這個程序用著不錯,可以玩玩
- // DHT21使用范例
- //單片機(jī) AT89S52 或 STC89C52RC
- //功能 串口發(fā)送溫濕度數(shù)據(jù) 晶振 11.0592M 波特率 9600
- //硬件 P2.0口為通訊口連接DHT11,DHT11的電源和地連接單片機(jī)的電源和地,單片機(jī)串口加MAX232連接電腦
- #include <reg51.h>
- #include <intrins.h>
- typedef unsigned char U8; /* defined for unsigned 8-bits integer variable 無符號8位整型變量 */
- typedef signed char S8; /* defined for signed 8-bits integer variable 有符號8位整型變量 */
- typedef unsigned int U16; /* defined for unsigned 16-bits integer variable 無符號16位整型變量 */
- typedef signed int S16; /* defined for signed 16-bits integer variable 有符號16位整型變量 */
- typedef unsigned long U32; /* defined for unsigned 32-bits integer variable 無符號32位整型變量 */
- typedef signed long S32; /* defined for signed 32-bits integer variable 有符號32位整型變量 */
- typedef float F32; /* single precision floating point variable (32bits) 單精度浮點(diǎn)數(shù)(32位長度) */
- typedef double F64; /* double precision floating point variable (64bits) 雙精度浮點(diǎn)數(shù)(64位長度) */
- #define uchar unsigned char
- #define uint unsigned int
- #define Data_0_time 4
- //----------------IO口定義區(qū)--------------------//
- sbit P2_0 = P2^0 ;
- //----------------定義區(qū)--------------------//
- U8 U8FLAG,k;
- U8 U8count,U8temp;
- U8 U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
- U8 U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
- U8 U8comdata;
- U8 outdata[5]; //定義發(fā)送的字節(jié)數(shù)
- U8 indata[5];
- U8 count, count_r=0;
- U8 str[5]={"RS232"};
- U16 U16temp1,U16temp2;
- SendData(U8 *a)
- outdata[0] = a[0];
- outdata[1] = a[1];
- outdata[2] = a[2];
- outdata[3] = a[3];
- outdata[4] = a[4];
- count = 1;
- SBUF=outdata[0];
- void Delay(U16 j)
- { U8 i;
- for(;j>0;j--)
- for(i=0;i<27;i++);
- void Delay_10us(void)
- U8 i;
- i--;
- i--;
- i--;
- i--;
- i--;
- i--;
- void COM(void)
- U8 i;
- for(i=0;i<8;i++)
- U8FLAG=2;
- while((!P2_0)&&U8FLAG++);
- Delay_10us();
- Delay_10us();
- Delay_10us();
- U8temp=0;
- if(P2_0)U8temp=1;
- U8FLAG=2;
- while((P2_0)&&U8FLAG++);
- //超時則跳出for循環(huán)
- if(U8FLAG==1)break;
- //判斷數(shù)據(jù)位是0還是1
- // 如果高電平高過預(yù)定0高電平值則數(shù)據(jù)位為 1
- U8comdata<<=1;
- U8comdata|=U8temp; //0
- }//rof
- //-----濕度讀取子程序 ------------
- //----以下變量均為全局變量--------
- //----溫度高8位== U8T_data_H------
- //----溫度低8位== U8T_data_L------
- //----濕度高8位== U8RH_data_H-----
- //----濕度低8位== U8RH_data_L-----
- //----校驗(yàn) 8位 == U8checkdata-----
- //----調(diào)用相關(guān)子程序如下----------
- //---- Delay();, Delay_10us();,COM();
- void RH(void)
- //主機(jī)拉低18ms
- P2_0=0;
- Delay(180);
- P2_0=1;
- //總線由上拉電阻拉高 主機(jī)延時20us
- Delay_10us();
- Delay_10us();
- Delay_10us();
- Delay_10us();
- //主機(jī)設(shè)為輸入 判斷從機(jī)響應(yīng)信號
- P2_0=1;
- //判斷從機(jī)是否有低電平響應(yīng)信號 如不響應(yīng)則跳出,響應(yīng)則向下運(yùn)行
- if(!P2_0) //T !
- U8FLAG=2;
- //判斷從機(jī)是否發(fā)出 80us 的低電平響應(yīng)信號是否結(jié)束
- U8FLAG=2;
- //判斷從機(jī)是否發(fā)出 80us 的高電平,如發(fā)出則進(jìn)入數(shù)據(jù)接收狀態(tài)
- //數(shù)據(jù)接收狀態(tài)
- COM();
- U8RH_data_H_temp=U8comdata;
- COM();
- U8RH_data_L_temp=U8comdata;
- COM();
- U8T_data_H_temp=U8comdata;
- COM();
- U8T_data_L_temp=U8comdata;
- COM();
- U8checkdata_temp=U8comdata;
- P2_0=1;
- //數(shù)據(jù)校驗(yàn)
- U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp);
- if(U8temp==U8checkdata_temp)
- U8RH_data_H=U8RH_data_H_temp;
- U8RH_data_L=U8RH_data_L_temp;
- U8T_data_H=U8T_data_H_temp;
- U8T_data_L=U8T_data_L_temp;
- U8checkdata=U8checkdata_temp;
- }//fi
- }//fi
- //main()功能描述: AT89C51 11.0592MHz 串口發(fā)
- //送溫濕度數(shù)據(jù),波特率 9600
- void main()
- U8 i,j;
- //uchar str[6]={"RS232"};
- /* 系統(tǒng)初始化 */
- TMOD = 0x20; //定時器T1使用工作方式2
- TH1 = 253; // 設(shè)置初值
- TL1 = 253;
- TR1 = 1; // 開始計(jì)時
- SCON = 0x50; //工作方式1,波特率9600bps,允許接收
- ES = 1;
- EA = 1; // 打開所以中斷
- TI = 0;
- RI = 0;
- SendData(str) ; //發(fā)送到串口
- Delay(1); //延時100US(12M晶振)
- while(1)
- //調(diào)用溫濕度讀取子程序
- RH();
- //串口顯示程序
- str[0]=U8RH_data_H;
- str[1]=U8RH_data_L;
- str[2]=U8T_data_H;
- str[3]=U8T_data_L;
- str[4]=U8checkdata;
- //讀取模塊數(shù)據(jù)周期不易小于 2S
- Delay(20000);
- }//elihw
- }// main
- void RSINTR() interrupt 4 using 2
- U8 InPut3;
- if(TI==1) //發(fā)送中斷
- TI=0;
- if(count!=5) //發(fā)送完5位數(shù)據(jù)
- SBUF= outdata[count];
- count++;
- if(RI==1) //接收中斷
- InPut3=SBUF;
- indata[count_r]=InPut3;
- count_r++;
- RI=0;
- if (count_r==5)//接收完4位數(shù)據(jù)
- //數(shù)據(jù)接收完畢處理。
- count_r=0;
- str[0]=indata[0];
- str[1]=indata[1];
- str[2]=indata[2];
- str[3]=indata[3];
- str[4]=indata[4];
- P0=0;
參考資料.7z
2024-2-22 00:42 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
5.21 MB, 下載次數(shù): 11, 下載積分: 黑幣 -5
一些參考資料
