查看: 2165|回復: 1
EIDE(組件)+VScode(主編輯器)+Keil5(輔助)+STM32CodeMX(初始化代碼生成)開發(fā)
ID:956085 發(fā)表于 2023-9-12 13:44 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
使用的是STM32f103c8t6控制板以及CMSIS-DAP仿真器,
主程序部分
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_I2C1_Init();
  MX_TIM2_Init();
  /* USER CODE BEGIN 2 */
  OLED_Init();
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    for(uint8_t i=0;i<28;i++)
      OLED_Fill(0);
      OLED_DrawBitmap(0,0,astronautallArray[ i],128,64,1);
      OLED_Refresh();
      HAL_Delay(50);
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
void SystemClock_Config(void)
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
    Error_Handler();
屏幕截圖 2023-09-12 132506.png (374.97 KB, 下載次數: 129)
開發(fā)環(huán)境圖
開發(fā)環(huán)境圖
效果圖,太空人旋轉動態(tài)顯示
效果圖,太空人旋轉動態(tài)顯示
OLED_Dynamic_Display.7z
324.35 KB, 下載次數: 3, 下載積分: 黑幣 -5
Keil5開發(fā)文件
OLED_Dynamic_Display_VScode.7z
355.6 KB, 下載次數: 3, 下載積分: 黑幣 -5
VScode開發(fā)配置文件
太空人BMP(28).zip
11.28 KB, 下載次數: 2, 下載積分: 黑幣 -5
28幀BMP圖片
參與人數 1黑幣 +50 收起 理由
admin + 50 共享資料的黑幣獎勵!
ID:956085 發(fā)表于 2023-9-14 07:20 | 只看該作者
需要這種開發(fā)環(huán)境的,我也可以提供教程
Powered by 單片機教程網
