- void ST7735_INITIAL ()
- //------------------------------------ST7735R Reset Sequence-----------------------------------------//
- RES =1;
- delay (1); //Delay 1ms
- RES =0;
- RES =1;
- delay (120); //Delay 120ms
- //--------------------------------End ST7735R Reset Sequence --------------------------------------//
- //--------------------------------End ST7735S Reset Sequence --------------------------------------//
- LCD_WriteCommand(0x11); //Sleep out
- delay(120); //Delay 120ms
- //------------------------------------ST7735S Frame Rate-----------------------------------------//
- LCD_WriteCommand(0xB1);
- LCD_WriteData(0x05);
- LCD_WriteData(0x3C);
- LCD_WriteCommand(0xB2);
- LCD_WriteCommand(0xB3);
- //------------------------------------End ST7735S Frame Rate---------------------------------//
- LCD_WriteCommand(0xB4); //Dot inversion
- LCD_WriteData(0x03);
- //------------------------------------ST7735S Power Sequence---------------------------------//
- LCD_WriteCommand(0xC0);
- LCD_WriteData(0x28);
- LCD_WriteData(0x08);
- LCD_WriteData(0x04);
- LCD_WriteCommand(0xC1);
- LCD_WriteData(0XC0);
- LCD_WriteCommand(0xC2);
- LCD_WriteData(0x0D);
- LCD_WriteData(0x00);
- LCD_WriteCommand(0xC3);
- LCD_WriteData(0x8D);
- LCD_WriteData(0x2A);
- LCD_WriteCommand(0xC4);
- LCD_WriteData(0xEE);
- //---------------------------------End ST7735S Power Sequence-------------------------------------//
- LCD_WriteCommand(0xC5); //VCOM
- LCD_WriteData(0x1A);
- LCD_WriteCommand(0x36); //MX, MY, RGB mode
- LCD_WriteData(0xC0);
- //------------------------------------ST7735S Gamma Sequence---------------------------------//
- LCD_WriteCommand(0xE0);
- LCD_WriteData(0x22);
- LCD_WriteData(0x07);
- LCD_WriteData(0x0A);
- LCD_WriteData(0x2E);
- LCD_WriteData(0x30);
- LCD_WriteData(0x25);
- LCD_WriteData(0x26);
- LCD_WriteData(0x3A);
- LCD_WriteData(0x01);
- LCD_WriteData(0x13);
- LCD_WriteCommand(0xE1);
- LCD_WriteData(0x16);
- LCD_WriteData(0x06);
- LCD_WriteData(0x2D);
- LCD_WriteData(0x23);
- LCD_WriteData(0x27);
- LCD_WriteData(0x3B);
- //------------------------------------End ST7735S Gamma Sequence-----------------------------//
- LCD_WriteCommand(0x3A); //65k mode
- LCD_WriteCommand(0x29); //Display on
- Void ST7735SCPT144PanelTurnOnDisplay (void)
- Write(COMMAND,0x29); //Display on
- Void ST7735SCPT144PanelTurnOffDisplay (void)
- Write(COMMAND,0x28); //Display off
- Void ST7735SCPT144PanelTurnOnPartial (void)
- Write(COMMAND,0x30); //Setup the partial area
- Write(DATA,0x00);
- Write(DATA,PSL); //PSL:Start Line
- Write(DATA,0x00);
- Write(DATA,PEL); //PEL:End Line
- Write(COMMAND,0x12); //Turn on partial mode
- Void ST7735SCPT144PanelTurnOffPartial (void)
- Write(COMMAND,0x13); //Turn off partial mode
- Void ST7735SCPT144PanelTurnOnIdle (void)
- Write(COMMAND,0x39); //Turn on idle mode
- Void ST7735SCPT144PanelTurnOffIdle (void)
- Write(COMMAND,0x38); // Turn off idle mode
- Void ST7735SCPT144PanelSleepInMode (void)
- Write(COMMAND,0x10); //Sleep in
- Delayms (120); //Delay 120ms
- Void ST7735SCPT144PanelSleepOutMode (void)
- Write(COMMAND,0x11); //Sleep out
