查看: 1410|回復(fù): 0
Arduino紅外線,無線解碼程序樣板
ID:328023 發(fā)表于 2024-1-20 11:19 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
解碼原理,利用arduino的微秒函數(shù),通過端口中斷(上升源,下降源),得到時(shí)間,就可以解碼波形
void    subir_decode(void)
    volatile static unsigned long timerf,timerf1,timerf2;
    volatile static unsigned long wcdata_decode,bkdata;
    volatile static u8 wcshift,bit_enable_rx ;
    timerf2 = micros() ;
    timerf = 0 ;
    //digitalWrite(LED_BLUE, !digitalRead(LED_BLUE));
    if(timerf2>timerf1)
    timerf = timerf2-timerf1 ;
    timerf1 = timerf2 ;
    if((timerf>5000)&&(timerf<20000))
    //    digitalWrite(LED_BLUE, !digitalRead(LED_BLUE));
        //Serial.write(timerf/100);
        wcshift = 31 ;
    //    wcdata_decode = 0x00 ;
            if(timerf<1800)
                wcdata_decode = wcdata_decode&0xfffffffe ;
                wcdata_decode = wcdata_decode|0x00000001 ;
            if(wcshift>0)
            wcshift-- ;
            wcdata_decode = wcdata_decode<<1 ;
                bfirok = 1 ;
                wcirdecode = wcdata_decode ;
                bkdata = wcdata_decode ;
                wcshift = 255 ;
            //    Serial.write((wcdata_decode&0x00ff0000)>>16);
            //    Serial.write((wcdata_decode&0x0000ff00)>>8);
            //    Serial.write((wcdata_decode&0x000000ff));
