查看: 2325|回復(fù): 0
PIC系列單片機(jī)配置字配置方法
以PIC18F4580單片機(jī)為例
PIC18F4580配置字
1、首先查看芯片手冊,找到配置字描述部分
2、Search for the header file for your device(pic18f458.h) in your compiler library directory. Then see what the names are for the bit masking(e.g. WDTDIS)…(根據(jù)實(shí)際硬件設(shè)計配置)
__CONFIG(1, OSC_HS); /* HS oscillator */__CONFIG(2, (BORV_3 & BOREN_BOHW & PWRT_OFF & WDT_OFF & WDTPS_32768)); /* VBOR set to 2.1V,                      Brown-out Reset enabled in hardware only (SBOREN is disabled),                      PWRT disabled,                      Watchdog Timer Postscale, 1:32,768                      WDT disabled (control is placed on the SWDTEN bit) */__CONFIG(3, (MCLRE_OFF & LPT1OSC_OFF & PBADEN_OFF)); /* MCLR pin enabled; RE3 input pin disabled,                      Timer1 configured for higher power operation,                      PORTB<4:0> pins are configured as digital I/O on Reset */__CONFIG(4, (DEBUG_OFF & BBSIZ_1024 & LVP_OFF & STVREN_ON)); /* Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins,                         Instruction set extension and Indexed Addressing mode disabled (Legacy mode),                         1K words (2 Kbytes) boot block,                         Single-Supply ICSP disabled,                         Stack full/underflow will cause Reset */
3、編譯之后,使用PICKit3升級固件,ImportHex時,可以看到配置字
4、正確配置PIC單片機(jī)配置字之后,可以解決程序無法啟動問題(一般是因?yàn)闀r鐘源沒有配置導(dǎo)致芯片沒有起振)
admin + 50 共享資料的黑幣獎勵!
