查看: 2376|回復(fù): 21
nrf51822移植stm32單片機(jī) LCD程序的問題
回帖獎勵 20 黑幣 回復(fù)本帖可獲得 20 黑幣獎勵! 每人限 1 次
ID:551154 發(fā)表于 2024-1-15 23:55 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
單片機(jī)nrf51822,在移植stm32lcd的例程中發(fā)現(xiàn)程序報錯,報錯顯示如下
.\Peripheral\inc\FONT.h(446): error:  #144: a value of type "char [4]" cannot be used to initialize an entity of type "unsigned char [2]"
  "???",0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0xFC,0x1F,0x84,0x10,0x84,0x10,0x84,0x10,
.\Peripheral\inc\FONT.h(448): error:  #144: a value of type "char [4]" cannot be used to initialize an entity of type "unsigned char [2]"
  "???",0xF8,0x0F,0x08,0x08,0xF8,0x0F,0x08,0x08,0xF8,0x0F,0x80,0x00,0xFF,0x7F,0x00,0x00,
.\Peripheral\inc\FONT.h(450): error:  #144: a value of type "char [4]" cannot be used to initialize an entity of type "unsigned char [2]"
  "???",0x00,0x00,0xFE,0x3F,0x02,0x20,0xF2,0x27,0x02,0x20,0x02,0x20,0xFA,0x2F,0x22,0x21,
.\Peripheral\inc\FONT.h(452): error:  #144: a value of type "char [4]" cannot be used to initialize an entity of type "unsigned char [2]"
  "???",0x80,0x00,0x80,0x00,0x80,0x00,0xFC,0x1F,0x84,0x10,0x84,0x10,0x84,0x10,0xFC,0x1F,
.\Peripheral\inc\FONT.h(454): error:  #144: a value of type "char [4]" cannot be used to initialize an entity of type "unsigned char [2]"
  "???",0x00,0x00,0xFE,0x1F,0x00,0x08,0x00,0x04,0x00,0x02,0x80,0x01,0x80,0x00,0xFF,0x7F,
Peripheral\src\LCD.c: 0 warnings, 5 errors
報錯位置代碼是這樣的
const typFNT_GB16 tfont16[]={
"中",0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0xFC,0x1F,0x84,0x10,0x84,0x10,0x84,0x10,
0x84,0x10,0x84,0x10,0xFC,0x1F,0x84,0x10,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,/*"中",0*/
"景",0xF8,0x0F,0x08,0x08,0xF8,0x0F,0x08,0x08,0xF8,0x0F,0x80,0x00,0xFF,0x7F,0x00,0x00,
0xF8,0x0F,0x08,0x08,0x08,0x08,0xF8,0x0F,0x80,0x00,0x84,0x10,0xA2,0x20,0x40,0x00,/*"景",1*/
"園",0x00,0x00,0xFE,0x3F,0x02,0x20,0xF2,0x27,0x02,0x20,0x02,0x20,0xFA,0x2F,0x22,0x21,
0x22,0x21,0x22,0x21,0x12,0x29,0x12,0x29,0x0A,0x2E,0x02,0x20,0xFE,0x3F,0x02,0x20,/*"園",2*/
"電",0x80,0x00,0x80,0x00,0x80,0x00,0xFC,0x1F,0x84,0x10,0x84,0x10,0x84,0x10,0xFC,0x1F,
0x84,0x10,0x84,0x10,0x84,0x10,0xFC,0x1F,0x84,0x50,0x80,0x40,0x80,0x40,0x00,0x7F,/*"電",3*/
"子",0x00,0x00,0xFE,0x1F,0x00,0x08,0x00,0x04,0x00,0x02,0x80,0x01,0x80,0x00,0xFF,0x7F,
0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0xA0,0x00,0x40,0x00,/*"子",4*/
最開始我以為是漢字導(dǎo)致的問題,將“中景園電子”幾個字刪除以后,程序不再報錯,編譯程序可以通過,然后我調(diào)用
LCD_ShowChinese(40,0,"中景園電子",RED,WHITE,16,0);
發(fā)現(xiàn)下載以后程序不能正常顯示,但是調(diào)用LCD_ShowString(0,0 ,"A",GRED,BLUE ,16,0);可以正常顯示字母。
百度查找很多地方,說是關(guān)于指針的問題,只是我沒看懂,想問一下大佬們怎么改
以下是LCD_ShowChinese的具體內(nèi)容,望大佬們指點
      函數(shù)說明:顯示漢字串
      入口數(shù)據(jù):x,y顯示坐標(biāo)
                *s 要顯示的漢字串
                fc 字的顏色
                bc 字的背景色
                sizey 字號 可選 16 24 32
                mode:  0非疊加模式  1疊加模式
      返回值:  無
void LCD_ShowChinese(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
        while(*s!=0)
                if(sizey==12) LCD_ShowChinese12x12(x,y,s,fc,bc,sizey,mode);
                else if(sizey==16) LCD_ShowChinese16x16(x,y,s,fc,bc,sizey,mode);
                else if(sizey==24) LCD_ShowChinese24x24(x,y,s,fc,bc,sizey,mode);
                else if(sizey==32) LCD_ShowChinese32x32(x,y,s,fc,bc,sizey,mode);
                else return;
                s+=2;
                x+=sizey;
      函數(shù)說明:顯示單個12x12漢字
                *s 要顯示的漢字
                fc 字的顏色
                bc 字的背景色
                sizey 字號
                mode:  0非疊加模式  1疊加模式
      返回值:  無
void LCD_ShowChinese12x12(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
        u8 i,j,m=0;
        u16 k;
        u16 HZnum;//漢字?jǐn)?shù)目
        u16 TypefaceNum;//一個字符所占字節(jié)大小
        u16 x0=x;
        TypefaceNum=(sizey/8+((sizey%8)?1:0))*sizey;
        HZnum=sizeof(tfont12)/sizeof(typFNT_GB12);        //統(tǒng)計漢字?jǐn)?shù)目
        for(k=0;k<HZnum;k++)
                if((tfont12[k].Index[0]==*(s))&&(tfont12[k].Index[1]==*(s+1)))
                        LCD_Address_Set(x,y,x+sizey-1,y+sizey-1);
                        for(i=0;i<TypefaceNum;i++)
                                for(j=0;j<8;j++)
                                        if(!mode)//非疊加方式
                                                if(tfont12[k].Msk[ i]&(0x01<<j))LCD_WR_DATA(fc);
                                                else LCD_WR_DATA(bc);
                                                m++;
                                                if(m%sizey==0)
                                                        m=0;
                                                        break;
                                        else//疊加方式
                                                if(tfont12[k].Msk[ i]&(0x01<<j))        LCD_DrawPoint(x,y,fc);//畫一個點
                                                x++;
                                                if((x-x0)==sizey)
                                                        x=x0;
                                                        y++;
                                                        break;
                continue;  //查找到對應(yīng)點陣字庫立即退出,防止多個漢字重復(fù)取模帶來影響
      函數(shù)說明:顯示單個16x16漢字
                *s 要顯示的漢字
                fc 字的顏色
                bc 字的背景色
                sizey 字號
                mode:  0非疊加模式  1疊加模式
      返回值:  無
void LCD_ShowChinese16x16(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
        u8 i,j,m=0;
        u16 k;
        u16 x0=x;
        HZnum=sizeof(tfont16)/sizeof(typFNT_GB16);        //統(tǒng)計漢字?jǐn)?shù)目
                if ((tfont16[k].Index[0]==*(s))&&(tfont16[k].Index[1]==*(s+1)))
                                for(j=0;j<8;j++)
                                        if(!mode)//非疊加方式
                                                if(tfont16[k].Msk[ i]&(0x01<<j))LCD_WR_DATA(fc);[ i]
                                                m++;
                                                if(m%sizey==0)
                                                        m=0;
                                                        break;
                                        else//疊加方式
                                                if(tfont16[k].Msk[ i]&(0x01<<j))        LCD_DrawPoint(x,y,fc);//畫一個點[ i]
                                                x++;
                                                if((x-x0)==sizey)
                                                        x=x0;
                                                        y++;
                                                        break;
      函數(shù)說明:顯示單個24x24漢字
                *s 要顯示的漢字
                fc 字的顏色
                bc 字的背景色
                sizey 字號
                mode:  0非疊加模式  1疊加模式
      返回值:  無
void LCD_ShowChinese24x24(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
        u8 i,j,m=0;
        u16 k;
        u16 x0=x;
        HZnum=sizeof(tfont24)/sizeof(typFNT_GB24);        //統(tǒng)計漢字?jǐn)?shù)目
                if ((tfont24[k].Index[0]==*(s))&&(tfont24[k].Index[1]==*(s+1)))
                                for(j=0;j<8;j++)
                                        if(!mode)//非疊加方式
                                                if(tfont24[k].Msk[ i]&(0x01<<j))LCD_WR_DATA(fc);
                                                m++;
                                                if(m%sizey==0)
                                                        m=0;
                                                        break;
                                        else//疊加方式
                                                if(tfont24[k].Msk[ i]&(0x01<<j))        LCD_DrawPoint(x,y,fc);//畫一個點
                                                x++;
                                                if((x-x0)==sizey)
                                                        x=x0;
                                                        y++;
                                                        break;
      函數(shù)說明:顯示單個32x32漢字
                *s 要顯示的漢字
                fc 字的顏色
                bc 字的背景色
                sizey 字號
                mode:  0非疊加模式  1疊加模式
      返回值:  無
void LCD_ShowChinese32x32(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
        u8 i,j,m=0;
        u16 k;
        u16 x0=x;
        HZnum=sizeof(tfont32)/sizeof(typFNT_GB32);        //統(tǒng)計漢字?jǐn)?shù)目
                if ((tfont32[k].Index[0]==*(s))&&(tfont32[k].Index[1]==*(s+1)))
                                for(j=0;j<8;j++)
                                        if(!mode)//非疊加方式
                                                if(tfont32[k].Msk[ i]&(0x01<<j))LCD_WR_DATA(fc);
                                                m++;
                                                if(m%sizey==0)
                                                        m=0;
                                                        break;
                                        else//疊加方式
                                                if(tfont32[k].Msk[ i]&(0x01<<j))        LCD_DrawPoint(x,y,fc);//畫一個點
                                                x++;
                                                if((x-x0)==sizey)
                                                        x=x0;
                                                        y++;
                                                        break;
ID:458247 發(fā)表于 2024-1-16 08:58 | 只看該作者
你用的keil?中文編碼格式用的是GB2312嗎?typFNT_GB16這個結(jié)構(gòu)體類型定義的可能存在問題,在這個單片機(jī)編譯器上不能這么寫
ID:551154 發(fā)表于 2024-1-16 18:53 | 只看該作者
yzw846562238 發(fā)表于 2024-1-16 08:58
你用的keil?中文編碼格式用的是GB2312嗎?typFNT_GB16這個結(jié)構(gòu)體類型定義的可能存在問題,在這個單片機(jī)編譯 ...
是GB2312,我需要修改成UTF-8嗎,大佬經(jīng)驗好豐富,一眼就看出來是GB2312編碼格式了,麻煩大佬細(xì)說一下,我還是沒明白應(yīng)該怎么修改
ID:551154 發(fā)表于 2024-1-16 21:18 | 只看該作者
忘了加代碼了,那個結(jié)構(gòu)體是這樣的
typedef struct
        unsigned char Index[2];
        unsigned char Msk[32];
}typFNT_GB16;
ID:458247 發(fā)表于 2024-1-17 13:00 | 只看該作者
forcexda 發(fā)表于 2024-1-16 21:18
typedef struct
是keil么,還是其他ide,代碼看著沒啥問題,要不把工程打包發(fā)上來看看?
ID:458247 發(fā)表于 2024-1-17 13:01 | 只看該作者
typedef struct
"unsigned char [2]"
感覺是你的中文被解析成了4字節(jié),其實gb2312應(yīng)該是2字節(jié)的。
ID:551154 發(fā)表于 2024-1-17 19:36 | 只看該作者
yzw846562238 發(fā)表于 2024-1-17 13:01
"unsigned char [2]"
  "???",0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0xFC,0x1F,0x84,0x10,0x84,0x10 ...
代碼我打包上傳了,麻煩大佬幫我看看,ide用的是keil,版本5.23
BLE.7z
464.4 KB, 下載次數(shù): 4
ID:551154 發(fā)表于 2024-1-17 20:22 | 只看該作者
"unsigned char [2]"
大佬,我順著你的思路,把unsigned char Index[2];        改成char Index[4];居然編譯通過了,然后正常顯示字符,但是我還是沒明白為什么[笑哭],大佬你看一下代碼,給我指點一下吧
ID:551154 發(fā)表于 2024-1-17 20:33 | 只看該作者
"unsigned char [2]"
剛才發(fā)現(xiàn),也有g(shù)b2312的鍋,必須把gb2312改成utff-8,不然字符不顯示,大佬這個字符編碼有沒有萬金油的那種,就是所有的字符都可以用的那種【捂臉哭】,有點打腦闊
ID:551154 發(fā)表于 2024-1-17 20:56 | 只看該作者
"unsigned char [2]"
似乎不行,雖然可以顯示了,但是顯示還是不算正常,無法正確顯示字符間距
ID:384109 發(fā)表于 2024-1-18 10:55 | 只看該作者
好好參考一下原來的例程吧,感覺你把漢字顯示部分自己改復(fù)雜了
ID:551154 發(fā)表于 2024-1-18 11:20 | 只看該作者
人中狼 發(fā)表于 2024-1-18 10:55
沒有哦,這里只做了移植,沒有改過漢字部分的代碼
ID:458247 發(fā)表于 2024-1-18 13:57 | 只看該作者
forcexda 發(fā)表于 2024-1-17 19:36
容我看看
ID:458247 發(fā)表于 2024-1-18 14:14 | 只看該作者
測試中文的時候,不要刷圖片、其他文字。不然你分不清是誰的問題。然后文字編碼格式要改成GB2312的,因為utf-8是三個字節(jié)的,跟你這個代碼沒法兼容。
BLE.7z
1.72 MB, 下載次數(shù): 2
ID:551154 發(fā)表于 2024-1-18 15:16 | 只看該作者
yzw846562238 發(fā)表于 2024-1-18 14:14
測試中文的時候,不要刷圖片、其他文字。不然你分不清是誰的問題。然后文字編碼格式要改成GB2312的,因為ut ...
不刷圖片和其他文字的話,字符出來還是有問題,主要是間距問題
ID:458247 發(fā)表于 2024-1-18 15:31 | 只看該作者
forcexda 發(fā)表于 2024-1-18 15:16
拍個效果圖看看,我看代碼沒看出有啥問題。另外你用utf-8的話,應(yīng)該是無法顯示才對啊
ID:551154 發(fā)表于 2024-1-18 19:15 | 只看該作者
yzw846562238 發(fā)表于 2024-1-18 15:31
上圖是gb2312的運(yùn)行情況,什么字符都不顯示
這兩個是utf-8下的運(yùn)行情況,能顯示字符,但是字符間距不對,且顯示也不正常,應(yīng)該顯示中景園三個字,結(jié)果只顯示中園兩個字
需要注意的是,如果在gb2312下改為utf-8,字符可以正常顯示后,再改回gb2312,字符又可以顯示,但是顯示依然不正常
應(yīng)該是和unsigned char index[2]變更成unsigned char index[4]有關(guān)系,但是原來的漢字顯示我還是不太清楚應(yīng)該如何修改,大佬可以%探討一下嗎
ID:458247 發(fā)表于 2024-1-19 08:38 | 只看該作者
forcexda 發(fā)表于 2024-1-18 19:15
你改成GB2312,把project清空一遍,中文重新打一遍,然后重新編譯下載,有stlink的話,最好是仿真看看哪一步出了問題
ID:384109 發(fā)表于 2024-1-19 18:51 | 只看該作者
感覺還是你選的例程的問題,你選的例程是從外部字庫芯片取字體數(shù)據(jù),并不適合你現(xiàn)在這種字庫的調(diào)用方式
ID:551154 發(fā)表于 2024-1-20 22:05 | 只看該作者
人中狼 發(fā)表于 2024-1-19 18:51
可是這個例程的字庫是調(diào)用存在rom里的字庫,不是外部字庫,根本沒有flash,我在stm32最小系統(tǒng)板上嘗試過是正常的
ID:384109 發(fā)表于 2024-1-21 09:27 | 只看該作者
你這里不同字號用了不同的函數(shù),那么字體的字節(jié)數(shù)就固定了,但函數(shù)里確還要計算字節(jié)數(shù),既然調(diào)試有問題,就把函數(shù)盡量簡化吧
ID:458247 發(fā)表于 2024-1-22 13:06 | 只看該作者
forcexda 發(fā)表于 2024-1-20 22:05
可是這個例程的字庫是調(diào)用存在rom里的字庫,不是外部字庫,根本沒有flash,我在stm32最小系統(tǒng)板上嘗試過 ...
還沒成功么
