查看: 1380|回復(fù): 3
STM32F103CBT6單片機(jī)與CAN通信,無(wú)法接收
ID:1078313 發(fā)表于 2023-7-10 13:36 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
用的cbt6調(diào)試can,可以幫我看一下驅(qū)動(dòng)程序有什么問(wèn)題嗎?125MHZ的雙機(jī)通信
  1. #include "stm32f10x.h"
  2. #include "./led/bsp_led.h"
  3. #include "./can/bsp_can.h"
  4. __IO uint32_t flag = 0;
  5. CanTxMsg TxMessage;
  6. CanRxMsg RxMessage;
  7. static void can_delay(__IO u32 nCount)
  8. {
  9.         for(; nCount != 0; nCount--);
  10. }
  11. int main(void)
  12. {
  13.         LED_GPIO_Config();
  14.         CAN_Config();
  15.   while(1)
  16.         {
  17.                         uint8_t m;
  18.
  19.             LED1_ON;
  20.                   LED3_ON;
  21.                         CAN_SetMsg(&TxMessage);
  22. m=CAN_Transmit(CANx, &TxMessage);
  23.          if(CAN_TransmitStatus(CANx,m)==CAN_TxStatus_Ok)
  24.          {
  25.                         LED1_OFF;
  26.          }
  27.                         can_delay(10000);
  28.                 if(flag==1)
  29.                 {
  30.                         LED1_TOGGLE;
  31.                         flag=0;
  32.                 }
  33.         }
  34. }
  1. #include "./can/bsp_can.h"
  2. static void CAN_GPIO_Config(void)
  3. {
  4.          GPIO_InitTypeDef GPIO_InitStructure;
  5.   /* Enable GPIO clock */
  6.   RCC_APB2PeriphClockCmd(CAN_TX_GPIO_CLK|CAN_RX_GPIO_CLK, ENABLE);
  7. //        //ÖØÓ³ÉäÒý½Å
  8. //        GPIO_PinRemapConfig(GPIO_Remap1_CAN1, ENABLE);
  9.          /* Configure CAN TX pins */
  10.   GPIO_InitStructure.GPIO_Pin = CAN_TX_PIN;
  11.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  12.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  13.   GPIO_Init(CAN_TX_GPIO_PORT, &GPIO_InitStructure);
  14.
  15.         /* Configure CAN RX  pins */
  16.   GPIO_InitStructure.GPIO_Pin = CAN_RX_PIN ;
  17.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  18.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  19.   GPIO_Init(CAN_RX_GPIO_PORT, &GPIO_InitStructure);
  20. }
  21. static void CAN_NVIC_Config(void)
  22. {
  23.            NVIC_InitTypeDef NVIC_InitStructure;
  24.     /* Configure one bit for preemption priority */
  25.     NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  26.     /*ÖжÏÉèÖÃ*/
  27.     NVIC_InitStructure.NVIC_IRQChannel = CAN_RX_IRQ;
  28.     NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  29.     NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  30.     NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  31.     NVIC_Init(&NVIC_InitStructure);
  32. }
  33. /*
  34. * º¯ÊýÃû£ºCAN_Mode_Config
  35. * ÃèÊö  £ºCANµÄģʽ ÅäÖÃ
  36. * ÊäÈë  £ºÎÞ
  37. * Êä³ö  : ÎÞ
  38. * µ÷Óà £ºÄÚ²¿µ÷ÓÃ
  39. */
  40. static void CAN_Mode_Config(void)
  41. {
  42.         CAN_InitTypeDef        CAN_InitStructure;
  43.
  44.         /* Enable CAN clock */
  45.   RCC_APB1PeriphClockCmd(CAN_CLK, ENABLE);
  46.         /*CAN¼Ä´æÆ÷³õʼ»¯*/
  47.         CAN_DeInit(CANx);
  48.         CAN_StructInit(&CAN_InitStructure);
  49.         /*CANµ¥Ôª³õʼ»¯*/
  50.         CAN_InitStructure.CAN_TTCM=DISABLE;
  51.         CAN_InitStructure.CAN_ABOM=DISABLE;
  52.         CAN_InitStructure.CAN_AWUM=ENABLE;
  53.         CAN_InitStructure.CAN_NART=DISABLE;
  54.         CAN_InitStructure.CAN_RFLM=DISABLE;
  55.         CAN_InitStructure.CAN_TXFP=ENABLE;
  56.         CAN_InitStructure.CAN_Mode = CAN_Mode_Normal
  57.         CAN_InitStructure.CAN_SJW=CAN_SJW_1tq;
  58.         CAN_InitStructure.CAN_BS1=CAN_BS1_10tq
  59.         CAN_InitStructure.CAN_BS2=CAN_BS2_5tq
  60.         CAN_InitStructure.CAN_Prescaler =18
  61.         CAN_Init(CANx, &CAN_InitStructure);
  62. }
在中斷里接受
  1. extern __IO uint32_t flag ;
  2. extern CanRxMsg RxMessage;
  3. void CAN_RX_IRQHandler(void)
  4. {
  5.
  6.         CAN_Receive(CANx, CAN_FIFO0, &RxMessage);
  7.
  8.         if((RxMessage.ExtId==0x1314) && (RxMessage.IDE==CAN_ID_EXT)  )//&& (RxMessage.DLC==8)
  9.         {
  10.         flag = 1;
  11.         }
  12.         else
  13.         {
  14.         flag = 0;
  15.         }
  16. }
ID:111463 發(fā)表于 2023-7-10 15:45 | 只看該作者
請(qǐng)確認(rèn) 兩者設(shè)置條件一致,從描述上來(lái)看 125MHZ?這是不可能達(dá)到的通信速率,主頻一般都不能超過(guò)72Mhz
ID:1078313 發(fā)表于 2023-7-10 16:26 | 只看該作者
sbskywalker 發(fā)表于 2023-7-10 15:45
STM32的can的最大速率不是可以達(dá)到1MHZ嗎?
ID:1078313 發(fā)表于 2023-7-10 16:28 | 只看該作者
程序里應(yīng)該是125khz
