查看: 2048|回復(fù): 2
51單片機(jī)播放歌曲起風(fēng)了源程序
         #include <reg51.h>
sbit voice=P1^5;   //單片機(jī)開發(fā)板型號(hào)不同需要修改為所對(duì)應(yīng)的蜂鳴器管腳
uchar code sound[]={0xff,
                    0x2b,0x30,0x30,0x10,0x2b,0x30,0x30,0x10,0x2b,0x20,0x26,0x20,0x20,0x20,
                    0x26,0x20,0x2b,0x30,0x30,0x10,0x2b,0x30,0x30,0x10,0x2b,0x10,0x26,0x10,
                    0x2b,0x10,0x30,0x10,0x40,0x20,0x40,0x20,0x2b,0x30,0x30,0x10,0x2b,0x30,
                    0x30,0x10,0x2b,0x20,0x26,0x20,0x20,0x20,0x26,0x20,0x2b,0x30,0x26,0x10,
                    0x2b,0x20,0x30,0x20,0x2b,0x20,0x2b,0x20,0xff,0x20,0xff,0x20,0x2b,0x30,
                                        0x30,0x10,0x2b,0x30,0x30,0x10,0x2b,0x20,0x26,0x20,0x20,0x20,0x26,0x20,
                                        0x2b,0x30,0x26,0x10,0x2b,0x20,0x30,0x20,0x39,0x20,0x39,0x20,0x26,0x10,
                                        0x2b,0x10,0x30,0x10,0x2b,0x10,0x30,0x20,0x30,0x20,0x26,0x10,0x2b,0x10,
                                        0x30,0x10,0x2b,0x10,0x30,0x30,0x20,0x10,0x26,0x10,0x2b,0x10,0x30,0x10,
                                        0x2b,0x10,0x30,0x20,0x30,0x20,0x30,0x20,0x2b,0x20,0x26,0x20,0x30,0x20,0x1c,0x20,0x20,0x10,0x1c,0x10,
                    0x1c,0x30,0x30,0x10,0x19,0x20,0x1c,0x10,0x19,0x10,0x19,0x20,0x19,0x20,
                    0x1c,0x10,0x19,0x10,0x19,0x20,0x26,0x20,0x18,0x10,0x15,0x10,0x18,0x10,
                    0x19,0x10,0x1c,0x20,0x20,0x20,0x1c,0x20,0x20,0x10,0x1c,0x10,0x1c,0x10,
                    0x20,0x10,0x1c,0x10,0x20,0x10,0x1c,0x20,0x20,0x10,0x2b,0x10,0x2b,0x10,
                    0x20,0x20,0x20,0x10,0x26,0x20,0x26,0x20,0x30,0x20,0x2b,0x20,0x26,0x20,
                    0x30,0x20,0x1c,0x20,0x20,0x10,0x1c,0x10,0x1c,0x30,0x30,0x10,0x19,0x20,
                    0x1c,0x10,0x19,0x10,0x19,0x20,0x19,0x20,0x1c,0x10,0x19,0x10,0x19,0x20,
                    0x26,0x20,0x18,0x10,0x15,0x10,0x18,0x10,0x19,0x10,0x1c,0x20,0x20,0x20,
                    0x1c,0x20,0x13,0x10,0x13,0x10,0x13,0x20,0x20,0x20,0x1c,0x20,0x13,0x10,
                    0x13,0x10,0x13,0x10,0x20,0x20,0x1c,0x10,0x1c,0x20,0x1c,0x20,0x1c,0x20,
                    0x1c,0x20,0xff,0x20,0xff,0x20,  0x18,0x20,0x15,0x20,0x13,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,0x0e,0x10,
                    0x10,0x10,0x10,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,0x19,0x10,0x18,0x10,
                    0x18,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,
                    0x0e,0x10,0x10,0x10,0x10,0x10,0x13,0x30,0x15,0x20,0x18,0x10,0x1c,0x10,
                    0x1c,0x10,0x18,0x20,0x1c,0x10,0x15,0x10,0x18,0x10,0x1c,0x20,0x1c,0x10,
                    0x18,0x30,0x13,0x20,0x13,0x20,0x13,0x10,0x12,0x10,0x13,0x20,0x13,0x10,
                    0x15,0x20,0xff,0x20,0xff,0x20,0x18,0x20,0x15,0x20,0x13,0x20,0x0e,0x10,0x10,0x10,
                    0x10,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,
                    0x15,0x20,0x13,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,0x0e,0x10,0x10,0x10,
                    0x10,0x20,0x0e,0x10,0x10,0x10,0x10,0x10,0x13,0x30,0x15,0x20,0x18,0x10,
                    0x1c,0x10,0x1c,0x10,0x13,0x30,0x15,0x20,0x18,0x10,0x1c,0x10,0x1c,0x10,
                    0x18,0x30,0x18,0x20,0x18,0x20,0xff,0x20,0xff,0x20,0x1c,0x10,0x13,0x10,
                    0x15,0x20,0x18,0x10,0x1c,0x10,0x1c,0x10,0x13,0x30,0x15,0x20,0x18,0x10,
                    0x1c,0x10,0x1c,0x10,0x18,0x30,0x18,0x20,0x18,0x20,0x18,0x20,0x18,0x20,0x00,
uchar zdjs=0, jp;
del(yj);
void main(void)
      uint dpjs=0;
      uchar yj;
      TMOD=0x01,IE=0x82;
      TH0=0xd8, TL0=0xef;
   TR0=1;
      zdjs=0;
      dpjs++; yj=sound[dpjs];
     dpjs++; jp=sound[dpjs];
   while(zdjs!=jp)
      if(yj!=0xff)
             if(yj!=0)
             voice=!voice;
                 del(yj);
          dpjs=0;
                      break;
        voice=0;
                 del(jp);
time0() interrupt 1  using 1
         TH0=0xd8, TL0=0xef;
         zdjs++;
del(yj)
      uchar yj2=2;
       while(yj!=0)
               while(yj2!=0)
                     yj2--;
                  yj2=2;
             yj--;
屏幕截圖 2023-06-28 101255.png (55.92 KB, 下載次數(shù): 52)
ID:1064915 發(fā)表于 2023-6-30 19:50 | 只看該作者
H(59): error C100: unprintable character 0xA1 skipped
ID:1086293 發(fā)表于 2023-7-3 15:25 | 只看該作者
joyb 發(fā)表于 2023-6-30 19:50
