#include <STC8h.H>
#include <stdio.h>
#include <intrins.h>
sbit RS = P2^4; //定義LCD1602端口
sbit RW = P2^5;
sbit EN = P2^6;
#define DataPort P0
#define RS_CLR RS=0
#define RS_SET RS=1
#define RW_CLR RW=0
#define RW_SET RW=1
#define EN_CLR EN=0
#define EN_SET EN=1
void delay(unsigned int ms) //@11.0592MHz
unsigned char i, j;
while(ms--)
i = 15;
j = 90;
do
while (--j);
} while (--i);
bit LCD_Check_Busy(void)
DataPort= 0xFF;
RS_CLR;
RW_SET;
EN_CLR;
delay(1);
EN_SET;
delay(1);
return (bit)(DataPort & 0x80);
void LCD_Write_Com(unsigned char com)
while(LCD_Check_Busy()); //忙則等待
RS_CLR;
RW_CLR;
EN_SET;
DataPort= com;
delay(1);
EN_CLR;
delay(1);
void LCD_Write_Data(unsigned char Data)
RS_SET;
RW_CLR;
EN_SET;
DataPort= Data;
delay(1);
EN_CLR;
delay(1);
void LCD_Clear(void)
LCD_Write_Com(0x01);
delay(5);
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
if (y == 0)
LCD_Write_Com(0x80 + x); //表示第一行
LCD_Write_Com(0xC0 + x); //表示第二行
while ((*s)!='\0')
LCD_Write_Data( *s);
s ++;
void LCD_Init(void)
LCD_Write_Com(0x38); /*顯示模式設(shè)置*/
delay(5);
delay(5);
delay(5);
LCD_Write_Com(0x08); /*顯示關(guān)閉*/
LCD_Write_Com(0x01); /*顯示清屏*/
LCD_Write_Com(0x06); /*顯示光標(biāo)移動(dòng)設(shè)置*/
delay(5);
LCD_Write_Com(0x0C); /*顯示開(kāi)及光標(biāo)設(shè)置*/
void DisplayVoltage(float voltage)
unsigned char str[16];
sprintf(str,"Voltage: %.2fV",voltage);
LCD_Write_Com(0x80);
LCD_Write_String(0,0,str);
void ADC_Init(void)
ADC_CONTR |= 0x80; //AD上電
ADCTIM = 0x3f; //設(shè)置ADC內(nèi)部時(shí)序
ADC_CONTR &= 0x7f; //AD斷電
ADCCFG = 0x2f; //設(shè)置ADC時(shí)鐘為系統(tǒng)時(shí)鐘/2/16,12位結(jié)果右對(duì)齊
ADC_CONTR = 0x80; //使能ADC模塊上電
delay(4);
ADC_CONTR |= 0x01; //選P01作為AD輸入
uint ADC_Read()
ADC_CONTR |= 0x40; //啟動(dòng)AD轉(zhuǎn)換
delay(2);
while ((ADC_CONTR & 0x20)==0); //查詢ADC完成標(biāo)志
ADC_CONTR &= ~0x20; //清完成標(biāo)志
return ADC_RES << 8 | ADC_RESL; //返回12位ADC結(jié)果
void main(void)
P0M0=0;
P0M1=0;
P2M0=0;
P2M1=0;
LCD_Init();
LCD_Clear();//清屏
ADC_Init();
delay(3);
while (1)
unsigned int rawVoltage = ADC_Read();
float voltage = (rawVoltage * 5.0) / 4095; // 假設(shè)參考電壓是5V
DisplayVoltage(voltage);
delay(900);
在測(cè)量時(shí)有點(diǎn)電壓(不管是0.5v還是3.3v)就直接顯示5V,不進(jìn)行測(cè)量時(shí)讀數(shù)在0~5v之間一直變化。程序有什么錯(cuò)誤?指教指教!
