查看: 1163|回復(fù): 1
stc12c5204ad,關(guān)于串口的問題。
就是想實(shí)現(xiàn)電腦發(fā)數(shù)據(jù)然后單片機(jī)數(shù)碼管上面顯示相應(yīng)的數(shù)字。遇到瓶頸了。單片機(jī)是STC12C5204AD
U16~U19是LS145 芯片。這個(gè)是我敲的代碼但是運(yùn)行結(jié)果不對,不懂是不是寫錯(cuò)了。
附帶原理圖請大神們指教。
#include<reg51.h>
#include "intrins.h"
#define uchar unsignedchar
unsigned char senddata;
unsigned char seg[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x00};
void delayms(unsigned int k);
void Deng();
void Smg();
void Nixie(unsigned char L,N)
    switch(L)
        case 1:P3=0x08;break;
        case 2:P3=0x0c;break;
        case 3:P3=0x10;break;
        case 4:P3=0x14;break;
        case 5:P3=0x20;break;
        case 6:P3=0x24;break;
        case 7:P3=0x28;break;
        case 8:P3=0x2c;break;
        case 9:P3=0x30;break;
        case 10:P3=0x34;break;
        case 11:P3=0x38;break;
        case 12:P3=0x3c;break;
    P1=seg[N];
    P2=seg[N];
    delayms(1);
    P1=0x00;
    P2=0x00;
void Deng()   //燈
        P1=0X00;
        P2=0X00;
        P3=0x30;
        delayms(1);
        P1=0X00;
        P3=0x34;
        delayms(1);
        P1=0X00;
        P2=0X00;
        P3=0x38;
        delayms(1);
        P3=0x3c;
        P1=0x00;
        delayms(1);
void Smg()  //數(shù)碼管
        Nixie(1,1);
        delayms(1);
        Nixie(2,2);
        delayms(1);
        Nixie(3,3);
        delayms(1);
        Nixie(4,4);
        delayms(1);
        Nixie(5,5);
        delayms(1);
        Nixie(6,6);
        delayms(1);
        Nixie(7,7);
        delayms(1);
        Nixie(8,8);
        delayms(1);
void InitializeSystem()   //串口初始化,波特率9600
        SCON = 0X50;//串口方式1,允許接收
        TMOD = 0X20;//定時(shí)器1定時(shí)方式2
        TCON = 0x40;//設(shè)定時(shí)器1開始計(jì)數(shù)
        TH1 = TL1 = 250;
        PCON = 0x80; //波特率加倍控制,SMOD位
        RI = 0; //清收發(fā)標(biāo)志
        TI = 0;
        TR1 = 1; //啟動(dòng)定時(shí)器
        EA=1;                //開啟總中斷
        ES = 1;
        ET1=0;
   //字符發(fā)送函數(shù)
void putchar(unsigned char data1)
        SBUF = data1;               //將待發(fā)送的字符送入發(fā)送緩沖器
        while(TI == 0);            //等待發(fā)送完成
        TI = 0;                     //發(fā)送中斷標(biāo)志請0
//字符串發(fā)送函數(shù)
void putstring(unsigned char *dat)
        while(*dat != '\0')           //判斷字符串是否發(fā)送完畢
                putchar(*dat);        //發(fā)送單個(gè)字符
                dat++;                 //字符地址加1,指向先下一個(gè)字符
                delayms(1);
//接收中斷函數(shù)
void revdata(void) interrupt 4
        if(RI == 0) return;         //如果沒有接收中斷標(biāo)志,返回
        ES = 0;            //關(guān)閉串口中斷
        RI = 0;            //清串行中斷標(biāo)志位
        senddata=SBUF;
        ES = 1;                 //開啟串口中斷
void main(void)
     InitializeSystem( );
        if(senddata=='1')
        Nixie(1,1);
        unsigned char data i, j;
    while(k--)
        i = 22;
        j = 128;
        do
                while (--j);
        } while (--i);
Schematic_顯示板_2023-05-29.pdf
183.99 KB, 下載次數(shù): 3
ID:276663 發(fā)表于 2023-6-1 22:52 | 只看該作者
nixie傳入?yún)?shù)的方式不對,(unsigned char L, unsigned char N)
