查看: 1624|回復(fù): 6
求助大佬,51單片機(jī)控制AS608指紋模塊卡在對(duì)接怎么解決
附我的代碼,及板子圖片
指紋測試2.zip
56.18 KB, 下載次數(shù): 2
ID:883242 發(fā)表于 2023-12-9 21:24 | 只看該作者
用邏輯分析儀或示波器看下波形,是否符合通訊協(xié)議。
ID:327265 發(fā)表于 2023-12-9 23:02 | 只看該作者
查看寫的驅(qū)動(dòng)程序是否有問題,或者您貼上來可以幫您查看
ID:1103416 發(fā)表于 2023-12-10 08:41 | 只看該作者
Hephaestus 發(fā)表于 2023-12-9 21:24
沒有邏輯分析儀咋辦
ID:1103416 發(fā)表于 2023-12-10 08:52 | 只看該作者
whwteng 發(fā)表于 2023-12-9 23:02
主函數(shù)部分
#include<reg52.h>
#include<intrins.h>
#include"buzz.h"
#include"key.h"
#include"uart.h"
#include"delay.h"
#include"FPM10A.h"
#include"lcd_1602.h"
    SRD = 0;//繼電器關(guān)閉
        LCD1602_Init();                        //初始化液晶
        LCD1602_Display(0x80,"Fingerprint Test",0,16);         //液晶開機(jī)顯示界面
    Uart_Init();                        //初始化串口
        Key_Init();                                //初始化按鍵
        Delay_Ms(200);          //延時(shí)500MS,等待指紋模塊復(fù)位
        Device_Check();                           //校對(duì)指紋模塊是否接入正確,液晶做出相應(yīng)的提示
        Delay_Ms(1000);                        //對(duì)接成功界面停留一定時(shí)間
            /**************進(jìn)入主功能界面****************/
                LCD1602_Display(0x80,"  Finger Unlock ",0,16);         //第一排顯示搜索指紋
                LCD1602_Display(0xc0,"  Add     delete",0,16);         //添加和刪除指紋
            //第一個(gè)按鈕,切換鍵按下后,進(jìn)行功能選擇
                if(KEY_DOWN == 0)
                         while(KEY_DOWN == 0); //等待松開按鍵
                           if(local_date<=2)
                                local_date++;
                                if(local_date==3)
                                        local_date=0;
                if(local_date==0)
                        LCD1602_Display(0x80,  " *",0,2);
                        LCD1602_Display(0xc0,  "  ",0,2);
                        LCD1602_Display(0xc0+8,"  ",0,2);
                else if(local_date==1)
                        LCD1602_Display(0x80,  "  ",0,2);
                        LCD1602_Display(0xc0,  " *",0,2);
                else if(local_date==2)
                        LCD1602_Display(0xc0+8," *",0,2);
                //第二個(gè)按鈕,確認(rèn)鍵按下后,進(jìn)入各自對(duì)應(yīng)的功能。
                if(KEY_OK == 0)
                         while(KEY_OK == 0);//等待松開按鍵
                        switch(local_date)
                                        case 0:  //搜索指紋
                                        FPM10A_Find_Fingerprint();
                                        break;
                                        case 1:         //添加指紋
                                        FPM10A_Add_Fingerprint();
                                        break;
                                        case 2:        //清空指紋
                                        FPM10A_Delete_All_Fingerprint();
                                          break;
                if(KEY_LOCK == 0)
                         while(KEY_LOCK == 0);//等待松開按鍵
                        Buzz_Times(2);
                        SRD = 1;
                        Delay_Ms(2000);
                        SRD = 0;
                        Delay_Ms(100); //延時(shí)判斷100MS檢測一次
通訊部分
#include <reg52.h>
#include "FPM10A.h"
#include "key.h"
#include "uart.h"
#include "lcd_1602.h"
#include "delay.h"
#include "buzz.h"
//sbit SRD = P2^6;//繼電器
volatile unsigned char FPM10A_RECEICE_BUFFER[32];
unsigned int finger_id = 0;
//FINGERPRINT通信協(xié)議定義
code unsigned char FPM10A_Get_Device[10] ={0x01,0x00,0x07,0x13,0x00,0x00,0x00,0x00,0x00,0x1b};//口令驗(yàn)證,驗(yàn)證模塊是否正確連接 ,對(duì)應(yīng)19號(hào)指令。
code unsigned char FPM10A_Pack_Head[6] = {0xEF,0x01,0xFF,0xFF,0xFF,0xFF};  //協(xié)議包頭
code unsigned char FPM10A_Get_Img[6] = {0x01,0x00,0x03,0x01,0x00,0x05};    //獲得指紋圖像,對(duì)應(yīng)1號(hào)指令。
code unsigned char FPM10A_Get_Templete_Count[6] ={0x01,0x00,0x03,0x1D,0x00,0x21 }; //獲得模版總數(shù)
code unsigned char FPM10A_Search[11]={0x01,0x00,0x08,0x04,0x01,0x00,0x00,0x03,0xE7,0x00,0xF8}; //4號(hào)指令,搜索指紋搜索范圍0 - 999,使用BUFFER1中的特征碼搜索
code unsigned char FPM10A_Search_0_9[11]={0x01,0x00,0x08,0x04,0x01,0x00,0x00,0x00,0x13,0x00,0x21}; //搜索0-9號(hào)指紋
code unsigned char FPM10A_Img_To_Buffer1[7]={0x01,0x00,0x04,0x02,0x01,0x00,0x08}; //將圖像放入到BUFFER1,2號(hào)功能
code unsigned char FPM10A_Img_To_Buffer2[7]={0x01,0x00,0x04,0x02,0x02,0x00,0x09}; //將圖像放入到BUFFER2        ,2號(hào)功能
code unsigned char FPM10A_Reg_Model[6]={0x01,0x00,0x03,0x05,0x00,0x09}; //將BUFFER1跟BUFFER2合成特征模版,5號(hào)功能
code unsigned char FPM10A_Delete_All_Model[6]={0x01,0x00,0x03,0x0d,0x00,0x11};//刪除指紋模塊里所有的模版,13號(hào)功能
volatile unsigned char  FPM10A_Save_Finger[9]={0x01,0x00,0x06,0x06,0x01,0x00,0x0B,0x00,0x19};//將BUFFER1中的特征碼存放到指定的位置,6號(hào)功能
//volatile:系統(tǒng)總是重新從它所在的內(nèi)存讀取數(shù)據(jù),即使它前面的指令剛剛從該處讀取過數(shù)據(jù)
/*------------------ FINGERPRINT命令字 --------------------------*/
//發(fā)送包頭
void FPM10A_Cmd_Send_Pack_Head(void)
        int i;
        for(i=0;i<6;i++) //包頭
     Uart_Send_Byte(FPM10A_Pack_Head);
//發(fā)送指令
void FPM10A_Cmd_Check(void)
        int i=0;
        FPM10A_Cmd_Send_Pack_Head(); //發(fā)送通信協(xié)議包頭
        for(i=0;i<10;i++)
                Uart_Send_Byte(FPM10A_Get_Device);
//接收反饋數(shù)據(jù)緩沖
void FPM10A_Receive_Data(unsigned char ucLength)
  unsigned char i;
  for (i=0;i<ucLength;i++)
     FPM10A_RECEICE_BUFFER = Uart_Receive_Byte();
//FINGERPRINT_獲得指紋圖像命令
void FPM10A_Cmd_Get_Img(void)
    unsigned char i;
    for(i=0;i<6;i++) //發(fā)送命令 0x1d
       Uart_Send_Byte(FPM10A_Get_Img);
//講圖像轉(zhuǎn)換成特征碼存放在Buffer1中
void FINGERPRINT_Cmd_Img_To_Buffer1(void)
        unsigned char i;
           for(i=0;i<7;i++)   //發(fā)送命令 將圖像轉(zhuǎn)換成 特征碼 存放在 CHAR_buffer1
      Uart_Send_Byte(FPM10A_Img_To_Buffer1);
//將圖像轉(zhuǎn)換成特征碼存放在Buffer2中
void FINGERPRINT_Cmd_Img_To_Buffer2(void)
     unsigned char i;
     for(i=0;i<6;i++)    //發(fā)送包頭
              Uart_Send_Byte(FPM10A_Img_To_Buffer2);
//搜索全部用戶999枚
void FPM10A_Cmd_Search_Finger(void)
       unsigned char i;
       for(i=0;i<11;i++)
                  Uart_Send_Byte(FPM10A_Search);
void FPM10A_Cmd_Reg_Model(void)
       unsigned char i;
       for(i=0;i<6;i++)
                  Uart_Send_Byte(FPM10A_Reg_Model);
//刪除指紋模塊里的所有指紋模版
void FINGERPRINT_Cmd_Delete_All_Model(void)
     unsigned char i;
    for(i=0;i<6;i++) //命令合并指紋模版
      Uart_Send_Byte(FPM10A_Delete_All_Model);
//保存指紋
void FPM10A_Cmd_Save_Finger( unsigned int storeID )
       unsigned long temp = 0;
                   unsigned char i;
       FPM10A_Save_Finger[5] =(storeID&0xFF00)>>8;
       FPM10A_Save_Finger[6] = (storeID&0x00FF);
                   for(i=0;i<7;i++)   //計(jì)算校驗(yàn)和
                              temp = temp + FPM10A_Save_Finger;
                   FPM10A_Save_Finger[7]=(temp & 0x00FF00) >> 8; //存放校驗(yàn)數(shù)據(jù)
                   FPM10A_Save_Finger[8]= temp & 0x0000FF;
       for(i=0;i<9;i++)
                      Uart_Send_Byte(FPM10A_Save_Finger);      //發(fā)送命令 將圖像轉(zhuǎn)換成 特征碼 存放在 CHAR_buffer1
//添加指紋
void FPM10A_Add_Fingerprint()
        unsigned char id_show[]={0,0,0};
        LCD1602_WriteCMD(0x01); //清屏
        finger_id=0;
        LCD1602_Display(0x80,"   Add  finger  ",0,16);
        LCD1602_Display(0xc0,"    ID is       ",0,16);
        //按返回鍵直接回到主菜單
        if(KEY_CANCEL == 0)
                 while(KEY_CANCEL==0);
                 break;
        //按切換鍵指紋iD值加1
        if(KEY_DOWN == 0)
                while(KEY_DOWN==0);
                if(finger_id == 1000)
                        finger_id = 0;
                finger_id = finger_id + 1;
         //指紋iD值顯示處理
         LCD1602_WriteCMD(0xc0+10);
         LCD1602_WriteDAT(finger_id/100+48);
         LCD1602_WriteDAT(finger_id%100/10+48);
         LCD1602_WriteDAT(finger_id%100%10+48);
         //按確認(rèn)鍵開始錄入指紋信息
         if(KEY_OK == 0)
                          while(KEY_OK==0);
                          LCD1602_Display(0x80," Please  finger ",0,16);
                          LCD1602_Display(0xc0,"                ",0,16);
                        while(KEY_CANCEL == 1)
                          //按下返回鍵退出錄入返回fingerID調(diào)整狀態(tài)
                                if(KEY_CANCEL == 0)
                                  break;
                                FPM10A_Cmd_Get_Img(); //獲得指紋圖像
                                FPM10A_Receive_Data(12);
                                //判斷接收到的確認(rèn)碼,等于0指紋獲取成功
                                if(FPM10A_RECEICE_BUFFER[9]==0)
                                        Delay_Ms(100);
                                        FINGERPRINT_Cmd_Img_To_Buffer1();
                                        LCD1602_Display(0x80,"Successful entry",0,16);
                                        Buzz_Times(1);
                                        Delay_Ms(1000);
                                                if(KEY_CANCEL == 0)
                                                        break;
                                                Delay_Ms(200);
                                                 //指紋iD值顯示處理
                                                FINGERPRINT_Cmd_Img_To_Buffer2();
                                                FPM10A_Cmd_Reg_Model();//轉(zhuǎn)換成特征碼
                                                  FPM10A_Cmd_Save_Finger(finger_id);
                                                Buzz_Times(1);
                                                Delay_Ms(1000);
                                                finger_id=finger_id+1;
                                            break;
                                break;
//                        ClrScreen(); //清空顯示屏
                //        Delay_Ms(500);
//搜索指紋
void FPM10A_Find_Fingerprint()
        unsigned int find_fingerid = 0;
        do
                FPM10A_Cmd_Get_Img(); //獲得指紋圖像,將圖像存儲(chǔ)在imagebuffer中
                        Delay_Ms(100);
                        FPM10A_Cmd_Search_Finger();
                        FPM10A_Receive_Data(16);
                        if(FPM10A_RECEICE_BUFFER[9] == 0) //搜索到
                                 LCD1602_Display(0x80," Search success ",0,16);
                                //拼接指紋ID數(shù)
                                 find_fingerid = FPM10A_RECEICE_BUFFER[10]*256 + FPM10A_RECEICE_BUFFER[11];
                                 //指紋iD值顯示處理
                                 LCD1602_WriteDAT(find_fingerid/100+48);
                                 LCD1602_WriteDAT(find_fingerid%100/10+48);
                                 LCD1602_WriteDAT(find_fingerid%100%10+48);
                                 Buzz_Times(2);
                                 SRD = 1;
                                 Delay_Ms(2000);
                                 SRD = 0;
                                else //沒有找到
                                        LCD1602_Display(0x80," Search  failed ",0,16);
                                         Buzz_Times(3);
        }while(KEY_CANCEL == 1);
//刪除所有存貯的指紋庫
void FPM10A_Delete_All_Fingerprint()
                unsigned char i=0;
                                LCD1602_Display(0x80,"   empty all    ",0,16);
                                LCD1602_Display(0xc0,"   Yes or no ?  ",0,16);
                do
                        if(KEY_OK==0)
                                while(KEY_OK==0);
                                LCD1602_Display(0x80,"   emptying     ",0,16);
                                Delay_Ms(300);
                                LCD1602_WriteCMD(0xc0);
                                for(i=0;i<16;i++)
                                        LCD1602_WriteDAT(42);
                                        Delay_Ms(100);
                                FINGERPRINT_Cmd_Delete_All_Model();
                                LCD1602_Display(0x80,"   All empty    ",0,16);
                                Buzz_Times(3);
                                break;
                 }while(KEY_CANCEL==1);
void Device_Check(void)
                unsigned char i=0;
                FPM10A_RECEICE_BUFFER[9]=1;                                           //串口數(shù)組第九位可判斷是否通信正常
                LCD1602_Display(0xc0,"Loading",0,7);                   //設(shè)備加載中界面
                for(i=0;i<8;i++)                                                           //進(jìn)度條式更新,看起來美觀
                        LCD1602_WriteDAT(42);                               //42對(duì)應(yīng)ASIC碼的 *
                        Delay_Ms(200);                                                           //控制進(jìn)度條速度
                LCD1602_Display(0xc0,"Docking  failure",0,16);      //液晶先顯示對(duì)接失敗,如果指紋模塊插對(duì)的話會(huì)將其覆蓋
                FPM10A_Cmd_Check();        //單片機(jī)向指紋模塊發(fā)送校對(duì)命令
                FPM10A_Receive_Data(12);                                                        //將串口接收到的數(shù)據(jù)轉(zhuǎn)存
                if(FPM10A_RECEICE_BUFFER[9] == 0)                                        //判斷數(shù)據(jù)低第9位是否接收到0 ,根據(jù)信息格式判斷的。
                        LCD1602_Display(0xc0,"Docking  success",0,16);        //符合成功條件則顯示對(duì)接成功
ID:1103416 發(fā)表于 2023-12-10 09:02 | 只看該作者
現(xiàn)在的情況是板子啟動(dòng)卡在對(duì)接,用上位機(jī)測試程序連接指紋模塊后才能進(jìn)入功能,但是功能會(huì)卡住。還有就是在上位機(jī)測試程序接通情況下重啟板子,修改指紋模塊的波特率為9600 或19200都能過對(duì)接,但是也是卡在后續(xù)功能。
ID:648281 發(fā)表于 2023-12-11 11:18 | 只看該作者
1、看看開發(fā)板晶振是多少,這個(gè)要確定
2、根據(jù)晶振計(jì)算波特率初值,不能錯(cuò)啦
3、采用不同的波特率和AS608對(duì)接測試
