查看: 1999|回復(fù): 12
STM32103fx單片機(jī)使用定時(shí)器TIM3實(shí)現(xiàn)燈一秒亮一次程序問(wèn)題
ID:1076644 發(fā)表于 2023-5-10 20:54 | 顯示全部樓層 |閱讀模式
STM32103fx使用定時(shí)器TIM3實(shí)現(xiàn)燈一秒亮一次
使用keil代碼編譯沒(méi)問(wèn)題,但是在proteus仿真上,燈是一直亮的狀態(tài),不進(jìn)行定時(shí)器中斷。改了很多次,不知道為啥,求助。代碼如下
  1. //主函數(shù)
  1. void TIM3_Config(void)
  2. {
  3.          /*1表示亮燈 0表示不亮*/
  4.        /* TIM_TimeBaseInitTypeDef結(jié)構(gòu)體在stm32f10x_tim.h中定義 */
  5. TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  6. RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  7. TIM_DeInit(TIM3);
  8.      /* 計(jì)數(shù)10000次 */
  9. TIM_TimeBaseStructure.TIM_Period = (10000-1);
  10.     /* 預(yù)分頻系數(shù),7200,因?yàn)橄到y(tǒng)時(shí)鐘72MHZ */
  11. TIM_TimeBaseStructure.TIM_Prescaler = 71;
  12. TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  13. //TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  14. TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  15.         /* 根據(jù)設(shè)定的參數(shù)設(shè)置TIM1  */
  16. TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  17. TIM_ClearITPendingBit(TIM3, TIM_IT_Update);
  18. TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE);//使能或者失能指定的TIM中斷TIM3,
  19. TIM_Cmd(TIM3, ENABLE);
  20. RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, DISABLE);
  21. }
  22. void GPIO_Config(void)
  23. {
  24.         /* 定義GPIO_InitTypeDef結(jié)構(gòu)體,在stm32f10x_gpio.h中定義 */
  25. GPIO_InitTypeDef   GPIO_InitStructure;
  26.         /* 使能 */
  27. RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  28. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
  29. GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  30. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; /*驅(qū)動(dòng)LED*/
  31. GPIO_Init(GPIOA, &GPIO_InitStructure);
  32. }
  33. void NVIC_Config(void){
  34.                 NVIC_InitTypeDef NVIC_InitStructure;
  35.     // 設(shè)置中斷組為0
  36.     NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  37.     // 設(shè)置中斷來(lái)源
  38.     NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn ;
  39.     // 設(shè)置主優(yōu)先級(jí)為 0
  40.     NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  41.     // 設(shè)置搶占優(yōu)先級(jí)為3
  42.     NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
  43.     NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  44.     NVIC_Init(&NVIC_InitStructure);
  45. }
  1. //服務(wù)子函數(shù)
仿真如下圖:
燈一直保持亮的狀態(tài),并不會(huì)一亮一滅,覺(jué)得是不是中斷有問(wèn)題,但查了挺多資料,還是不行。
ID:94031 發(fā)表于 2023-5-11 06:40 | 顯示全部樓層
初始化的是PA3,不是PA5.
ID:1076644 發(fā)表于 2023-5-11 08:11 | 顯示全部樓層
主函數(shù)代碼和中斷好像沒(méi)有發(fā)出來(lái),重發(fā)一次。求助
//主函數(shù)代碼:
  1. int main(void)
  2. {
  3.         void GPIO_Config();
  4.         void TIM3_Config();
  5.         void NVIC_Config();
  7.         while(1){
  8.                         if(time==1000){
  9.                                         time=0;
  10.                                 led=~led;
  11.                         if(led ==1)
  12.                                 GPIO_SetBits(GPIOA, GPIO_Pin_5);
  13.                         else
  14.                                 GPIO_ResetBits(GPIOA, GPIO_Pin_5);
  15.                         }
  16.                 }
  17. }
//中斷服務(wù)子函數(shù)代碼
  1. void TIM3_IRQHandler(void)   //TIM3中斷
  2. {
  3.         if (TIM_GetITStatus(TIM3, TIM_IT_Update) == SET) //檢查指定的TIM中斷發(fā)生與否:TIM 中斷源
  4.                 {TIM_ClearITPendingBit(TIM3, TIM_IT_Update);
  5.                         time++;
  6.                         TIM_ClearITPendingBit(TIM3, TIM_IT_Update);  //清除TIMx的中斷待處理位:TIM 中斷源
  7.
  8.                 }
  9.         }
ID:161164 發(fā)表于 2023-5-11 10:16 | 顯示全部樓層
ID:1073299 發(fā)表于 2023-5-11 10:19 | 顯示全部樓層
你的LED接線有問(wèn)題,一直與電源連接。正確的做法是這樣的
ID:1076644 發(fā)表于 2023-5-11 13:16 | 顯示全部樓層
xuyaqi 發(fā)表于 2023-5-11 06:40
初始化的是PA3,不是PA5.
抱歉哈抱歉  但是我把GPIO改成了5口 還是不行
ID:1076644 發(fā)表于 2023-5-11 13:22 | 顯示全部樓層
wydev 發(fā)表于 2023-5-11 10:19
我把led接地的線取消了 但是燈不亮了
ID:1077231 發(fā)表于 2023-5-13 14:45 | 顯示全部樓層
你預(yù)分頻系數(shù)7200,TIM_Period應(yīng)該設(shè)為7199吧,這樣的話TIM_Prescaler為1000就大概是1秒觸發(fā)一次TIM3。這樣你在TIM3_IRQHandler里面,每進(jìn)入一次就反轉(zhuǎn)燈的狀態(tài)就可以了。另外你的time變量聲明為extern了吧,
如果我沒(méi)有看錯(cuò),那么你原來(lái)的寫(xiě)法,可能要100秒才觸發(fā)一次反轉(zhuǎn)。
ID:77589 發(fā)表于 2023-5-15 11:38 | 顯示全部樓層
TIM3的初始化有點(diǎn)問(wèn)題
按你的參數(shù),中斷一次需要,需要10s,要看效果需要耐心等一下。
可以把定時(shí)周期的10000-1改成1000-1,就1S中斷一次了。
ID:1076644 發(fā)表于 2023-5-15 18:13 | 顯示全部樓層
BonizLee 發(fā)表于 2023-5-13 14:45
你預(yù)分頻系數(shù)7200,TIM_Period應(yīng)該設(shè)為7199吧,這樣的話TIM_Prescaler為1000就大概是1秒觸發(fā)一次TIM3。這樣 ...
我把time給去了 然后把分頻系數(shù)也改了  然后燈還是不亮  是我GPIO口設(shè)置的問(wèn)題么
ID:1076644 發(fā)表于 2023-5-15 18:16 | 顯示全部樓層
Longan.Wang 發(fā)表于 2023-5-15 11:38
我把這行關(guān)閉的注釋掉,然后就是燈還是不亮  就感覺(jué)不僅沒(méi)進(jìn)中斷,GPIO我看著也沒(méi)問(wèn)題啊
ID:77589 發(fā)表于 2023-5-17 15:49 | 顯示全部樓層
你原來(lái)的程序,大概需要10s才中斷一次,你在主程序中又做了1000的計(jì)數(shù),就相當(dāng)把時(shí)間又?jǐn)U大了1000倍,就是10000s才能改變LED狀態(tài),大概是2.7777777777777777777777777777778小時(shí),在軟件上仿真更慢,就慢慢的等吧!
可以把LED取反輸出放在中斷響應(yīng)程序里試試。
