請大佬看看是pic16f676單片機(jī)代碼哪兒的問題
報錯顯示::: warning: (1273) Omniscient Code Generation not available in Free mode
miewendeng.c:479: warning: (752) conversion to shorter data type
D:\XC8\sources\pic\eeread.c:12: error: (1360) no space for auto/param eeprom_write@addr
(908) exit status = 1
nbproject/Makefile-default.mk:131: recipe for target 'dist/default/production/miewendeng.X.production.hex' failed
make[2]: Leaving directory 'D:/MPLAB X IDE v4.05???/miewendeng.X'
nbproject/Makefile-default.mk:90: recipe for target '.build-conf' failed
make[1]: Leaving directory 'D:/MPLAB X IDE v4.05???/miewendeng.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
make[2]: *** [dist/default/production/miewendeng.X.production.hex] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
編譯已失敗 (退出值2, 總時間: 1s)
警告:adcshili.c:418: warning: (752) conversion to shorter data type這個警告表示在第418行進(jìn)行了將數(shù)據(jù)類型轉(zhuǎn)換為較短的數(shù)據(jù)類型的操作。
錯誤:D:\XC8\sources\common\lwdiv.c:31: error: (1358) no space for _eeprom_read temps (1)這個錯誤表示編譯器無法為_eeprom_read temps分配足夠的空間。
eeprom_write(0x03,eeprom_read(0x03)+1); //清蟲天數(shù)計數(shù)+1天 418行
請問大佬這個代碼該怎么改啊,剛剛?cè)胄械男“鬃聊チ撕脦滋爝是一頭霧水。
- * File: adcshili.c
- * Author: Administrator
- * Created on 2024年1月5日, 上午9:24
- //#include <stdio.h>
- //#include <stdlib.h>
- int main(int argc, char** argv) {
- return (EXIT_SUCCESS);
- # include <xc.h>
- #pragma config FOSC = INTRCIO // Oscillator Selection bits (INTOSC oscillator: I/O function on RA4/OSC2/CLKOUT pin, I/O function on RA5/OSC1/CLKIN)INTOSC 振蕩器, RA4、RA5為IO口
- #pragma config WDTE = OFF // Watchdog Timer Enable bit (WDT enabled)看門狗開
- #pragma config PWRTE = ON // Power-up Timer Enable bit (PWRT enabled)上電復(fù)位開
- #pragma config MCLRE = OFF // RA3/MCLR pin function select (RA3/MCLR pin function is digital I/O, MCLR internally tied to VDD)RA3/MCLR引腳功能為MCLR
- #pragma config BOREN = OFF // Brown-out Detect Enable bit (BOD enabled)欠壓檢測功能關(guān)
- #pragma config CP = OFF // Code Protection bit (Program Memory code protection is disabled)程序存儲器代碼保護(hù)被禁用
- #pragma config CPD = OFF // Data Code Protection bit (Data memory code protection is disabled)數(shù)據(jù)代碼保護(hù)關(guān)
- //__ CONFIG(0X31A4);
- __EEPROM_DATA(5,50,67,6,5,0,0,0); //0X00第一位表示定時倍數(shù);0X01第二位表示最低電壓-低;0X02第三位表示最高電壓-高;0X03第四位表示清蟲天數(shù)記錄;0X04第五位表示清蟲天數(shù)預(yù)設(shè);0X05第五位表示為0鉛酸電池(最低不能低于2點(diǎn)幾V)、為1鋰電池(最高不能超過12.6V);0X06空;0X07空
- #define uchar unsigned char
- #define uint unsigned int
- /*#define EEPROM_ADDRESS 0x10 // 定義EEPROM地址
- // 定義EEPROM中存儲的數(shù)據(jù)
- const unsigned char myEEPROMData[] __at(EEPROM_ADDRESS) = {
- 0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07
- __EEPROM_DATA(5,50,67,6,5,0,0,0);*/
- uint AN2_val; //存放AN2通道模擬轉(zhuǎn)換的值
- uint AN4_val; //存放AN4通道模擬轉(zhuǎn)換的值
- uchar i = 0;
- uchar j = 0;
- uint yanshi;
- uchar AN2_num1;
- uchar AN2_num2;
- uchar AN2_num3;
- uchar AN4_num1;
- uchar AN4_num2;
- uchar AN4_num3;
- uchar AN4_num4;
- uchar yukon_num1;
- uchar yukon_num2;
- uint anjian_num1;
- uchar anjian_num2;
- uchar n;
- uint num;
- uchar daochon_num;
- uchar h;
- uchar day; //0為白天,1為晚上
- uchar fuzhai=1; //負(fù)載開啟
- uchar chondian; //0為充電完成,1為充電未完成,繼續(xù)充電
- uchar taiyangban; //1為太陽板電壓高于電池,0為太陽板電壓低于電池
- uchar ONOFF=1; //放電到充電一循環(huán),1開啟,0關(guān)閉
- uchar qcts;
- uchar k;
- uchar a=6;
- uchar t;
- uchar z=0;
- uchar m;
- void init1()
- TRISA = 0b00110100; //設(shè)置RA輸入輸出端口 RA2,RA4,RA5(AN2、AN3)為輸入,其他輸出
- TRISC = 0b00010011; //設(shè)置RC輸入輸出端口 RC0、RC1、RC4(AN4、AN5)為輸入,其他輸出
- PORTA = 0b00000000; //設(shè)置A端口輸出為低電平
- PORTC = 0b00000000; //設(shè)置C端口輸出為低電平
- ANSEL = 0X14; //ANS4=1,ANS2=1;AN4和AN2為模擬輸入 二進(jìn)制00010100
- /* CM2 = 1; //CM2:CM0:111 比較器模式位(關(guān)閉)
- CM1 = 1;
- CM0 = 1;*/
- //ADCON1 = 0X10; //ADCS<2:0>:A/D 轉(zhuǎn)換時鐘源選擇位 0011 =FOSC/8 4MHz頻率 二進(jìn)制00010000
- ADCON1=0b01010000; //AD,RC0(AN4)定義為AD口(A/D 轉(zhuǎn)換時鐘選擇位)
- void ADAN2() //對RA2(AN2)進(jìn)行A/D模擬轉(zhuǎn)換輸入
- ADCON0 = 0X09; //二進(jìn)制0000 1001 (bit7:0 左對齊,bit6:0 參考電壓VDD, bit5:0 未用, bit4-bit2:010 通道02(AN2), bit1:0 A/D轉(zhuǎn)換結(jié)束/未進(jìn)行, bit0:(ADON)1 A/D轉(zhuǎn)換模塊正在工作) A/D 控制寄存器
- for (i=0; i<16; i++)
- asm("NOP"); //稍微延時
- asm("NOP");
- asm("NOP");
- asm("NOP");
- GO_DONE = 1; //1 = A/D 轉(zhuǎn)換正在進(jìn)行。該位置 1 將啟動 A/D 轉(zhuǎn)換。 在轉(zhuǎn)換結(jié)束后該位將被硬件自動清零。 ADCON0 _ A/D 控制寄存器
- while (GO_DONE) //循環(huán)檢測GO_DONE是否為0,為0轉(zhuǎn)換結(jié)束
- continue;
- AN2_val + = ADRESH; //將左對齊后的20次結(jié)果賦值
- ADON = 0; //A/D轉(zhuǎn)換模塊結(jié)束
- AN2_val = AN2_val/16; //取20次檢測電壓的平均值
- if (AN2_val < eeprom_read(0X01)) //讀寫寄存器__EEPROM_DATA(5,50,67,6,5,0,0,0)中第二位,電源電壓為10.8v時,電路分壓后測出AN2電壓為:0.98v (5v是參考電壓,一個數(shù)值代表多少電壓:5/1024=0.00448,如果輸入電壓為0.98v,0.98/0.00448=218.75)
- AN2_num1++;
- if(AN2_num1 > 16) //(超過20次電壓低于10.8v)
- AN2_num1 = 0; //計數(shù)清0
- fuzhai = 0; //負(fù)載未開啟工作
- else
- AN2_num1 = 0; //清0
- if (AN2_val > eeprom_read(0X02)) //讀寫寄存器__EEPROM_DATA(5,50,67,6,5,0,0,0)中第三位,電源電壓為14.4v時,電路分壓后測出AN2電壓為:1.31v (如果輸入電壓為1.31v,1.31/0.00448=292.41)
- AN2_num2++;
- if(AN2_num2++ > 16) //(超過20次電壓高于14.4v)
- AN2_num2 = 0; //計數(shù)清0
- chondian = 0; //充電完成
- else
- AN2_num3++; //計數(shù)自增
- if (AN2_num3 > 16) //(超過20次電壓低于14.4v)
- AN2_num3 = 0; //計數(shù)清0
- chondian = 1; //充電未完成,繼續(xù)充電
- void ADAN4() //對RC0(AN4)進(jìn)行A/D模擬轉(zhuǎn)換輸入
- ADCON0 = 0X11; //二進(jìn)制0000 1001 (bit7:0 左對齊,bit6:0 參考電壓VDD, bit5:0 未用, bit4-bit2:100 通道04(AN4), bit1:0 A/D轉(zhuǎn)換結(jié)束/未進(jìn)行, bit0:(ADON)1 A/D轉(zhuǎn)換模塊正在工作) A/D 控制寄存器
- for (j=0; j<16; j++)
- asm("NOP");
- asm("NOP");
- asm("NOP");
- continue;
- AN4_val + = ADRESH; //將左對齊后的20次結(jié)果賦值
- AN4_val = AN4_val/16; //取20次檢測電壓的平均值
- if(AN2_val - AN4_val < 13) //連續(xù)檢測20次太陽板比鉛酸電池或鋰電池低于3V (晚上)
- AN4_num1++;
- if (AN4_num1 > 24) //(超過20次太陽板電壓比電源電壓低于3v)
- AN4_num1 = 0; //計數(shù)清0
- day = 1; //晚上
- else
- AN4_num1 = 0;
- if (AN2_val - AN4_val > 23) //連續(xù)檢測20次太陽板高于5.5V的鉛酸電池或鋰電池 (白天)
- AN4_num2++;
- if (AN4_num2 > 24) //(超過20次太陽板電壓比電源電壓高于5.5v)
- AN4_num2 = 0;
- day = 0; //白天
- else
- AN4_num2 = 0;
- if (AN4_val < 0b00000011) //連續(xù)檢測20次太陽板電壓高于電池電壓,開始充電,連續(xù)檢測20次太陽板電壓低于電池電壓,不充電
- AN4_num3++;
- if (AN4_num3 > 16) //連續(xù)檢測20次太陽板電壓高于電池電壓
- AN4_num3 = 0; //計數(shù)清零
- taiyangban = 1; //1為太陽板電壓高于電池
- fuzhai = 1; //負(fù)載工作開啟
- ONOFF=1; //放電到充電一循環(huán),開啟
- else
- AN4_num4++;
- if (AN4_num4 > 16) //連續(xù)檢測20次太陽板電壓低于電池電壓
- AN4_num4 = 0; //計數(shù)清零
- taiyangban = 0; //0為太陽板電壓低于電池
- void kaijishansuo() //開機(jī)閃爍5次
- if (yanshi > 800) //1s溢出(3906)
- yanshi = 0;
- if (z == 0)
- z = 1;
- else
- z = 0;
- a--;
- void condianshansuo() //充電連續(xù)閃爍
- if (yanshi > 1500) //1s溢出
- yanshi = 0;
- if (z == 0)
- z = 1;
- else
- z = 0;
- void panduan () //轉(zhuǎn)換后的數(shù)據(jù)判斷,定義是否需要開燈、充電、雨控等待
- if (fuzhai == 1) //負(fù)載開啟
- if (day == 1) //晚上
- if (ONOFF == 1) //放電到充電一循環(huán),開啟
- TMR1ON=1; //中斷TMR1開啟,開始計時
- if (RC1 == 0) //雨控控制,0為雨控檢測無雨,短接帽斷路
- yukon_num1++;
- if (yukon_num1 > 16) //檢測超過20次沒有雨
- yukon_num1 = 0; //計數(shù)清0
- RC2 = 1; //沒有雨水,繼電器啟動
- else //雨控控制,0為雨控檢測有雨,短接帽連通,將5v電壓拉到RC1引腳
- yukon_num2++;
- if (yukon_num2 > 16) //檢測超過20次有雨
- yukon_num2 = 0; //計數(shù)清0
- RC2 = 0; //下雨,繼電器關(guān)閉
- else
- RC2 = 0; //未實(shí)現(xiàn)放電到充電的循環(huán),繼電器關(guān)閉,負(fù)載未啟動
- else
- RC2 = 0; //白天繼電器關(guān)閉,負(fù)載未啟動
- else
- RC2 = 0; //繼電器關(guān)閉,負(fù)載未啟動
- if (chondian == 1) //1為充電未完成,繼續(xù)充電
- if (taiyangban == 1) //1為太陽板電壓高于電池
- RC1 = 1; //RC3高電平,電源模塊充電,太陽板給電池充電
- if (num > 0)
- num = 0; //定時清0
- if (h > 0)
- h = 0;
- condianshansuo(); ////充電藍(lán)燈閃爍
- else
- RC3 = 0; //充電完成,RC3低電平,電源模塊不充電
- if (a < 1) //藍(lán)燈不閃爍
- z = 0; //RA0=0
- else
- z = 0; //RA0=0
- void anxia()
- anjian_num1++;
- if (anjian_num1 > 4000)
- anjian_num1 = 0;
- anjian_num2++; //增加一小時(定時數(shù)據(jù))
- a = 2; //藍(lán)燈閃爍一次
- k = 1; //有未寫入數(shù)據(jù)
- void sonkai()
- if(k == 1)
- eeprom_write(0x04,anjian_num2); //把a(bǔ)njian_num2寫到地址0x04
- qcts = anjian_num2; //清除定時時間
- k = 0; //沒有未寫入數(shù)據(jù)
- anjian_num1 = 0;
- anjian_num2 = 0; //清除定時數(shù)據(jù)
- if(t == 1) //開始讀定時時間
- if (a < 1) //藍(lán)燈不閃爍的時候
- if (anjian_num2 > 0) //定時時間大于0
- anjian_num1++;
- if (anjian_num1 > 4000) //延時7200
- if (anjian_num1%2000 == 0) //延時時間/2000=0
- anjian_num2--; //減去一次已顯示的
- else
- t = 0; //讀定時時間控制位清除
- anjian_num1; //延時清零
- else
- if ( anjian_num1>200 ) //短按10s-20s之間,可以開始讀定時間t=1
- if (anjian_num1<1000)
- a = 6; //開始讀藍(lán)燈閃爍5次
- t = 1; //開始讀定時時間
- anjian_num2 = eeprom_read(0x04); //從內(nèi)存讀取定時數(shù)據(jù)
- anjian_num1 = 0; //延時清零
- void shezhi() //設(shè)置定時時間
- if (RC4 == 0) //按鍵按下
- anxia();
- else //按鍵松開
- sonkai();
- void dianchi() //每次開機(jī)判斷所使用的電池,和讀入定時時間
- if (RA4 == 0 ) ////RA4口為低時是用蓄電池
- if (eeprom_read(0x05)==1) //如果RA4口為蓄電池,控制位為1時,就寫入蓄電池的數(shù)據(jù)
- eeprom_write(0x01,50); //最低電壓
- eeprom_write(0x02,67); //最高電壓
- eeprom_write(0x05,0); //標(biāo)記為蓄電池 ????
- else //RA4口為高時是用鋰電池
- if (eeprom_read(0x05)==0) //如果RA4口為鋰電池,控制位為0時,就寫入鋰電池的數(shù)據(jù)
- eeprom_write(0x01,43); //最低電壓(41)
- eeprom_write(0x02,58); //最高電壓
- eeprom_write(0x05,1); //標(biāo)記為鋰電池 ???
- qcts = eeprom_read(0x04); //(預(yù)計清·蟲天數(shù)為5天一次)
- if(eeprom_read(0x03) <= qcts) //(判斷清除天數(shù)幾天一次)
- eeprom_write(0x03,6); //(將清蟲天數(shù)記錄設(shè)為6天一次)
- void init2 ()
- T0CS = 0; //Timer0使用內(nèi)部時鐘 OPTION_REG _ 選擇寄存器
- PSA=1; //將預(yù)分頻器給看門狗WDT OPTION_REG _ 選擇寄存器
- TMR0=0x00; //定時器
- T0IF=1; //Timer0 啟動控制位使能(0關(guān)閉)(標(biāo)志位) INTCON _ 中斷控制寄存器
- T0IE=1; //Timer0中斷開啟(使能位) INTCON _ 中斷控制寄存器
- TMR1CS = 0; //Timer1使用內(nèi)部時鐘 Timer1 控制寄存器
- T1CKPS0=1; //1:8倍預(yù)分頻比 Timer1 控制寄存器 T1CKPS1:T1CKPS0:11=1:8倍預(yù)分頻比
- T1CKPS1=1; //1:8倍預(yù)分頻比 Timer1 控制寄存器
- //TMR1H=(65536-(500000/8))/256; //初始化TMR1的高八位初始值 0.5s中斷溢出一次
- //TMR1L=(65536-(500000/8))%256; //初始化TMR1的低八位初始值
- TMR1H=0x0B; //高八位置初始值
- TMR1L=0xE9; //低八位置初始值
- TMR1ON=0; //Timer1 啟動控制位使能(0關(guān)閉) Timer1 控制寄存器
- TMR1IF=0; //中斷標(biāo)志位清零 外設(shè)中斷標(biāo)志寄存器 1
- TMR1IE=1; //Timer1中斷開啟 外設(shè)中斷使能寄存器 1
- PEIE=1; //外部中斷開啟 INTCON ? 中斷控制寄存器
- GIE=1; //全局中斷開啟 INTCON ? 中斷控制寄存器
- void dc() //倒蟲
- if (RC5 == 0)
- RC5 = 1;
- if (RC5 == 1 && RA5 == 0)
- m = 1; //(步驟控制)
- if (RC5 == 1 && RA5 == 1 && m == 1)
- daochon_num++; //倒蟲天數(shù)增加
- m = 0;
- if (daochon_num >= 2) //超過兩天清一次蟲
- daochon_num = 0; //清0
- RC5 = 0;
- eeprom_write(0x03,0);
- void interrupt time0()
- if (TMR1IF == 1)
- TMR1IF=0; //中斷標(biāo)志溢出清0
- num++;
- if (num == 139) //定時計時1一個小時溢出
- h++; //每小時自增
- num = 0; //溢出清0
- if (h == 1)
- eeprom_write(0x03,eeprom_read(0x03)+1); //清蟲天數(shù)計數(shù)+1天
- if (h == 5) //等于設(shè)定的小時
- h = 0; //小時清零
- RC2 = 0; //繼電器/負(fù)載關(guān)閉
- ONOFF=0; //放電到充電一循環(huán),時間到置0,關(guān)閉
- if (T0IF == 1) //1 = TMR0 寄存器溢出 (必須在軟件中清除) 0 = TMR0 寄存器沒有溢出
- T0IF = 0; //tmr0溢出清零
- yanshi++;
- TMR0=0x00;
- n++;
- if (n > 250) //1s/256us=3906.25,1秒溢出
- n = 0; //溢出清0
- ADAN2(); //讀AD轉(zhuǎn)化口RA2/AN2
- ADAN4(); //讀AD轉(zhuǎn)化口RC0/AN4
- panduan (); //轉(zhuǎn)換后的數(shù)據(jù)判斷,定義是否需要開燈、充電、雨控等待
- if (eeprom_read(0x03)>=qcts && TMR1ON==1) //讀清蟲設(shè)定天數(shù)2天的時候 ?????
- dc(); //倒蟲
- if (a > 0)
- kaijishansuo(); //開機(jī)藍(lán)燈閃爍5次
- if (z == 1)
- RA0 = 1; //藍(lán)燈閃爍
- else
- RA0 = 0;
- shezhi(); //設(shè)置定時時間
- void main ()
- init1(); //通道初始化
- init2 (); //定時器初始化
- dianchi(); //電池選擇
- dc(); //倒蟲
- while (1) //死循環(huán)
