void Reset()
num1 = 0;
num2 = 0;
step = 0;
LcdFullClear();
/* 數(shù)字鍵動作函數(shù),n-按鍵輸入的數(shù)值 */
void NumKeyAction(unsigned char n)
unsigned char len;
unsigned char str[12];
if (step > 1) //如計算已完成,則重新開始新的計算
Reset();
if (step == 0) //輸入第一操作數(shù)
num1 = num1*10 + n; //輸入數(shù)值累加到原操作數(shù)上
len = LongToString(str, num1); //新數(shù)值轉(zhuǎn)換為字符串
LcdShowStr(16-len, 1, str); //顯示到液晶第二行上
else //輸入第二操作數(shù)
num2 = num2*10 + n; //輸入數(shù)值累加到原操作數(shù)上
len = LongToString(str, num2); //新數(shù)值轉(zhuǎn)換為字符串
問:執(zhí)行完 if (step > 1)
Reset();
} 之后要直接執(zhí)行if (step == 0)
num1 = num1*10 + n;
}這個if嗎
