查看: 1066|回復(fù): 1
STM32F4 HAL波形發(fā)生器怎么沒有波形輸出?敬請(qǐng)指教
ID:82098 發(fā)表于 2024-1-24 13:30 | 只看該作者 回帖獎(jiǎng)勵(lì) |正序?yàn)g覽 |閱讀模式
//初始化DAC
void DAC_DAC1_Init(void)//初始化DAC
    /*配置GPIO*/
        GPIO_InitTypeDef GPIO_Initure;
        __HAL_RCC_DAC_CLK_ENABLE();             //使能DAC時(shí)鐘
        __HAL_RCC_GPIOA_CLK_ENABLE();           //開啟GPIOA時(shí)鐘
        GPIO_Initure.Pin=GPIO_PIN_4;            //PA4
        GPIO_Initure.Mode=GPIO_MODE_ANALOG;     //模擬
        GPIO_Initure.Pull=GPIO_NOPULL;          //不帶上下拉
        HAL_GPIO_Init(GPIOA,&GPIO_Initure);
    /*DAC通道1配置*/
        DAC_ChannelConfTypeDef DACCH1_Config;
        hdac1.Instance=DAC;
        HAL_DAC_Init(&hdac1);                 //初始化DAC
        DACCH1_Config.DAC_Trigger=DAC_TRIGGER_T6_TRGO;             //定時(shí)器2的更新觸發(fā)
        DACCH1_Config.DAC_OutputBuffer=DAC_OUTPUTBUFFER_DISABLE;//DAC1輸出緩沖關(guān)閉
        HAL_DAC_ConfigChannel(&hdac1,&DACCH1_Config,DAC_CHANNEL_1);//DAC通道1配置
        HAL_DAC_Start(&hdac1,DAC_CHANNEL_1);  //開啟DAC通道1
//TIM6配置
//通用定時(shí)器6中斷初始化
//arr:自動(dòng)重裝值
//psc:時(shí)鐘預(yù)分頻數(shù)
//定時(shí)器溢出時(shí)間計(jì)算方法:Tout=((arr+1)*(psc+1))/Ft us.
//Ft=定時(shí)器工作頻率,單位:Mhz
//這里使用的是定時(shí)器6!
void DAC_TIM6_Init(u32 Freq)//TIM6初始化
    /*TIM6配置*/
    u32 usPeriod;
    u16 usPrescaler;
    u32 uiTIMxCLK;
    uiTIMxCLK = SystemCoreClock / 2;//84MHZ
    if (Freq < 100)
        usPrescaler = 10000 - 1;                       /*分頻比 = 10000*/
        usPeriod =  (uiTIMxCLK / 10000) / Freq  - 1;/*自動(dòng)重裝的值*/
    else if (Freq < 3000)
        usPrescaler = 100 - 1;                       /*分頻比 = 100*/
        usPeriod =  (uiTIMxCLK / 100) / Freq  - 1;/*自動(dòng)重裝的值*/
    else    /*大于4K的頻率,無(wú)需分頻*/
        usPrescaler = 0;                   /*分頻比 = 1*/
        usPeriod = uiTIMxCLK / Freq - 1;/*自動(dòng)重裝的值*/
    __HAL_RCC_TIM6_CLK_ENABLE();                     //使能TIM6時(shí)鐘
    htim6.Instance=TIM6;                             //通用定時(shí)器6
    htim6.Init.Prescaler=usPrescaler;//arr;          //分頻系數(shù)
    htim6.Init.CounterMode=TIM_COUNTERMODE_UP;       //向上計(jì)數(shù)器
    htim6.Init.Period=usPeriod;//psc;                //自動(dòng)裝載值
    htim6.Init.ClockDivision=0;//TIM_CLOCKDIVISION_DIV1; //時(shí)鐘分頻因子
    HAL_TIM_Base_DeInit(&htim6);                     //時(shí)基復(fù)位
    HAL_TIM_Base_Init(&htim6);                       //定時(shí)器6初始化
    TIM6->CR2 &= ~(0x0070);                          //清除定時(shí)器6MMS位
    TIM6->CR2 |= 0x0020;                             //選擇定時(shí)器更新事件作為觸發(fā)輸出
    __HAL_TIM_ENABLE(&htim6);                        //開啟定時(shí)器6
//DMA配置
//DMAx的各通道配置
//這里的傳輸形式是固定的,這點(diǎn)要根據(jù)不同的情況來(lái)修改
//從存儲(chǔ)器->外設(shè)模式/8位數(shù)據(jù)寬度/存儲(chǔ)器增量模式
//void DAC_DMA_Init(void)
*   函 數(shù) 名: DAC_DMA1_Init
*   功能說(shuō)明: 配置PA4 為DAC_OUT1, 啟用DMA2
*   形    參: BufAddr : DMA數(shù)據(jù)緩沖區(qū)地址
*             Count   : 緩沖區(qū)樣本個(gè)數(shù)
*            Freq  : DAC樣本更新頻率
*   返 回 值: 無(wú)
void DAC_DMA1_Init(u32 BufAddr, u32 Count, u32 Freq)
    __HAL_TIM_DISABLE(&htim6);//失能定時(shí)器
    DAC_TIM6_Init(Freq);//TIM6初始化
    /*DAC通道1配置*/
        hdac1.Instance=DAC;
    __HAL_RCC_DMA1_CLK_ENABLE();//DMA1時(shí)鐘使能
    //Tx DMA配置
        hdma_dac1.Instance=DMA1_Stream5;                            //數(shù)據(jù)流選擇
        hdma_dac1.Init.Channel=DMA_CHANNEL_7;                                //通道選擇
        hdma_dac1.Init.Direction=DMA_MEMORY_TO_PERIPH;             //存儲(chǔ)器到外設(shè)
        hdma_dac1.Init.PeriphInc=DMA_PINC_DISABLE;                 //外設(shè)非增量模式
        hdma_dac1.Init.MemInc=DMA_MINC_ENABLE;                     //存儲(chǔ)器增量模式
        hdma_dac1.Init.PeriphDataAlignment=DMA_PDATAALIGN_HALFWORD;    //外設(shè)數(shù)據(jù)長(zhǎng)度:16位
        hdma_dac1.Init.MemDataAlignment=DMA_PDATAALIGN_HALFWORD;       //存儲(chǔ)器數(shù)據(jù)長(zhǎng)度:16位
        hdma_dac1.Init.Mode=DMA_CIRCULAR;                            //循環(huán)模式
        hdma_dac1.Init.Priority=DMA_PRIORITY_MEDIUM;               //中等優(yōu)先級(jí)
        hdma_dac1.Init.FIFOMode=DMA_FIFOMODE_DISABLE;
        hdma_dac1.Init.FIFOThreshold=DMA_FIFO_THRESHOLD_FULL;
        hdma_dac1.Init.MemBurst=DMA_MBURST_SINGLE;                 //存儲(chǔ)器突發(fā)單次傳輸
        hdma_dac1.Init.PeriphBurst=DMA_PBURST_SINGLE;              //外設(shè)突發(fā)單次傳輸
        HAL_DMA_DeInit(&hdma_dac1);
        HAL_DMA_Init(&hdma_dac1);
        DMA1_Stream5->CR|=1;    //使能DMA
        __HAL_LINKDMA(&hdac1,DMA_Handle1,hdma_dac1);    //將DMA與DAC1聯(lián)系起來(lái)
        //啟動(dòng)DAC和DMA
        HAL_DAC_Start_DMA(&hdac1,DAC_CHANNEL_1,(uint32_t*)g_Wave1, 210,DAC_ALIGN_12B_R);
dac.zip
2.06 KB, 下載次數(shù): 0
ID:1110495 發(fā)表于 2024-2-1 11:24 | 只看該作者
先給dac一個(gè)恒定的輸出,看電壓輸出是否正常。排除dac輸出沒問題后,看看定時(shí)器中斷是否正常進(jìn)入,記得在msp函數(shù)里配置中斷。
