查看: 1640|回復(fù): 0
Protues仿真單片機(jī)DS1302
ID:568114 發(fā)表于 2023-11-4 23:07 | 顯示全部樓層 |閱讀模式
  1. #include "reg51.h"
  2. #include "ds1302.h"
  3. #define uc unsigned char
  4. uc tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff,0xbf,
  5.           0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10,0xc1};
  6. uc duan[8];
  7. unsigned int ms;
  8. bit flag;
  9. unsigned char key,qiehuan;
  10. unsigned char moshi;
  11. bit anxia;
  12. unsigned char discom,wei;
  13. unsigned int canshu=23;
  14. void delay(unsigned int k)
  15. {
  16. unsigned char i;
  17. for(i=0;i<k;i++);
  18. }
  19. void Init()
  20. {
  21. P2=P2&0X1F|0X80;
  22. P0=0XFF;
  23. P2&=0X1F;
  24. P2=P2&0X1F|0XA0;
  25. P0=0X00;
  26. P2&=0X1F;
  27. }
  28. void display()
  29. {
  30. for(discom=0;discom<8;discom++)
  31. {
  32. P3=0X00;
  33. P3=1<<discom;
  34. P2=tab[duan[discom]];
  35. delay(200);
  36. }
  37. }
  38. void time0_Init()
  39. {
  40.         TMOD = 0x01;                //設(shè)置定時(shí)器模式
  41.         TL0 = (65536-10)%256;                //設(shè)置定時(shí)初值
  42.         TH0 = (65536-10)/256;                //設(shè)置定時(shí)初值
  43.         TF0 = 0;                //清除TF0標(biāo)志
  44.         TR0 = 1;
  45.         EA=1;
  46.         ET0=1;
  47. }
  48. void time0()interrupt 1
  49. {
  50. ms++;
  51. if(ms==1)
  52. {ms=0;
  53. }
  54. display();
  55. }
  56. void main()
  57. {
  58. Init();
  59. time0_Init();
  60. SETRTC();
  61. while(1)
  62. {
  63.          display();
  64.          RTC();
  65.          duan[0]=TIM[2]>>4;
  66.          duan[1]=TIM[2]&0X0F;
  67.          duan[2]=11;
  68.          duan[3]=TIM[1]>>4;
  69.    duan[4]=TIM[1]&0X0F;
  70.          duan[5]=11;
  71.    duan[6]=TIM[0]>>4;
  72.    duan[7]=TIM[0]&0X0f;
  73. }
  74. }
仿真程序: DS1302程序 仿真.zip (78.29 KB, 下載次數(shù): 7)
