查看: 1377|回復(fù): 0
我的單片機(jī)設(shè)計(jì),里面包含proteus仿真和程序代碼
簡(jiǎn)易密碼鎖設(shè)計(jì),bug比較多
  1. /**************************************************************                                                  *
  2. 功能:通過(guò)軟件程序設(shè)置密碼,初始密碼為123456,當(dāng)按鍵按下之后  *
  3.           再按下確認(rèn)鍵,如果密碼正確,則綠燈亮,舵機(jī)旋轉(zhuǎn)90度,如果*
  4.           密碼錯(cuò)誤,紅燈亮,短暫延時(shí)后,數(shù)碼管清零,紅燈滅,重新輸*
  5.           入密碼。        *
  6. *//************************************************************/
  7. /****************************************************************/
  8.
  9. #include <reg51.h>
  10. #define uchar unsigned char
  11. #define uint  unsigned int
  12. sbit P2_0 = P2^0;
  13. sbit P2_1 = P2^1;
  14. sbit P2_2 = P2^2;
  15. sbit P2_3 = P2^3;
  16. sbit P2_4 = P2^4;
  17. sbit P2_5 = P2^5;
  18. sbit P2_6 = P2^6;
  19. sbit P3_6 = P3^6;
  20. sbit LED_G = P3^0;
  21. sbit LED_R = P3^1;
  22. sbit beep = P3^7;
  23. uint tab[16]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
  24. uchar h,l,s,o,zhengque,m = 0,v = 1,w = 0,n = 1,keyval_0 ,keyval_1,keyval_2,keyval_3,
  25. keyval_4,keyval_5,keyval_6,keyval_7,keyval_8,keyval_9,keyval_10,keyval_11,keyval_12,
  26. keyval_13,keyval_14,keyval_15,keyval,temp = 0x01;
  27. void delay(uint z)
  28. {
  29.         uint x , y;
  30.         for(x = z ; x > 0 ; x--)
  31.                 for(y = 114 ; y > 0 ; y--);
  32. }
  33. //有參延時(shí)
  34. void key_scan1()
  35. {
  36.
  37.     P1=0x0f;//檢測(cè)是哪一行有按鍵按下;
  38.     if(P1!=0x0f)
  39.     {
  40.         delay(10);
  41.         if(P1!=0x0f)
  42.         {
  43.                         beep = ~beep;
  44.             P1=0x0f;
  45.             switch(P1)
  46.             {
  47.                 case(0x0e):h=1;break;
  48.                 case(0x0d):h=2;break;
  49.                 case(0x0b):h=3;break;
  50.                 case(0x07):h=4;break;
  51.             }
  52.         }
  53.         P1=0xf0;//檢測(cè)是哪一列有按鍵按下
  54.         switch(P1)
  55.         {
  56.             case(0xe0):l=1;break;
  57.             case(0xd0):l=2;break;
  58.             case(0xb0):l=3;break;
  59.             case(0x70):l=4;break;
  60.         }
  61.         while(P1!=0xf0);//當(dāng)按鍵復(fù)位時(shí)
  62.
  63.                 w++;
  64.                 beep = ~beep;
  65.
  66.                 //按一次第一個(gè)數(shù)碼管顯示,按兩次前兩個(gè)數(shù)碼管顯示......
  67.     }
  68.
  69. }
  70. void shuru()
  71. {
  72.         P2 = 0Xc0;
  73.         //P0 = 0XBF;
  74.
  75.         while(v)
  76.         {
  77.
  78.            key_scan1();
  79.            s = 5*h + l;//行列進(jìn)行線(xiàn)性運(yùn)算,通過(guò)判斷s的值來(lái)判斷對(duì)應(yīng)按鍵
  80.            switch(s)
  81.            {
  82.                            case(9):keyval = 0;keyval_0 = 0;break;
  83.             case(8):keyval = 1;keyval_1 = 1;break;
  84.             case(7):keyval = 2;keyval_2 = 2;break;
  85.             case(6):keyval = 3;keyval_3 = 3;break;
  86.                         case(14):keyval = 4;keyval_4 = 4;break;
  87.                         case(13):keyval = 5;keyval_5 = 5;break;
  88.             case(12):keyval = 6;keyval_6 = 6;break;
  89.             case(11):keyval = 7;keyval_7 = 7;break;
  90.                         case(19):keyval = 8;keyval_8 = 8;break;
  91.             case(18):keyval = 9;keyval_9 = 9;break;
  92.                         case(17):keyval = 10;keyval_10 = 10;break;
  93.             case(16):keyval = 11;keyval_11 = 11;break;
  94.             case(24):keyval = 12;keyval_12 = 12;break;
  95.             case(23):keyval = 13;keyval_13 = 13;break;
  96.                         case(22):keyval = 14;keyval_14 = 14;break;
  97.             case(21):keyval = 15;keyval_15 = 15;break;
  98.            }
  99.
  100.            switch(w)
  101.            {
  102.                    case 1:        P2_0 = 1;P0 = tab[keyval];delay(100);P2_0 = 0;break;
  103.                 case 2:        P2_1 = 1;P0 = tab[keyval];delay(100);P2_1 = 0;break;
  104.                 case 3:        P2_2 = 1;P0 = tab[keyval];delay(100);P2_2 = 0;break;
  105.                 case 4:        P2_3 = 1;P0 = tab[keyval];delay(100);P2_3 = 0;break;
  106.                 case 5:        P2_4 = 1;P0 = tab[keyval];delay(100);P2_4 = 0;break;
  107.                 case 6:        P2_5 = 1;P0 = tab[keyval];delay(100);P2_5 = 0;break;
  108.            }
  109.            if(P2_6 == 0)
  110.            delay(10);
  111.            if(P2_6 == 0)
  112.            v = 0;
  113.
  114.         }  //依次輸入密碼
  115. }
  116. void main()
  117. {
  118.         beep = 0;
  119.         shuru();
  120.         zhengque = ((keyval_1==1)&(keyval_2==2)&(keyval_3==3)&(keyval_4==4)&(keyval_5==5)&(keyval_6==6));//設(shè)置的密碼
  121.         if(P2_6 == 0)
  122.         {
  123.                 delay(10);
  124.                 if(P2_6 == 0)         //確認(rèn)鍵按下時(shí),判斷密碼是否正確
  125.                 {
  126.                   if(zhengque)
  127.                   {
  128.                            LED_G = 0;
  129.                          delay(1000);
  130.                          LED_G = 1;
  131.                          EA = 1;
  132.                          IT0 = 1;
  133.                          TMOD = 0X01;
  134.                          TH0 = (60536%256);
  135.                          TL0 = (60536/256);
  136.                         while(n)
  137.                         {
  138.                                 P3_6 = 0;
  139.                         }
  140.                   }
  141.                   else
  142.                   {
  143.                   for(o = 0 ; o < 10 ; o++)
  144.                   {
  145.                           LED_R = 0;
  146.                         beep = ~beep;
  147.                         delay(300);
  148.                         LED_R = 1;
  149.
  150.
  151.                         }
  152.                   }
  153.                 }
  154.         }
  155. }
  156.
  157. void timer0() interrupt 1  //定時(shí)器0控制舵機(jī)的PWM
  158. {
  159.         TH0 = (60536%256);
  160.         TL0 = (60536/256);
  161.         m++;
  162.         if(m == 5)
  163. {
  164.         P3_6 = 1;
  165.         m = 0;
  166.         n = 0;
  167. }
  168. }
  169. /*****************************************************************/
Keil代碼與Proteus仿真下載: 1.zip (116.53 KB, 下載次數(shù): 10)
