查看: 1492|回復(fù): 0
89C51單片機(jī)編程秒表 Proteus仿真
ID:1102848 發(fā)表于 2023-12-14 13:13 | 顯示全部樓層 |閱讀模式
程序:
#include <reg51.h>
#define d_code P1
#define d_wei P3
uchar code tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar sec;
uchar count = 0;
void delay(uchar m);
void InitTimer0(void)
    TMOD = 0x01;
    TH0 = -50000 / 256;
        TL0 = -50000 % 256;
           ET0 = 1;
        EA = 1;
    TR0 = 1;
void main(void)
    uchar shi,ge;
        InitTimer0();
        sec = 0;
         shi = sec / 10;
         ge = sec % 10;
         d_code =  0xff;
         d_code =  ~tab[shi];
         d_wei = 0x02;
         delay(10);
         d_code =  0xff;
         d_code =  ~tab[ge];
         d_wei = 0x01;
         delay(10);
void Timer0Interrupt(void) interrupt 1
    TH0=-50000 / 256;
        TL0=-50000 % 256;
        count ++ ;
        if( count > 19 )
                count = 0;
                sec ++ ;
                if( sec > 59 )
                sec = 0;
void delay(uchar m)   //M ms 延時(shí)程序 (12M)
    unsigned char a,b,c;
    for(c=m;c>0;c--)
        for(b=142;b>0;b--)
            for(a=2;a>0;a--);
仿真.7z
41.31 KB, 下載次數(shù): 11, 下載積分: 黑幣 -5
