查看: 1921|回復(fù): 2
DIY 51單片機(jī)尋跡小車 附程序
#include <STC89C5xRC.H>
typedef unsigned char u8;
typedef unsigned int  u16;
sbit PWM1 = P3^3;          //左電機(jī)控制信號(hào)
sbit PWM2 = P3^4;
sbit PWM3 = P3^5;          //右電機(jī)控制信號(hào)
sbit PWM4 = P3^6;
sbit Lin = P2^7;                  //左紅外模塊
sbit Rin = P2^5;                  //右紅外模塊
sbit K1 = P1^0;                  //功能按鍵
sbit LED= P1^2;
u8 connt=2;                          //調(diào)速周期/10ms/100hz
u8 COM = 0;                            //功能控制位
bit Q_J=0;     //前進(jìn)標(biāo)志
bit H_T=0;    //后退標(biāo)志
bit Z_Z=0;      //左轉(zhuǎn)標(biāo)志
bit Y_Z=0;    //右轉(zhuǎn)標(biāo)志
void delay( u16 k )                   //延時(shí)1ms
    u16 i,j;
        for(i=k;i>0;i--)
        for(j=120;j>0;j--);
void time0()                                        //T0初始化函數(shù)
         TMOD = 0x01;                          //定時(shí)器模式
         TL0 = 0x18;                        //定時(shí)初始值
         TH0 = 0xFC;
         TF0 = 0;                                 //清除TF0標(biāo)志
   ET0 = 1;                                          //打開(kāi)計(jì)時(shí)器中斷
   TR0 = 1;                                        //啟動(dòng)計(jì)時(shí)器
void SC()
   Q_J=0; H_T=0;
         Z_Z=0; Y_Z=0;
   PWM1=0; PWM2=0;  //剎車
         PWM3=0; PWM4=0;
void QJ()                                   //前進(jìn)
         H_T=0; Z_Z=0; Y_Z=0;
         Q_J=1;
void HT()                                   //后退
   Z_Z=0; Y_Z=0; Q_J=0;
         H_T=1;
void ZZ()                                   //左轉(zhuǎn)
   Y_Z=0; Q_J=0; H_T=0;
         Z_Z=1;
void YZ()                                   //右轉(zhuǎn)
         Q_J=0; H_T=0; Z_Z=0;
   Y_Z=1;
void lin1()                                           //尋跡功能程序
   if( Lin && Rin )                //左右=1,小車前進(jìn)
                         QJ();
             delay(100);
             SC();
             delay(150);
        if( !Lin && !Rin )                //左右=0,小車停止
             SC();      //待機(jī)
        if( !Lin && Rin )                //左=0,右=1,小車左轉(zhuǎn)
             SC();
             delay(100);
             ZZ();
             delay(100);
        if( Lin && !Rin )                //右=0,左=1,小車右轉(zhuǎn)
             SC();
             delay(100);
             YZ();
             delay(100);
//void lin2()        //手勢(shì)程序
  //if( Lin && Rin )                 //兩探頭=1,小車前進(jìn)
        //QJ();
  //if( !Lin && !Rin )                //兩探頭=0,小車后退
              //HT();
void konzi()                  //控制
    if( K1 == 0 )
            delay(10);
            COM++;
            while( !K1 );
                        delay(10);
        if( COM >=2)COM = 0;
void main ()                                   //主函數(shù)
    time0();                                                 //T0初始化
    EA = 1;    //打開(kāi)總中斷
          SC();      //待機(jī)
                          konzi();
        switch(COM)                                           //功能選擇
                 case 0: SC(); break;
                                         case 1: lin1();break;                //尋跡
                 case 2: lin2();break;                //手勢(shì)控制
void Timer0Interrupt() interrupt 1         //T0中斷函數(shù)1ms
   static u8 PWM_Cnt =0;
         static u16 S =0;
   TL0 = 0x18;
         TH0 = 0xFC;
         S++;
         PWM_Cnt++;
         if(Q_J)                       //前進(jìn)
                           PWM4 = 0;
         PWM2 = 0;
                if(PWM_Cnt<=connt)
                           PWM1 = 1;
                           PWM3 = 1;
                            PWM1 = 0;
                            PWM3 = 0;
   if(H_T)                       //后退
               PWM1 = 0;
                           PWM3 = 0;
                        if(PWM_Cnt<=connt)
                           PWM2 = 1;
                                 PWM4 = 1;
                           PWM2 = 0;
                           PWM4 = 0;
                if(Z_Z)                      //左轉(zhuǎn)
              PWM1 = 0;
                          PWM2 = 0;
                          PWM4 = 0;
                 if(PWM_Cnt<=connt)
                           PWM3 = 1;
                     PWM3 = 0;
                if(Y_Z)                      //右轉(zhuǎn)
                           PWM2 = 0;
               PWM3 = 0;
                           PWM4 = 0;
                if(PWM_Cnt<=connt)
                            PWM1 = 1;
                            PWM1 = 0;
  if(PWM_Cnt>=10)PWM_Cnt = 0;
        if(S>=1000)  //秒脈沖
                   LED=~LED;
                         S=0;
收藏收藏7 分享淘帖 頂 踩
ID:291549 發(fā)表于 2024-3-17 21:51 | 只看該作者
感謝提供這么好的例程及方案。
ID:1130203 發(fā)表于 2024-8-5 20:39 | 只看該作者
您好,準(zhǔn)大學(xué)生,想復(fù)刻您的51單片機(jī)尋跡小車,想詢問(wèn)下能否要下您的原理圖和pcb
