr.h>
#include <os.h>
#include <stdlib.h>
#include <stdio.h>
_sfrbit P36_o_74f161_clr_n = _p3^6; //
_sfrbit P35_o_74f161_enp = _p3^5; //外部計(jì)數(shù)器F161有效(Enable)
_sfrbit P30_io_74hc393_clr_hold = _p3^0; //外部計(jì)數(shù)器HC393復(fù)位/HOLD輸入
_sfrbit P37_i_prescaler = _p3^7; // 64分頻的預(yù)分頻器
//七段LED字形數(shù)據(jù)
// hgfedcba
#define DIG0 0xC0 // 11000000b ; 0 P2.0
#define DIG1 0xF9 // 11111001b ; 1 +-----a-----+
#define DIG2 0xA4 // 10100100b ; 2 | |
#define DIG3 0xB0 // 10110000b ; 3 P2.5 f b P2.1
#define DIG4 0x99 // 10011001b ; 4 | |
#define DIG5 0x92 // 10010010b ; 5 | P2.6 |
#define DIG6 0x82 // 10000010b ; 6 +-----g-----+
#define DIG7 0xD8 // 11011000b ; 7 | |
#define DIG8 0x80 // 10000000b ; 8 P2.4 e c P2.2
#define DIG9 0x98 // 10011000b ; 9 | |
// ; | P2.3 |
#define DIGM 0xBF // 10111111b ; - +-----d-----+ * h P2.7
#define DIGP 0x7F // 01111111b ; .
#define DIGB 0xFF // 11111111b ; "Blank"(“空白”)
const char segment_pattern[] = { DIG0, DIG1, DIG2,\
DIG3, DIG4, DIG5, DIG6, DIG7, DIG8, DIG9 };
const char segment_select[] = { 0xFE, 0xFD, 0xFB, \
0xF7, 0xEF, 0xDF, 0xBF, 0x7F };
unsigned long trailer;
unsigned long task;
unsigned int trimer;
unsigned char fnd[8];
unsigned char mfnd[8];
unsigned int int_state;
unsigned char fnd_state;
unsigned char boat;
bit hold;
void _interrupt IVN_TIMER1 time_base() {
_tl1 = 0x60; _th1 = 0xF0; // 4000 2 M Sec 500 Times
_p0 = 0xff;
_p2 = segment_select[fnd_state];
_p0 = fnd[fnd_state++];
fnd_state &= 0x07;
if(int_state == 0) { //
P35_o_74f161_enp = 0; //外部計(jì)數(shù)器F161計(jì)數(shù)禁止
P30_io_74hc393_clr_hold = 1; //外部計(jì)數(shù)器HC393復(fù)位
P36_o_74f161_clr_n = 0; //外部計(jì)數(shù)器F161復(fù)位
_tl0 = 0x00; _th0 = 0x00; //內(nèi)部計(jì)數(shù)器復(fù)位
hold = P30_io_74hc393_clr_hold; // HOLD(保持)鍵狀態(tài)輸入
P36_o_74f161_clr_n = 1; // 外部計(jì)數(shù)器F161有效(Enable)
P30_io_74hc393_clr_hold = 0; // 外部計(jì)數(shù)器HC393有效(Enable)
P35_o_74f161_enp = 1; // 外部計(jì)數(shù)器F161進(jìn)行計(jì)數(shù)
if(int_state == 316) { // 10GHz狀態(tài)(64分頻的預(yù)分頻器)
if (!P37_i_prescaler) { // 門(mén)控時(shí)間為0.64秒
for (trimer = 0; trimer<202; trimer++) ; // 15個(gè)機(jī)器周期單位
// 測(cè)試信號(hào)24MHz輸入
boat++; // 15360000 用于顯示,需調(diào)整
boat++; // 延遲1個(gè)機(jī)器周期(12個(gè)時(shí)鐘周期)
boat++; // 15359988
boat++; // 15360000
// boat++; // 15360012
P35_o_74f161_enp = 0; // 外部計(jì)數(shù)器停止
trailer = _th0;
trailer = (trailer << 20) & 0x0ff00000;
task = _tl0;
task = (task << 12) & 0x000ff000;
trailer |= task;
task = _p3;
task = (task << 7) & 0x00000f00;
trailer |= task;
task = _p1 & 0x000000ff;
trailer |= task;
P35_o_74f161_enp = 1; // ?? ??? ???? ?????
// 電流消耗,
// 外部計(jì)數(shù)器將重新開(kāi)始。
if(int_state == 494) { // 100 MHz Mode 1 Sec Gate Time
if (P37_i_prescaler) { // 1 Sec Gate Time
for (trimer = 0; trimer<248; trimer++) ; // 15個(gè)機(jī)器周期單位
// 測(cè)試24MHz信號(hào)源輸入
boat++; // 24000000 用于顯示,需調(diào)整
boat++; //
boat++; //
boat++; //
boat++; // 23999988
boat++; // 24000000
// boat++; // 24000012
trailer = _th0;
task = _tl0;
trailer |= task;
task = _p3;
trailer |= task;
trailer |= task;
// 電流消耗,以時(shí)間表
// 外部計(jì)數(shù)器重新開(kāi)始。
if(int_state == 506) { // 1Hz數(shù)字顯示
boat = trailer % 10;
mfnd[7] = segment_pattern[boat & 0xf];
trailer /= 10;
if(int_state == 507) {
mfnd[6] = segment_pattern[boat & 0xf];
trailer /= 10;
if(int_state == 508) {
mfnd[5] = segment_pattern[boat & 0xf];
trailer /= 10;
if(int_state == 509) {
mfnd[4] = segment_pattern[boat & 0xf];
trailer /= 10;
if(int_state == 510) {
mfnd[3] = segment_pattern[boat & 0xf];
trailer /= 10;
if(int_state == 511) {
mfnd[2] = segment_pattern[boat & 0xf];
trailer /= 10;
if(int_state == 512) {
mfnd[1] = segment_pattern[boat & 0xf];
trailer /= 10;
if(int_state == 513) {
mfnd[0] = segment_pattern[boat & 0xf];
trailer /= 10;
int_state++;
if(int_state >= 514) {
int_state = 0;
if (hold) {
fnd[0] = mfnd[0];
fnd[1] = mfnd[1];
fnd[2] = mfnd[2];
fnd[3] = mfnd[3];
fnd[4] = mfnd[4];
fnd[5] = mfnd[5];
fnd[6] = mfnd[6];
fnd[7] = mfnd[7];
fnd[1] &= 0x7F; // MHz點(diǎn)
} else {
fnd[0] &= 0x7F; // GHz點(diǎn)
main()
_tmod = 0x15; // 0b00010101 Timer0 = Mode1, Counter, use TR0
// Timer1 = Mode1, Timer, use TR1
_tl0 = 0X0; _th0 = 0X0;
_tl1 = 0X0; _th1 = 0X0;
_tr0 = 1; // Timer 0 計(jì)數(shù)開(kāi)始
_tr1 = 1; // Timer 1 計(jì)數(shù)開(kāi)始
_et1 = 1; // 設(shè)置定時(shí)器1中斷狀態(tài)
_ea = 1; // 設(shè)置全局中斷狀態(tài)
while(1) ;
