查看: 1174|回復: 2
error C267: 'write_data': requires ANSI-style prototype
ID:1095516 發(fā)表于 2023-11-3 12:20 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
這個問題如何解決呢,剛開始有點不會
#include<reg51.h>
#include<lcd1602.h>
uchar int_time;
uchar second;
uchar minute;
uchar hour;
uchar code date[]="H.I.T.CHINA";
uchar code time[]="TIME 23:59:55";
uchar second=55,minute59,hour=23;
void clock_init()
   uchar i,j;
   for(i=0;i<16;i++)
      write_data(date[ i]);
        write_com(0x80+0x40);
        for(j=0;j<16;j++)
           write_data(time[j]);
void clock_write(uint s,uint m,uint h)
   write_sfm(0x47,h);
   write_sfm(0x4a,m);
   write_sfm(0x4d,s);
   init1602();
   clock_init();
   TMOD=0x01;
   EA=1;
   ET0=1;
   TH0=(65536-50000)/256;
   TL0=(65536-50000)%256;
   TR0=1;
   int_time=0;
   second=55;
   minute=59;
   hour=23;
      clock_write(seconf,minute,hour);
void T0_interserve(void) interrupt 1 using 1
{  int_time++;
   if(int_time==20)
      int_time=0;
          second++;
   if(second==60)
   second=0;
   minute++;
   if(minute==60)
      minute=0;
          hour++;
        if(hour==24)
           hour=0;
a1103.c(2): warning C318: can't open file 'lcd1602.h'
A1103.C(18): warning C206: 'write_data': missing function-prototype
A1103.C(18): error C267: 'write_data': requires ANSI-style prototype
ID:94031 發(fā)表于 2023-11-3 13:22 | 只看該作者
缺 write_data 函數(shù)原型,缺 lcd1602.h 頭文件
ID:883242 發(fā)表于 2023-11-3 15:20 | 只看該作者
就是第一個錯誤,找不到頭文件。
