查看: 1647|回復(fù): 0
基于AVR128單片機(jī)搶答器仿真設(shè)計(jì)
ID:190577 發(fā)表于 2023-8-29 15:45 | 顯示全部樓層 |閱讀模式
二、硬件設(shè)計(jì)原理圖如下: 3.png
三、單片機(jī)軟件設(shè)計(jì)
1、首先是系統(tǒng)初始化
void timer0_init()                                 //定時(shí)器初始化
   TCCR0=0x07;                                      //普通模式,OC0不輸出,1024分頻
   TCNT0=f_count;                                    //初值,定時(shí)為10ms
   TIFR=0x01;                                       //清中斷標(biāo)志位
   TIMSK=0x01;                                      //使能定時(shí)器0溢出中斷
   SREG|=0x80;                                   //開(kāi)啟全局中斷
2、數(shù)碼管顯示程序
void Smg_Dispaly(uchar Value1,uchar Value2,uchar Num)
   if(SmgCnt == 0)
      PORTB = 0xFF;
          PORTB = Smg_Duan[Value1/10];
          PORTA = Smg_Wei[0];
   else if(SmgCnt == 1)
      PORTB = 0xFF;
          PORTB = Smg_Duan[Value1%10];
          PORTA = Smg_Wei[1];
   else if(SmgCnt == 2)
   else if(SmgCnt == 3)
      PORTB = 0xFF;
          PORTB = Smg_Duan[Value2/10];
          PORTA = Smg_Wei[3];
   else if(SmgCnt == 4)
      PORTB = 0xFF;
          PORTB = Smg_Duan[Value2%10];
          PORTA = Smg_Wei[4];
   else if(SmgCnt == 5)
   else if(SmgCnt == 6)
   else if(SmgCnt == 7)
      PORTB = 0xFF;
          PORTB = Smg_Duan[Num];
          PORTA = Smg_Wei[7];
   if(++SmgCnt >= 8)
            SmgCnt  = 0;
3、按鍵程序
if(PINC == 0xFF)
            Kcnt = 0;Kflag = 0;
          else if(Kflag == 0)
             if(++Kcnt >= 3)
                      Kflag = 1;Kcnt = 0;timer = 0;
                          PORTE =~ PORTE;
                          if(DownCnt == 0)
                            switch(PINC)
                  case 0xFE: ValueNum = 1;  ValueFlag = 1;break;
                      case 0xFD: ValueNum = 2;  ValueFlag = 1;break;
                  case 0xFB: ValueNum = 3;  ValueFlag = 1;break;
                      case 0xF7: ValueNum = 4;  ValueFlag = 1;break;
                      case 0xEF: ValueNum = 5;  ValueFlag = 1;break;
                      case 0xDF: ValueNum = 6;  ValueFlag = 1;break;
                  case 0xBF: ValueNum = 7;  ValueFlag = 1;break;
                      case 0x7F: ValueNum = 8;  ValueFlag = 1;break;
                      default: break;
4、核心算法程序
#pragma interrupt_handler timer1_ovf_isr:15
void timer1_ovf_isr(void)
     static uchar cnt = 0;
        if(StartFlag == 0)
             cnt = 0;
     if(++cnt >= 200)
             cnt = 0;                         // 定時(shí)器定時(shí)5ms,計(jì)數(shù)200次為1s
                if(StartData == 0)
                    SecFlag  = 1;  // 秒信號(hào)
          TCNT1H = (65535-500)/256;
     TCNT1L = (65535-500)%256;
     Smg_Dispaly(ValueCnt,ValueTmr,ValueNum);
四、proteus仿真設(shè)計(jì)Proteus軟件是一款應(yīng)用比較廣泛的工具,它可以在沒(méi)有硬件平臺(tái)的基礎(chǔ)上通過(guò)自身的軟件仿真出硬件平臺(tái)的運(yùn)行情況,這樣就可以通過(guò)軟件仿真來(lái)驗(yàn)證我們?cè)O(shè)計(jì)的方案有沒(méi)有問(wèn)題,如果有問(wèn)題,可以重新選擇器件,連接器件,直到達(dá)到我們?cè)O(shè)定的目的,避免我們搭建實(shí)物的時(shí)候,如果當(dāng)初選擇的方案有問(wèn)題,我們器件都已經(jīng)焊接好了,再去卸載下去,再去焊接新的方案的器件,測(cè)試,這樣會(huì)浪費(fèi)人力和物力,也給開(kāi)發(fā)者帶來(lái)一定困惑,Proteus仿真軟件就很好的解決這個(gè)問(wèn)題,我們?cè)谠O(shè)計(jì)之初,就使用該軟件進(jìn)行模擬仿真,測(cè)試,選擇滿足我們?cè)O(shè)計(jì)的最優(yōu)方案。最后根據(jù)測(cè)試沒(méi)問(wèn)題的仿真圖紙,焊接實(shí)物,調(diào)試,最終完成本設(shè)計(jì)的作品。 4.png
