查看: 2276|回復(fù): 3
STC8單片機(jī)之EV1527無(wú)線433M解碼程序
ID:105206 發(fā)表于 2024-3-9 22:28 | 顯示全部樓層 |閱讀模式
MCU:STC8單片機(jī)
解碼協(xié)議:EV1527
顯示:LCD1602
  1. #include "time.h"
  2. #include "uart.h"
  3. #include "delay.h"
  4. #include "task.h"
  5. ////////////////////////////////
  6. unsigned char decode_ok;
  7. unsigned int  hh_w,ll_w;
  8. unsigned char  ma_x;
  9. unsigned char  bma1,bma2,bma3,bma4;
  10. unsigned char  mma1,mma2,mma3,mma4;
  11. unsigned char mmb1,mmb2,mmb3,mmb4;
  12. //extern uint8_t mmb1,mmb2,mmb3,mmb4;
  13. unsigned char rf_ok1,rf_ok2,rf_ok;
  14. unsigned char old_rc5;
  15. unsigned char tb_ok;
  16. unsigned char D0,D1,D2,D3 ;
  17. unsigned int s ,s1;
  18. unsigned char bt_auto;
  19. unsigned char rf_data[4];
  20. void rexode_433M(void);
  21. //bit open_led_flag=0;
  22. unsigned char count_5ms=0;
  23.
  24. extern unsigned char code out[];//LED數(shù)組
  25. extern u8 add1,spacing,mode;//地址,間隔時(shí)間,模式
  26. //////////////////////////////////////////
  27. void Timer0Init(void)
  28. {
  29.         TMOD|=0x00;
  30.         TL0=65536-10;                                                //定時(shí)10ms
  31.         TH0=(65536-10)>>8;
  32. /////////////////////以下STC12/////////////////////
  33. //                TL0=65536-46;                                                //定時(shí)10ms,系統(tǒng)時(shí)鐘12分頻后,定時(shí)1的時(shí)鐘為2.25M,
  34. //                TH0=(65536-46)>>8;
  35.         TR0=1;ET0=1;        //定時(shí)器0 ,定時(shí)16位模式
  36.         EA=1;
  37. }
  38. //////////////////////////////////////////
  39. void timer0_interrupt(void) interrupt 1
  40. {
  41.         TL0=(65535-50)%256;                                                //定時(shí)50us,
  42.         TH0=(65535-50)/256;
  43.         count_5ms++;
  44.         TX_433M_pin=~TX_433M_pin;
  45.         rexode_433M();
  46. }
  47. //////////////////////////////////////////////
  48. void rexode_433M(void)
  49. {
  50.         if (!RF)
  51.         {
  52.                 ll_w++;
  53.                 old_rc5=0;
  54.         }
  55.         else
  56.         {
  57.         hh_w++;
  58.         if (!old_rc5)
  59.         {   // 2/5 100/130
  60.                 if (((hh_w>=2)&&(hh_w<=15))&&((ll_w>=160)&&(ll_w<=320)))
  61.                 {
  62.                         tb_ok = 1 ;
  63.                         ma_x = 0;
  64.                         bma1=0; bma2=0; bma3=0; bma4=0;
  65.                 }
  66.                 else if ((tb_ok)&&((ll_w>=19)&&(ll_w<=33))) //8/13
  67.                 {
  68.                         ma_x++;
  69.                         if(ma_x>23)
  70.                         {
  71.                                 if(!rf_ok1)
  72.                                 {
  73.                                         mma1=bma1;
  74.                                         mma2=bma2;
  75.                                         mma3=bma3;
  76.                                         mma4=bma4;
  77.
  78.                                         rf_ok1=1;
  79.                                         tb_ok=0;
  80.                                         s=10000;
  81.                                         }
  82.                                         else
  83.                                         {
  84.                                                 mmb1=bma1;
  85.                                                 mmb2=bma2;
  86.                                                 mmb3=bma3;
  87.                                                 mmb4=bma4;
  88.
  89.                                                 rf_ok2=1;
  90.                                                 tb_ok=0;
  91.                                         }
  92.                                 }
  93.                          }
  94.                          else if ((tb_ok)&&((ll_w>=2)&&(ll_w<=14)))   // 2/7
  95.                          {
  96.                                  switch (ma_x)
  97.                                  {
  98.                                  case 0 : { bma1=bma1 | 0x01; break; }
  99.                                  case 1 : { bma1=bma1 | 0x02; break; }
  100.                                  case 2 : { bma1=bma1 | 0x04; break; }
  101.                                  case 3 : { bma1=bma1 | 0x08; break; }
  102.                                  case 4 : { bma1=bma1 | 0x10; break; }
  103.                                  case 5 : { bma1=bma1 | 0x20; break; }
  104.                                  case 6 : { bma1=bma1 | 0x40; break; }
  105.                                  case 7 : { bma1=bma1 | 0x80; break; }
  106.                                  case 8 : { bma2=bma2 | 0x01; break; }
  107.                                  case 9 : { bma2=bma2 | 0x02; break; }
  108.                                  case 10: { bma2=bma2 | 0x04; break; }
  109.                                  case 11: { bma2=bma2 | 0x08; break; }
  110.                                  case 12: { bma2=bma2 | 0x10; break; }
  111.                                  case 13: { bma2=bma2 | 0x20; break; }
  112.                                  case 14: { bma2=bma2 | 0x40; break; }
  113.                                  case 15: { bma2=bma2 | 0x80; break; }
  114.                                  case 16: { bma3=bma3 | 0x01; break; }
  115.                                  case 17: { bma3=bma3 | 0x02; break; }
  116.                                  case 18: { bma3=bma3 | 0x04; break; }
  117.                                  case 19: { bma3=bma3 | 0x08; break; }
  118.                                  case 20: { bma3=bma3 | 0x10; break; }// ?????1?
  119.                                  case 21: { bma3=bma3 | 0x20; break; }
  120.                                  case 22: { bma3=bma3 | 0x40; break; }
  121.                                  case 23: { bma3=bma3 | 0x80;
  122.                                                           if(!rf_ok1)
  123.                                                           {
  124.        mma1=bma1;
  125.        mma2=bma2;
  126.        mma3=bma3;
  127.                                                            // mma4=bma4;
  128.        rf_ok1=1;
  129.        tb_ok=0;
  130. //                                   bt_auto=0;
  131.        s=10000;
  132.        break;
  133.                                                           }
  134.                                                           else
  135.                                                           {
  136.        mmb1=bma1;
  137.        mmb2=bma2;
  138.        mmb3=bma3;
  139.        //mmb4=bma4;
  140.        rf_ok2=1;
  141.        tb_ok=0;
  142.        break;
  143.                                                          }
  144.                                                 }
  145.                     }
  146.                     ma_x++;
  147.                  }
  148.                  else
  149.                  {ma_x=0; tb_ok=0;bt_auto=0;bma1=0;bma2=0; bma3=0; hh_w=1;ll_w=0;}
  150.                  ll_w=0;hh_w=1;
  151.              }
  152.              old_rc5=1;
  153.        }
  154.        if(rf_ok1)
  155.         {
  156.             s--;
  157.             if(!s) rf_ok1=0;
  158.             if(rf_ok2)
  159.             {
  160.             if((mma1==mmb1)&&(mma2==mmb2)&&(mma3==mmb3))
  161.             {
  162.                 rf_ok=1;
  163.                 rf_ok1=0;
  164.                 rf_ok2=0;
  165.             }
  166.             else
  167.             {
  168.                 rf_ok=0;
  169.                 rf_ok1=0;
  170.                 rf_ok2=0;
  171.              }
  172.         }
  173.     }
  174.     if((rf_ok))
  175.     {
  176.         TR0=0;
  177.         rf_ok=0;
  178.         rf_data[0]=mma1;
  179.         rf_data[1]=mma2;
  180.         rf_data[2]=mma3;
  181.                 SendOneByte(rf_data[0]);
  182.                 SendOneByte(rf_data[1]);
  183.                 SendOneByte(rf_data[2]);
  184.         decode_ok=1;
  185.         TR0=1;
  186.     }
  187. }
  188. ////////////////////////////////////////////
  189. void EV1527_decoding()
  190. {
  191.         char i=0;
  192.         /////////////////解碼值////////////////////////////////
  193.                 if(decode_ok)
  194.                 {
  195.                          decode_ok=0;
  196.                         switch(rf_data[2])
  197.                         {
  198.                                 case  0x19: OUT1=~OUT1;rf_data[2]=0;break;//1號(hào)鍵
  199.                                 case  0x29: OUT2=~OUT2;rf_data[2]=0;break;
  200.                                 case  0x49: OUT3=~OUT3;rf_data[2]=0;break;
  201.                                 case  0x89: OUT4=~OUT4;rf_data[2]=0;break;
  202.                                 case  0x39: OUT5=~OUT5;rf_data[2]=0;break;
  203.                                 case  0x59: OUT6=~OUT6;rf_data[2]=0;break;
  204.                                 case  0xa9: OUT7=~OUT7;rf_data[2]=0;break;
  205.                                 case  0x69: OUT8=~OUT8;rf_data[2]=0;break;
  206.                                 case  0x79: OUT9=~OUT9;rf_data[2]=0;break;
  207.                                 case  0xe9: OUT10=~OUT10;rf_data[2]=0;break;//10號(hào)鍵
  208. /////////////11鍵亮(流水)/////////12鍵滅(流水)////////////////////////////////////////////
  209.                                 case 0X99:   //解碼                遙控器11鍵
  210.                                 {
  211.                                         delay_ms(1);
  212.                                         led=out[i];//led燈開(kāi)始往后面亮delay_ms(2);//led燈開(kāi)始往后面亮
  213.                                         i++;
  214.                                         delay_ms(spacing*100);
  215.                                         if(i>8)//如果led燈亮完了
  216.                                         {
  217.
  218.                                                 i=8;
  219.                                                 led=0xff;rf_data[2]=0;
  220.                                         }
  221.                                 }break;
  222.                                 case 0Xd9:   //解碼                遙控器12鍵
  223.                                 {
  224.                                         delay_ms(1);
  225.                                         led=out[i];//滅-》滅
  226.                                         i--;
  227.                                         delay_ms(spacing*100);
  228.                                         if(i<0)
  229.                                         {
  230.
  231.                                                 i=0;led=0x00; //p35=1;
  232.                                                 rf_data[2]=0;
  233.                                         }
  234.                                 }break;
  235.                         }
  236.
  237.                 }
  238.
  239.
  240. }
#include "time.h"
#include "uart.h"
#include "LCD1602.h"
#include "delay.h"
#include "key.h"
#include "task.h"
extern u8         xdata U1RxBuf[];
extern u8 add;
extern bit flag;
extern unsigned char Uartflag ;                          //UART判斷標(biāo)志位
extern char Recive_state ;   //接收完成標(biāo)志
                            主函數(shù)
        InitUART();
        Timer0Init();
///////////////配置端口為雙向口////////////////////////
        P1M0=0X00;
        P1M1=0X00;
        P2M0=0X00;
        P2M1=0X00;
        P3M0=0X00;
        P3M1=0X00;
        Init_LCD1602();;//lcd初始化
        delay_ms(10);
        LCD_Clear();          //清屏
//////////////////////LOGO///////////////////////////
        LCD1602_write_com(0x80);                //指針指向第1行第0個(gè)位置
        LCD1602_write_word("       BLD      ");//寶蕾德電子產(chǎn)品
        LCD1602_write_com(0x80+0x40);        //指針指向第2行第0個(gè)位置
        LCD1602_write_word("0~10s APPLE:S118");
        delay_ms(100);
        LCD_Clear();//清屏
        LCD1602_write_word("                 ");
        LCD1602_write_word("spacing:    s~   ");        //
//        spacing=IapRead(0x0000);         //EEPROM  讀0x0000到hc[0]
//        add1=IapRead(0x0002);         //EEPROM  讀0x0002到hc[1]
//        mode=IapRead(0x0004);         //EEPROM  讀0x0002到hc[2]
        delay_ms(2);
        spacing_data();
        P2=0x00;
        while(1)   //無(wú)限循環(huán)
                EV1527_decoding();//解碼
                display_zhu();
原理圖: 無(wú)
仿真: 無(wú)
代碼: STC8-解碼433M EV1527 串口發(fā)送OK版.rar (84.37 KB, 下載次數(shù): 69)
參與人數(shù) 1黑幣 +70 收起 理由
admin + 70 共享資料的黑幣獎(jiǎng)勵(lì)!
ID:672792 發(fā)表于 2024-3-10 16:59 | 顯示全部樓層
好資料必須支持,
ID:491875 發(fā)表于 2024-3-11 08:42 | 顯示全部樓層
如果能夠增加掉電喚醒功能就可以方便控制接受芯片進(jìn)入節(jié)電模式方便單火線取電功能的實(shí)現(xiàn)那就完美了,現(xiàn)在市面上有這個(gè)芯片
ID:465279 發(fā)表于 2024-6-7 23:45 來(lái)自觸屏版 | 顯示全部樓層
學(xué)習(xí)了?留著下次再看
