查看: 1248|回復(fù): 0
STM32F030+SD2405+24C08+SD卡
ID:35191 發(fā)表于 2023-7-20 20:51 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. #include "my.h"
  2. #include "24C08.h"
  3. #include "SD2405.h"
  4. #include "led.h"
  5. FRESULT write_TF(FIL fsr,char *namebuf,uint8_t *databuf,uint32_t len,uint16_t lseek,uint8_t location)
  6. {
  7.
  8.         FRESULT res1;
  9.   UINT bw;
  10.
  11.         res1=f_open(&fsr,namebuf,FA_OPEN_ALWAYS | FA_WRITE);
  12.         switch (location)
  13.         {
  14.                 case 0 ://指定位置
  15.                         res1=f_lseek(&fsr,lseek);
  16.                         break;
  17.                 case 1 :        //從頭
  18.                   break;
  19.                 case 2 :        //至尾
  20.                         res1=f_lseek(&fsr,fsr.fsize);
  21.                   break;
  22.     default:
  23.                   break;
  24.         }
  25.         res1 = f_write(&fsr,databuf,len,&bw);
  26.   res1 = f_close(&fsr);
  27.         return res1;
  28. }
  29. uint32_t FileSize;
  30. FRESULT read_TF(FIL fsr,char *namebuf,uint8_t *databuf,uint32_t len,uint16_t lseek,uint8_t location)
  31. {
  32.
  33.         uint32_t Datalen;
  34.         FRESULT res1;
  35.   UINT br;
  36.
  37.         res1=f_open(&fsr,namebuf,FA_READ);
  38.         FileSize=f_size(&fsr);
  39.         switch (location)
  40.         {
  41.                 case 0 :        //指定位置
  42.                         res1=f_lseek(&fsr,lseek);
  43.                         break;
  44.                 case 1 :        //從頭
  45.                   break;
  46.                 case 2 :          //至尾
  47.                         res1=f_lseek(&fsr,fsr.fsize);
  48.                   break;
  49.     default:
  50.                   break;
  51.         }
  52.         if(len==0)
  53.     Datalen=FileSize;
  54.         else
  55.                 Datalen=len;
  56.
  57.         res1 = f_read(&fsr,databuf,Datalen,&br);
  58.   res1 = f_close(&fsr);
  59.         return res1;
  60. }
  61. ///////////////////////////////////////////////////////////////
  62. //channel=0:串口1,time15定時時間
  63. //channel=1:串口2,time16定時時間
  64. //channel=2:深度數(shù)據(jù),淺-米
  65. //channel=3:深度數(shù)據(jù),深-米
  66. extern uint32_t Time_PT[2];
  67. extern uint32_t Work_Time[4];
  68. uint16_t usart_readtime(uint8_t channel,uint8_t *buf)
  69. {
  70.         uint8_t i;
  71.         uint16_t data;
  72.         uint32_t sum;
  73.         uint16_t temp;
  74.
  75.         if(channel<2)
  76.         {
  77.                 sum=(buf[4*channel+0]*60*60+buf[4*channel+1]*60+buf[4*channel+2])*1000+buf[4*channel+3]*10;
  78.                 if(sum>10)
  79.                 {
  80.                         Time_PT[channel]=sum/10;
  81.                         data=10;
  82.                 }
  83.                 else
  84.                 {
  85.                         data=sum;
  86.                 }
  87.         }
  88.         else if(2<=channel && channel<=3)
  89.         {
  90.                 temp=(buf[2*(channel-2)+8]<<8) + buf[2*(channel-2)+9];
  91.                 data=temp;
  92.         }
  93.         else if(channel>3)
  94.         {
  95.                 channel=4;
  96.                 for(i=0;i<2;i++)
  97.                 {
  98.                         Work_Time[2*(channel+i-4)]=buf[4*(channel+i-1)]*100+buf[4*(channel+i-1)+1]; //12,13   16,17
  99.                         Work_Time[2*(channel+i-4)+1]=buf[4*(channel+i-1)+2]*100+buf[4*(channel+i-1)+3];//14,15   18,19
  100.                 }
  101.                 data=0;
  102.         }
  103.         return data;
  104. }
  105. extern int32_t depth_data; //厘米的深度數(shù)據(jù),除以100是米,除以10000是mpa。
  106. extern int16_t depth_temp; //水溫數(shù)據(jù),3位小數(shù)點,單位℃。
  107. //出口:depth_temp  = 水溫數(shù)據(jù)
  108. //      depth_data  = 壓力數(shù)據(jù)
  109. void temper_dep(uint8_t *databuf)
  110. {
  111.   uint8_t state2;
  112.         uint8_t c2;
  113.         uint8_t buf[8];
  114.
  115.         signed long L32;
  116.
  117.
  118.         //2-18的數(shù)字取出并累加
  119.         state2=0;
  120.         for(c2=2;c2<USART1_RX_MAX-3;c2++)
  121.         {
  122.                 state2 = state2 + (databuf[c2]-48);//0x30
  123.         }
  124.
  125.         //接收的累加和
  126.         buf[0]= databuf[USART1_RX_MAX-3]-48;//百位
  127.         buf[1]= databuf[USART1_RX_MAX-2]-48;//十位
  128.         buf[2]= databuf[USART1_RX_MAX-1]-48;//個位
  129.         c2=(buf[0]*100)+(buf[1]*10)+buf[2];
  130.         if(state2==c2)
  131.         {
  132.                 //與接收的ASCII累加和相等
  133.                 //取出地址
  134.                 buf[0]= databuf[2]-48;//地址十位
  135.                 buf[1]= databuf[3]-48;//地址個位
  136.                 buf[2]= buf[0]*10+buf[1];
  137.                 if(buf[2]==DEPTH_TEMP_ADD)//地址=1
  138.                 {
  139.                         //取出壓力值和標志
  140.                         state2 = databuf[4]-48;//取出壓力正負標志
  141.
  142.                         buf[0]=databuf[5]-48;//壓力千位
  143.                         buf[1]=databuf[6]-48;//壓力百位
  144.                         buf[2]=databuf[7]-48;//壓力十位
  145.                         buf[3]=databuf[8]-48;//壓力個位
  146.                         buf[4]=databuf[9]-48; //小數(shù)1位
  147.                         buf[5]=databuf[10]-48;//小數(shù)2位
  148.                         buf[6]=databuf[11]-48;//小數(shù)3位
  149.                         buf[7]=databuf[12]-48;//小數(shù)4位
  150.
  151.                         L32 = (long)((buf[0]*10000000)+(buf[1]*1000000)+(buf[2]*100000)
  152.                                 +(buf[3]*10000)+(buf[4]*1000)+(buf[5]*100)+(buf[6]*10)+buf[7]);
  153.
  154.
  155.                         depth_data=L32;         //壓力數(shù)據(jù)
  156.                         if(state2==1)//壓力正負標志,00=正數(shù),01=負數(shù)
  157.                         {
  158.                                 depth_data = ~depth_data+1;//轉(zhuǎn)換為負數(shù)
  159.                         }
  160.                         //取出溫度值和標志
  161.                         state2 = databuf[13]-48;//取出溫度正負標志
  162.
  163.                         buf[0]=databuf[14]-48;//溫度十位
  164.                         buf[1]=databuf[15]-48;//溫度個位
  165.                         buf[2]=databuf[16]-48;//溫度小數(shù)1
  166.                         buf[3]=databuf[17]-48;//溫度小數(shù)2
  167.                         buf[4]=databuf[18]-48;//溫度小數(shù)3
  168.
  169.                         L32 = (long)((buf[0]*10000)+(buf[1]*1000)+(buf[2]*100)+(buf[3]*10)+buf[4]);
  170.
  171.                         depth_temp = L32;
  172.                         if(state2==1)//水溫度正負標志,00=正數(shù),01=負數(shù)
  173.                         {
  174.                                 depth_temp = ~depth_temp+1;//轉(zhuǎn)換為負數(shù)
  175.                         }
  176.                 }
  177.         }
  178. }
  179. FRESULT storage(FIL fsr,Time_Def *timebuf,uint8_t channel)
  180. {
  181.         FRESULT res1;
  182.         uint8_t databuf[12];
  183.         char filebuf[13];
  184.
  185.   //RTC_GetRTCTime(timebuf);
  186.         RTC_ReadDate(timebuf);
  187.         if(channel==0)
  188.         {
  189.                 filebuf[0]=timebuf->Year/16+48;
  190.                 filebuf[1]=timebuf->Year%16+48;
  191.                 filebuf[2]=timebuf->Month/16+48;
  192.                 filebuf[3]=timebuf->Month%16+48;
  193.                 filebuf[4]=timebuf->Day/16+48;
  194.                 filebuf[5]=timebuf->Day%16+48;
  195.                 filebuf[6]=timebuf->Hour/16+48;
  196.                 filebuf[7]=timebuf->Hour%16+48;
  197.                 filebuf[8]='.';
  198.                 filebuf[9]='t';
  199.                 filebuf[10]='x';
  200.                 filebuf[11]='t';
  201.                 filebuf[12]='\0';
  202.
  203.                 databuf[0]=0Xff;
  204.                 databuf[1]=0Xfa;
  205.                 databuf[2]=timebuf->Minute;
  206.                 databuf[3]=timebuf->Second;
  207.
  208.                 databuf[4]=depth_data >> 24;
  209.                 databuf[5]=depth_data >> 16;
  210.                 databuf[6]=depth_data>> 8;
  211.                 databuf[7]=depth_data;
  212.                 databuf[8]=depth_temp>> 8;
  213.                 databuf[9]=depth_temp;
  214.                 databuf[10]=0Xfa;
  215.                 databuf[11]=0Xff;
  216.
  217.                 res1=write_TF(fsr,filebuf,databuf,12,0,2);
  218.         }
  219.         if(channel==1)
  220.         {
  221.         }
  222.         return res1;
  223. }
  224. extern uint8_t Wrong_buf[5];
  225. void Modbus_0X10_EEPROM(uint8_t *buf,uint16_t len)
  226. {
  227.         uint8_t i;
  228.         uint8_t databuf1[20];
  229.         uint8_t databuf2[20];
  230.
  231.         for(i=0;i<6;i++)
  232.                 databuf2[i]=buf[i];
  233.         CrcCheck(databuf2,6);
  234.
  235.         if(buf[2]==0)
  236.         {
  237.                 for(i=0;i<buf[6];i++)
  238.                  databuf1[i]=buf[i+7];
  239.
  240.                 EEPROM_Write(buf[3],databuf1,buf[6]);
  241.                 USART_SendBuffDat(USART4,databuf2,8);
  242.         }
  243.         else
  244.         {
  245.                 if(buf[5]==3 && buf[6]==6)
  246.                 {
  247.                         time_init.Year=buf[7];
  248.                         time_init.Month=buf[8];
  249.                         time_init.Day=buf[9];
  250.                         time_init.Week=0x01;
  251.                         time_init.Hour=buf[10];
  252.                         time_init.Minute=buf[11];
  253.                         time_init.Second=buf[12];
  254.
  255.                         RTC_WriteDate(&time_init);
  256.
  257.                         USART_SendBuffDat(USART4,databuf2,8);
  258.                 }
  259.                 else
  260.                 {
  261.                         USART_SendBuffDat(USART4,Wrong_buf,sizeof(Wrong_buf));
  262.                 }
  263.         }
  264. }
  265. void Modbus_0X03_EEPROM(uint8_t *buf,uint16_t len)
  266. {
  267.         uint8_t i;
  268.         uint8_t databuf1[20];
  269.         uint8_t databuf2[20];
  270.
  271.         databuf2[0]=buf[0];
  272.         databuf2[1]=buf[1];
  273.         databuf2[2]=buf[5]*2;
  274.
  275.         if(buf[2]==0)
  276.         {
  277.                 EEPROM_Read(buf[3],databuf1,buf[5]*2);
  278.                 //delay_ms(10);
  279.           for(i=0;i<buf[5]*2;i++)
  280.                         databuf2[3+i]=databuf1[i];
  281.
  282.                 CrcCheck(databuf2,buf[5]*2+3);
  283.           USART_SendBuffDat(USART4,databuf2,buf[5]*2+5);
  284.         }
  285.         else
  286.         {
  287.     if(buf[5]*2==6)
  288.                 {
  289.                         RTC_ReadDate(&sysTime);
  290.                         databuf1[0]=sysTime.Year;
  291.                         databuf1[1]=sysTime.Month;
  292.                         databuf1[2]=sysTime.Day;
  293.                         databuf1[3]=sysTime.Hour;
  294.                         databuf1[4]=sysTime.Minute;
  295.                         databuf1[5]=sysTime.Second;
  296.
  297.                         for(i=0;i<buf[5]*2;i++)
  298.                           databuf2[3+i]=databuf1[i];
  299.
  300.                   CrcCheck(databuf2,buf[5]*2+3);
  301.             USART_SendBuffDat(USART4,databuf2,buf[5]*2+5);
  302.                 }
  303.                 else
  304.                 {
  305.                         USART_SendBuffDat(USART4,Wrong_buf,sizeof(Wrong_buf));
  306.                 }
  307.         }
  308. }
  309. extern uint8_t BD_SendBuf[UART_BUFF_MAX_SIZE];
  310. extern uint8_t Right_buf[5];
  311. extern uint8_t Wrong_buf[5];
  312. uint8_t BD_Return(char *buf,uint16_t len)
  313. {
  314.
  315.         uint8_t i;
  316.
  317.         if(buf[0]=='
  318. 僅供參考: 代碼.7z (664 KB, 下載次數(shù): 15)
  319. && buf[59]=='\r' && buf[60]=='\n')//$DWXX,21/12/09,04:59:29,121.532003,E,31.079860,N,24,8,0.00\r\n
  320.         {
  321.
  322.                 time_init.Year=(buf[6]-48)*16+(buf[7]-48);
  323.                 time_init.Month=(buf[9]-48)*16+(buf[10]-48);
  324.                 time_init.Day=(buf[12]-48)*16+(buf[13]-48);
  325.                 time_init.Week=0x01;
  326.                 time_init.Hour=(buf[15]-48)*16+(buf[16]-48);
  327.                 time_init.Minute=(buf[18]-48)*16+(buf[19]-48);
  328.                 time_init.Second=(buf[21]-48)*16+(buf[22]-48);
  329.                 RTC_WriteDate(&time_init);
  330.
  331.                 BD_SendBuf[8]=0x22;
  332.                 for(i=0;i<len-6;i++)
  333.                   BD_SendBuf[9+i]=buf[i];
  334.
  335.                 BD_SendBuf[9+len-6]=0x22;
  336.                 BD_SendBuf[9+len-5]=0x0D;
  337.                 BD_SendBuf[9+len-4]=0x0A;
  338.                 delay_ms(50);
  339.                 USART_SendBuffDat(USART2,BD_SendBuf,len+12-6);  //AT+SEND="$DWXX,21/12/09,04:59:29,121.532003,E,31.079860,N,24,8,0.00"\r\n
  340.                 USART_SendBuffDat(USART4,Right_buf,sizeof(Right_buf));
  341.                 return 0;
  342.         }
  343.
  344.         else if(!strncmp(buf,"NO EFFECTIVE LOCATION INFORMATION",len))
  345.         {
  346.                 USART_SendBuffDat(USART4,Wrong_buf,sizeof(Wrong_buf));
  347.     return 1;
  348.         }
  349.         else if(!strncmp(buf,"OK",len))
  350.         {
  351.                 USART_SendBuffDat(USART4,Right_buf,sizeof(Right_buf));
  352.           return 2;
  353.         }
  354.         else
  355.         {
  356.                 USART_SendBuffDat(USART4,Wrong_buf,sizeof(Wrong_buf));
  357.                 return 3;
  358.         }
  359. }
  360. extern uint32_t Time_PT[2];
  361. extern uint32_t Time15_tag;
  362. extern uint32_t Time16_tag;
  363. extern uint8_t BD_Work_Flag;
  364. void Sensor_BD_Power(uint32_t *buf)
  365. {
  366.         if(Time_PT[0]>(buf[0]+buf[1]))
  367.         {
  368.                 if(Time15_tag>(Time_PT[0]-buf[0]) || Time15_tag<buf[1])
  369.       SENSOR_ON;
  370.                 else
  371.                         SENSOR_OFF;
  372.         }
  373.         else
  374.             SENSOR_ON;
  375.
  376.         if(BD_Work_Flag)
  377.                 if(Time_PT[1]>(buf[2]+buf[3]))
  378.                 {
  379.                         if(Time16_tag>(Time_PT[1]-buf[2]) || Time16_tag<buf[3])
  380.                                 BD_ON;
  381.                         else
  382.                                 BD_OFF;
  383.                 }
  384.                 else
  385.                          BD_ON;
  386.    else
  387.                         BD_OFF;
  388. }
  389. extern uint8_t tebuf[LOAD_LEN_MAX];
  390. void Data_load(FIL fsr,uint8_t *buf,uint32_t len)
  391. {
  392.         uint8_t NoData_buf[8]={0xBB,0xAA,0x23,0x04,0x23,0x13,0xDD,0xCC};
  393.         uint8_t load_buf[LOAD_LEN_MAX];
  394.         FRESULT res1;
  395.         char filebuf[13];
  396.         uint8_t hour;
  397.         uint8_t temp;
  398.         uint32_t i,j;
  399.
  400.         hour=buf[6]/16*10+buf[6]%16;
  401.         temp=hour;
  402.         for(i=0;i<len-2;i++)
  403.                 tebuf[i]=buf[i];
  404.
  405.         for(i=0;i<24-temp;i++)
  406.         {
  407.
  408.                 filebuf[0]=buf[3]/16+48;//年
  409.                 filebuf[1]=buf[3]%16+48;
  410.                 filebuf[2]=buf[4]/16+48;//月
  411.                 filebuf[3]=buf[4]%16+48;
  412.                 filebuf[4]=buf[5]/16+48;//日
  413.                 filebuf[5]=buf[5]%16+48;
  414.                 filebuf[6]= hour/10+48;//時
  415.                 filebuf[7]= hour%10+48;
  416.                 filebuf[8]='.';
  417.                 filebuf[9]='t';
  418.                 filebuf[10]='x';
  419.                 filebuf[11]='t';
  420.                 filebuf[12]='\0';
  421.                 res1=read_TF(fsr,filebuf,load_buf,0,0,1);
  422.                 tebuf[2]=FileSize+8;
  423.                 tebuf[6]=hour/10*16+hour%10;
  424.                 tebuf[9]=1+i;
  425.                 tebuf[10]=1;
  426.                 for(j=0;j<FileSize;j++)
  427.                         tebuf[11+j]=load_buf[j];
  428.
  429.                 tebuf[FileSize+11]=0xCC;
  430.                 tebuf[FileSize+12]=0xDD;
  431.
  432.                 if(res1==0)
  433.                         USART_SendBuffDat(USART4,tebuf,FileSize+13);
  434.                 else
  435.                 {
  436.                         for(j=0;j<4;j++)
  437.               NoData_buf[2+j]=buf[3+j];
  438.                         NoData_buf[5]=hour/10*16+hour%10;
  439.                         USART_SendBuffDat(USART4,NoData_buf,sizeof(NoData_buf));
  440.                 }
  441.                  hour++;
  442.         }
  443.
  444. }
僅供參考:
收藏收藏2 分享淘帖 頂 踩
