查看: 2173|回復: 6
單片機數(shù)碼管顯示不全還亂閃,感覺代碼沒錯啊?
回帖獎勵 5 黑幣 回復本帖可獲得 5 黑幣獎勵! 每人限 1 次
ID:1058641 發(fā)表于 2023-9-21 16:35 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
程序2樓
ID:1058641 發(fā)表于 2023-9-21 16:49 | 只看該作者
#include <reg52.h>
#include "LCD7290.h"
sbit S1=P3^0;
sbit S2=P3^1;
sbit S3=P3^2;
sbit S4=P3^3;
code unsigned char SMGcode[18]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x80,0xc6,0xc0,0x86,0x8e,0xbf,0xff};
unsigned int s=0;
unsigned int s0_1=0;
unsigned int s1=0;
unsigned int m=0;
void selectHC573(unsigned char n)
        switch(n)
                case 5: P2=(P2 & 0x1f) | 0xa0;break;
                case 6: P2=(P2 & 0x1f) | 0xc0;break;
                case 7: P2=(P2 & 0x1f) | 0xe0;break;
void displySMG(unsigned char pos,unsigned char value)
        selectHC573(6);
        P0=0x01<<pos;
        selectHC573(7);
        P0=value;
void delay_dingshi(unsigned int n)
        while(n--);
void delay()
        unsigned char i;
        i = 350;
        while (i--);
void init()
        TMOD=0x01;
        TH0=(65535-50000)/256;
        TL0=(65535-50000)%256;
        ET0=1;
        EA=1;
        TR0=1;
void dinshi() interrupt 1
        s++;
        if(s == 20)
                s0_1++;
                s=0;
                if(s0_1 >= 59)
                        s1++;
                        s0_1 = 0;
                        if(s1 >= 59)
                                m++;
                                s1=0;
                        if(m >= 24)
                    m=0;
void RunningSMG()
        displySMG(7,SMGcode[s0_1%10]);
        delay();
        displySMG(6,SMGcode[s0_1/10]);
        delay();
        displySMG(5,SMGcode[17]);
        delay();
        displySMG(4,SMGcode[s1%10]);
        delay();
        displySMG(3,SMGcode[s1/10]);
        delay();
        displySMG(2,SMGcode[17]);
        delay();
        displySMG(1,SMGcode[m%10]);
        delay();
        displySMG(0,SMGcode[m/10]);
        delay();
void scan()
        if(S1 == 0)
                delay_dingshi(50);
                if(S1 == 0)
                        while(S1==0);
                        TR0=~TR0;
        if(S2 == 0)
                delay_dingshi(50);
                if(S2 == 0)
                        while(S2==0);
                        if(++s0_1 >= 59)
                                s0_1=0;
        if(S3 == 0)
                delay_dingshi(50);
                if(S3 == 0)
                        while(S3==0);
                        if(++s1 >= 59)
                                s1=0;
        if(S4 == 0)
                delay_dingshi(50);
                if(S4 == 0)
                        while(S4==0);
                        if(++m >= 24)
                                m=0;
int main()
        init();
        LCD_Init();
        LCD_Disp_String(0,1,"³ÂÌÎ");
        LCD_Disp_String(1,1,"2021441811");
        LCD_Disp_String(3,0,"ÖÇÄÜÒÇÆ÷");
                scan();
                RunningSMG();
ID:213173 發(fā)表于 2023-9-21 20:37 | 只看該作者
ZLG7290.PDF (292.96 KB, 下載次數(shù): 12) 內(nèi)有范例程序
ID:1093026 發(fā)表于 2023-9-21 21:14 | 只看該作者
頻率問題
ID:1094181 發(fā)表于 2023-9-22 14:30 | 只看該作者
延時問題
ID:161164 發(fā)表于 2023-9-22 16:02 | 只看該作者
沒消影
  1. void displySMG(unsigned char pos, unsigned char value)
  2. {
  3.         P0 = 0xff;//消影
  4.         selectHC573(6);
  5.         P0 = 0x01 << pos;
  6.         selectHC573(7);
  7.         P0 = value;
  8. }
復制代碼
ID:1058641 發(fā)表于 2023-10-17 21:43 | 只看該作者
解決了,謝謝大佬
