查看: 2959|回復(fù): 14
STM32CBT6單片機(jī)SPI通信,端口重定義引腳PA15,PB3,PB4,PB5
ID:1102481 發(fā)表于 2024-1-25 15:12 | 顯示全部樓層 |閱讀模式
300黑幣
描述:原本使用的SPI2,端口PB12.13.15   PA0  正常顯示   對應(yīng)  CS,SCLK,SDA,RS(命令/數(shù)據(jù))
         換成SPI1,端口 PA15,PB3.4.5                               對應(yīng)  CS,SCLK,RS(命令/數(shù)據(jù)),SDA    問題:換了以后,不能顯示。只換PA15,可以顯示,所以問題出在PB345這塊。請教大家
#include "SPI.h"
void GPIO_Config(void)
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);
          RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
                //對應(yīng)的SCK   PB3
                GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable , ENABLE);
                GPIO_PinRemapConfig(GPIO_Remap_SPI1 , ENABLE);
                GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_3;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
            //MOSI為 SDA       PB 5
    GPIO_InitStructure.GPIO_Pin =   GPIO_Pin_5;
                //MISO__A0 --  PB4
    GPIO_InitStructure.GPIO_Pin =   GPIO_Pin_4;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        //液晶初始化I/O口  rst      PA0  --rst
    GPIO_InitStructure.GPIO_Pin =   GPIO_Pin_0;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
        //片選    PA15___CS
                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
void SPI_Initial()
        SPI_InitTypeDef  SPI_InitStructure;
  SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx;//設(shè)置SPI單向或者雙向的數(shù)據(jù)模式:SPI設(shè)置為雙線雙向全雙工
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;        //設(shè)置SPI工作模式:設(shè)置為主SPI
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;//設(shè)置SPI的數(shù)據(jù)大小:SPI發(fā)送接收8位幀結(jié)構(gòu)
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;//選擇了串行時(shí)鐘的穩(wěn)態(tài):時(shí)鐘懸空高
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;//數(shù)據(jù)捕獲于第二個(gè)時(shí)鐘沿
  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;         //NSS信號(hào)由硬件(NSS管腳)還是軟件(使用SSI位)管理:內(nèi)部NSS信號(hào)有SSI位控制
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;//定義波特率預(yù)分頻的值:波特率預(yù)分頻值為2
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //指定數(shù)據(jù)傳輸從MSB位還是LSB位開始:數(shù)據(jù)傳輸從MSB位開始
  SPI_Init(SPI1, &SPI_InitStructure);         //根據(jù)SPI_InitStruct中指定的參數(shù)初始化外設(shè)SPIx寄存器
  SPI_Cmd(SPI1, ENABLE);
void RCC_Configuration(void)
  ErrorStatus HSEStartUpStatus;
  /*RCC 復(fù)位和時(shí)鐘設(shè)置*/
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();                                         //時(shí)鐘管理重置
  /* Enable HSE 外部高速晶振*/
  RCC_HSEConfig(RCC_HSE_ON);                   //打開外部晶振
  /* Wait till HSE is ready 等待外部晶振 就緒, 返回值:SUCCESS 就緒,ERROR 未就緒*/
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);    //Flash讀取緩沖啟動(dòng)Flash預(yù)取值    加速
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);                                            //Flash操作的延時(shí)設(shè)置Flash_Latency延時(shí)2周期
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);                                         //AHB使用系統(tǒng)時(shí)鐘
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);                                  //APB2(高速)為HCLK的一半
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);                           //APB1(低速)為HCLK的一半
        //注:AHB主要負(fù)責(zé)外部存儲(chǔ)器時(shí)鐘。APB2負(fù)責(zé)AD,I/O,高級(jí)TIM,串口1。APB1負(fù)責(zé)DA,USB,SPI,I2C,CAN,串口2345,普通TIM
    /* ADCCLK = PCLK2/4 */
    RCC_ADCCLKConfig(RCC_PCLK2_Div4);        //默認(rèn)4
    /* PLLCLK = 8MHz * 7 = 56 MHz   注意此處的8M是指的外部晶振的大小*/
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);      //PLLCLK = 8MHz * 9 = 72 MH      默認(rèn)為7
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);        //啟動(dòng)PLL
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET){}       //等待PLL啟動(dòng)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);                                //將PLL設(shè)置為系統(tǒng)時(shí)鐘源
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08){}                          //等待系統(tǒng)時(shí)鐘源的啟動(dòng)
void SPI_SendData(uint8_t byte)
  while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
  SPI_I2S_SendData(SPI1, byte);
最佳答案
查看完整內(nèi)容
或許你我的手上的手冊不一樣? 我手上的這份明白表示,PB3/4/5,沒有原生態(tài)SPI接口,連映射的都沒有。既然本就沒有,你映射過去也依然沒用。 至于只換PA15可以,是因?yàn)槟愕腟PI_NSS是由軟件控制的,可以是任意IO。 而硬件控制,則需跟隨SPIx的群組走了。 附上手冊,其中第21頁你看一下。 如果確定有SPI,那恐怕是要查一下外圍了。
ID:1102481 發(fā)表于 2024-1-26 10:12 | 顯示全部樓層
cocolala 發(fā)表于 2024-1-25 21:17
看下JTAG默認(rèn)的IO口,注意映射問題。
如圖,JTAG 占用PA15,PB3.PB4,       已經(jīng)用代碼         RCC_APB2PeriphClockCmdRCC_APB2Periph_AFIO,ENABLE);        GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable , ENABLE);        GPIO_PinRemapConfig(GPIO_Remap_SPI1 , ENABLE);
開啟AFIO,將PB3.4變?yōu)槠胀ǹ谧,不知道哪里還是不行。
ID:69038 發(fā)表于 2024-1-25 15:12 | 顯示全部樓層
或許你我的手上的手冊不一樣?
附上手冊,其中第21頁你看一下。
STM32F103X8.pdf (15.39 MB, 下載次數(shù): 3)
ID:1102481 發(fā)表于 2024-1-25 15:14 | 顯示全部樓層
這個(gè)是測試包,問題在   SPI和LCD12864部分
測試.7z
170.05 KB, 下載次數(shù): 3
ID:883242 發(fā)表于 2024-1-25 16:03 | 顯示全部樓層
stm32更新?lián)Q代好多次了,具體型號(hào)都不肯說誰也幫不了你,說了其實(shí)也沒用因?yàn)樘嗔,還是自己用CubeMX配置一下好一些。
如果是第一代STM32F103才可以用這個(gè)STDPeripheral庫。
ID:161164 發(fā)表于 2024-1-25 16:08 | 顯示全部樓層
30塊包郵的邏輯分析儀,你值得擁有
ID:137005 發(fā)表于 2024-1-25 16:12 | 顯示全部樓層
STM32 PB3 PB4 PB5作為普通IO,用作SPI使用
https://blog.csdn.net/feiyingzaishi/article/details/103108929
參與人數(shù) 1黑幣 +12 收起 理由
衛(wèi)玉書 + 12 共享資料的黑幣獎(jiǎng)勵(lì)!
ID:226055 發(fā)表于 2024-1-25 21:17 | 顯示全部樓層
ID:1102481 發(fā)表于 2024-1-26 10:04 | 顯示全部樓層
Hephaestus 發(fā)表于 2024-1-25 16:03
stm32更新?lián)Q代好多次了,具體型號(hào)都不肯說誰也幫不了你,說了其實(shí)也沒用因?yàn)樘嗔,還是自己用CubeMX配置 ...
不好意思,打錯(cuò)字了,STM32F103C8T6,第一次用這個(gè)懸賞,提示我有%詞匯,然后可能刪除的時(shí)候,漏了。
確實(shí)太多了。具體問題已經(jīng)指出,SPI1端口重映射的問題,但是可能第一次用端口映射,這里面問題不清楚在哪里,所以求助大家,也不知道如何將懸賞給大家
ID:1102481 發(fā)表于 2024-1-26 10:06 | 顯示全部樓層
好的,謝謝你的建議
ID:1102481 發(fā)表于 2024-1-26 10:14 | 顯示全部樓層
lkc8210 發(fā)表于 2024-1-25 16:08
30塊包郵的邏輯分析儀,你值得擁有
小白,第一次聽說,好的,我看看。謝謝
ID:69038 發(fā)表于 2024-1-26 11:53 | 顯示全部樓層
103Cx系列貌似沒有SPI3。甚至低容量版本(<64K)的只有一個(gè)SPI1
只有在STM32F103Rx/Vx/Zx中,PB3/4/5才是SPI3,
在CBT6中PB3/4/5只是GPIO和Jlink接口,也不能映射到SPI1,你要的SPI1在PA4/5/6。
ID:1102481 發(fā)表于 2024-1-26 17:14 | 顯示全部樓層
zhuls 發(fā)表于 2024-1-26 11:53
是的,沒有用到SPI3,原來用的SPI2,后來IO不夠,改成用SPI1。
我的問題就是如何正確的在基礎(chǔ)代碼基礎(chǔ)上,成功改到SPI1(注意看題)。然后8樓是C8T6的引腳資源,
關(guān)閉JTAG,開啟AFIO,   PB5的IIC也關(guān)了,SPI2也試著關(guān)了,暫時(shí)沒用。
ID:1102481 發(fā)表于 2024-1-29 10:16 | 顯示全部樓層
zhuls 發(fā)表于 2024-1-25 15:12
或許你我的手上的手冊不一樣?
我手上的這份明白表示,PB3/4/5,沒有原生態(tài)SPI接口,連映射的都沒有。既然 ...
感謝 ,您的手冊和我的確實(shí)不一樣。我又看了一下這個(gè)數(shù)據(jù)手冊,確實(shí)有SPI1的映射,不過您的關(guān)于PA15的回答確實(shí)解決了我一個(gè)困惑,,謝謝您無私的指點(diǎn)。我再找找其他問題,祝新年快樂
ID:1102481 發(fā)表于 2024-1-29 10:19 | 顯示全部樓層
molo 發(fā)表于 2024-1-25 16:12
https://blog.csdn.net/feiyingzaishi/article/details/103108 ...
實(shí)在抱歉,最佳答案只能有一個(gè),感謝您的指點(diǎn)
