查看: 955|回復(fù): 1
單片機(jī)測電壓 LCD1602上下讀數(shù)一直一樣?
ID:1100311 發(fā)表于 2023-11-21 23:27 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. #include<reg51.h>
  2. #include<intrins.h>
  3. sbit CS=P1^0;
  4. sbit CLK=P1^1;
  5. sbit DIO=P1^2;
  6. unsigned char code digit[10]={"0123456789"};
  7. unsigned char code Str[]={"Volt="};
  8. sbit RS=P2^0;
  9. sbit RW=P2^1;
  10. sbit E=P2^2;
  11. sbit BF=P0^7;
  12. void delay1ms()
  13. {
  14.    unsigned char i,j;
  15.          for(i=0;i<10;i++)
  16.           for(j=0;j<33;j++)
  17.            ;
  18. }
  19. void delaynms(unsigned char n)
  20. {
  21.    unsigned char i;
  22.         for(i=0;i<n;i++)
  23.            delay1ms();
  24. }
  25. bit BusyTest(void)
  26.   {
  27.     bit result;
  28.         RS=0;
  29.     RW=1;
  30.     E=1;
  31.     _nop_();
  32.     _nop_();
  33.     _nop_();
  34.     _nop_();
  35.     result=BF;
  36.    E=0;
  37.    return result;
  38.   }
  39. void WriteInstruction (unsigned char dictate)
  40. {
  41.     while(BusyTest()==1);
  42.          RS=0;
  43.          RW=0;
  44.          E=0;
  45.
  46.          _nop_();
  47.          _nop_();
  48.          P0=dictate;
  49.          _nop_();
  50.          _nop_();
  51.          _nop_();
  52.          _nop_();
  53.          E=1;
  54.          _nop_();
  55.          _nop_();
  56.          _nop_();
  57.          _nop_();
  58.           E=0;
  59. }
  60. void WriteAddress(unsigned char x)
  61. {
  62.      WriteInstruction(x|0x80);
  63. }
  64. void WriteData(unsigned char y)
  65. {
  66.     while(BusyTest()==1);
  67.           RS=1;
  68.           RW=0;
  69.           E=0;
  70.
  71.           P0=y;
  72.           _nop_();
  73.           _nop_();
  74.           _nop_();
  75.      _nop_();
  76.           E=1;
  77.           _nop_();
  78.           _nop_();
  79.           _nop_();
  80.          _nop_();
  81.          E=0;
  82. }
  83. void LcdInitiate(void)
  84. {
  85.     delaynms(15);
  86.     WriteInstruction(0x38);
  87.         delaynms(5);
  88.     WriteInstruction(0x38);
  89.         delaynms(5);
  90.         WriteInstruction(0x38);
  91.         delaynms(5);
  92.         WriteInstruction(0x0c);
  93.         delaynms(5);
  94.         WriteInstruction(0x06);
  95.         delaynms(5);
  96.         WriteInstruction(0x01);
  97.         delaynms(5);
  98. }
  99. void display_volt(void)
  100. {
  101.     unsigned char i;
  102.          WriteAddress(0x03);
  103.          i = 0;
  104.          while(Str[i] != '\0')
  105.           {
  106.                  WriteData(Str[ i]);
  107.                  i++;
  108.                 }
  109. }
  110. void display_volt2(void)
  111. {
  112.     unsigned char i;
  113.          WriteAddress(0x43);
  114.          i = 0;
  115.          while(Str[i] != '\0')
  116.           {
  117.                  WriteData(Str[i]);
  118.                  i++;
  119.                 }
  120. }
  121. void display_dot(void)
  122. {
  123.          WriteAddress(0x09);
  124.          WriteData('.');
  125. }
  126. void display_dot2(void)
  127. {
  128.          WriteAddress(0x49);
  129.          WriteData('.');
  130. }
  131. void  display_V(void)
  132. {
  133.     WriteAddress(0x0c);
  134.          WriteData('V');
  135.
  136. }
  137. void  display_V2(void)
  138. {
  139.     WriteAddress(0x4c);
  140.          WriteData('V');
  141.
  142. }
  143. void display1(unsigned char x)
  144. {
  145.         WriteAddress(0x08);
  146.         WriteData(digit[x]);
  147. }
  148. void display1_2(unsigned char x)
  149. {
  150.         WriteAddress(0x48);
  151.         WriteData(digit[x]);
  152. }
  153. void display2(unsigned char x)
  154. {
  155.         unsigned char i,j;
  156.         i=x/10;
  157.         j=x%10;
  158.    WriteAddress(0x0a);
  159.         WriteData(digit[i]);
  160.         WriteData(digit[j]);
  161. }
  162. void display2_2(unsigned char x)
  163. {
  164.         unsigned char i,j;
  165.         i=x/10;
  166.         j=x%10;
  167.    WriteAddress(0x4a);
  168.         WriteData(digit[i]);
  169.         WriteData(digit[j]);
  170. }
  171. unsigned char  A_D()
  172. {
  173.   unsigned char i,dat;
  174.    CS=1;
  175.    CLK=0;
  176.    CS=0;
  177.    DIO=1;
  178.    CLK=1;
  179.    CLK=0;
  180.    DIO=1;
  181.    CLK=1;
  182.    CLK=0;
  183.    DIO=0;
  184.    CLK=1;
  185.    CLK=0;
  186.    DIO=1;
  187.    CLK=1;
  188.    for(i=0;i<8;i++)
  189.     {
  190.       CLK=1;
  191.       CLK=0;
  192.       dat<<=1;
  193.                 dat|=(unsigned char)DIO;
  194.     }
  195.     CS=1;
  196.          return dat;
  197.   }
  198. unsigned char  A_D2()
  199. {
  200.   unsigned char i,dat;
  201.    CS=1;
  202.    CLK=0;
  203.    CS=0;
  204.    DIO=1;
  205.    CLK=1;
  206.    CLK=0;
  207.    DIO=1;
  208.    CLK=1;
  209.    CLK=0;
  210.    DIO=1;
  211.    CLK=1;
  212.    CLK=0;
  213.    DIO=1;
  214.    CLK=1;
  215.    for(i=0;i<8;i++)
  216.     {
  217.       CLK=1;
  218.       CLK=0;
  219.       dat<<=1;
  220.                 dat|=(unsigned char)DIO;
  221.     }
  222.     CS=1;
  223.          return dat;
  224.   }
  225. main(void)
  226. {
  227.   unsigned int AD_val,AD_val2;
  228.   unsigned char Int,Dec,Int2,Dec2;
  229.    LcdInitiate();
  230.    delaynms(5);
  231.    display_volt();
  232.    display_volt2();
  233.    display_dot();
  234.    display_V();
  235.    display_dot2();
  236.    display_V2();
  237.    while(1)
  238.       {
  239.                   AD_val= A_D();
  240.                   AD_val2=A_D2();
  241.                   Int=(AD_val)/51;
  242.                   Dec=(AD_val%51)*100/51;
  243.                   Int2=(AD_val2)/51;
  244.                   Dec2=(AD_val2%51)*100/51;
  245.           display1(Int);
  246.                   display2(Dec);
  247.                   display1_2(Int2);
  248.                   display2_2(Dec2);
  249.                   delaynms(250);
  250.                 }
  251.
  252. }
ID:883242 發(fā)表于 2023-11-22 20:47 | 只看該作者
LCM的Datasheet貼出來,特別是關(guān)于0x43和0x03命令的區(qū)別。
