查看: 1262|回復(fù): 8
關(guān)于C語言的const結(jié)構(gòu)指標(biāo)用法問題
ID:903667 發(fā)表于 2024-3-18 23:50 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
如何讓 Disp()共用 const 結(jié)構(gòu)與RAM 結(jié)構(gòu)
#include <iostream>
#include <cstring>
typedef struct {
                uint8_t reg[2];
               }ST_t;
const ST_t  AAVal = {44,55};  // 副程式必須加 "const"
ST_t  BBVal = {11,22};
//void Disp(const ST_t *Ptr)  // 是否可以不用加"const"
void Disp(ST_t *Ptr)
      printf("AAVal[0] = %d   AAVal[1] = %d \n",Ptr->reg[0],Ptr->reg[1]);
int main(void)
    Disp(&AAVal);
//  Disp(&BBVal);  // error: invalid conversion from ‘const ST_t*’ to ‘ST_t*’ [-fpermissive]
    printf("AAVal[0] = %d AAVal[1] = %d \n",AAVal.reg[0],AAVal.reg[1]);
    return (0);
ID:883242 發(fā)表于 2024-3-19 00:33 | 只看該作者
我用mingw_w64 13.0編譯你的代碼,只有warning沒有error,你用的是什么編譯器?
ID:277550 發(fā)表于 2024-3-19 11:54 | 只看該作者
編譯參數(shù)中不將warning當(dāng)錯(cuò)誤,通常是警告的
ID:903667 發(fā)表于 2024-3-19 21:03 | 只看該作者
Hephaestus 發(fā)表于 2024-3-19 00:33
為什么 void Disp(ST_t *Ptr) 無法取 const 資料??
該如何改比較正確?
#include <iostream>
#include <cstring>
typedef struct {
                uint8_t reg[2];
               }ST_t;
const ST_t  AAVal = {44,55};  // "Flash 里"
ST_t  BBVal = {11,22};        // "RAM里"
      printf("Val[0] = %d   Val[1] = %d \n",Ptr->reg[0],Ptr->reg[1]);
int main(void)
    Disp(&AAVal);
    return (0);
我使用 jyshare站的/compile/12/   與 onlinegdb 編輯
ID:883242 發(fā)表于 2024-3-19 22:17 | 只看該作者
keyway 發(fā)表于 2024-3-19 21:03
該如何改比較正確?
-fpermissive
Downgrade some required diagnostics about nonconformant code from errors to warnings. Thus, using -fpermissive allows some nonconforming code to compile. Some C++ diagnostics are controlled only by this flag, but it also downgrades some C and C++ diagnostics that have their own flag:
-Wdeclaration-missing-parameter-type (C and Objective-C only)
-Wimplicit-function-declaration (C and Objective-C only)
-Wimplicit-int (C and Objective-C only)
-Wincompatible-pointer-types (C and Objective-C only)
-Wint-conversion (C and Objective-C only)
-Wnarrowing (C++ and Objective-C++ only)
-Wreturn-mismatch (C and Objective-C only)
The -fpermissive option is the default for historic C language modes (-std=c89, -std=gnu89, -std=c90, -std=gnu90).
ID:903667 發(fā)表于 2024-3-21 00:03 | 只看該作者
Hephaestus 發(fā)表于 2024-3-19 22:17
-fpermissive
Downgrade some required diagnostics about nonconformant code from errors to warnings ...
出現(xiàn)error的原因是C++設(shè)計(jì)的比C更加安全,它不能自動(dòng)的將void *轉(zhuǎn)換為其它指針類型
解決方法:CFLAGS = -fpermissive
但 Mplab xc8與Keil 如何設(shè)定此參數(shù)?
ID:883242 發(fā)表于 2024-3-21 00:09 | 只看該作者
keyway 發(fā)表于 2024-3-21 00:03
解決方法:CFLAGS =  ...
單片機(jī)就不要蹭這個(gè)問題了,PC上面const變量好歹是在RAM里面只是不讓你改,單片機(jī)的const根本就沒法動(dòng)。
ID:1088185 發(fā)表于 2024-3-21 11:30 | 只看該作者
調(diào)用時(shí)轉(zhuǎn)換一下就行了
Disp((ST_t*)&BBVal);
ID:903667 發(fā)表于 2024-3-21 22:33 | 只看該作者
1600277881 發(fā)表于 2024-3-21 11:30
謝謝~~原來指標(biāo)也可以強(qiáng)制轉(zhuǎn)換為其它類型
